Re: Does this look sketchy to you? [Re: ChryCoGuy] #3087873
10/20/22 05:44 PM
10/20/22 05:44 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Originally Posted by ChryCoGuy
Seems like a lot of trouble to go through for a refrigerator (not to mention the potential for disaster). I probably would have just found a way to level the fridge, or just put my cold stuff in the fridge inside the house... work
You really have to cool down a propane refrigerator before you put food in it. I am sure it is a temporary situation while they pack the camper for a trip.
My Monster are real!
Living within your means makes life pretty easy.
Re: Does this look sketchy to you? [Re: Cab_Burge] #3087889
10/20/22 06:42 PM
10/20/22 06:42 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Originally Posted by Cab_Burge
I think putting the parking brake on real hard before putting the tranny into park should work okay work shruggy
up up And especially after that "Parking or Emergency" brake catfight argue you would think no one would have an issue with it holding. Yes it would be extra safe blocking the rear wheels or putting wheel chocks there but both the parking/emergency and trans PARK mode should hold it no problem.
Re: Does this look sketchy to you? [Re: 67vertman] #3087892
10/20/22 06:44 PM
10/20/22 06:44 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Great point as they don't look like they are too portable or intended to be used anywhere but temporarily in their driveway.
Re: Does this look sketchy to you? [Re: 67vertman] #3087893
10/20/22 06:47 PM
10/20/22 06:47 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I'm looking at them differently "those are the biggest front wheel chocks I have ever seen, no chance in my mind of that truck rolling down the driveway with those chocks!" laugh2
Re: Does this look sketchy to you? [Re: A12] #3087898
10/20/22 07:30 PM
10/20/22 07:30 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
"Romance in the Lance" might be a little sketchy ifn you catch my drift.
Re: Does this look sketchy to you? [Re: SV_MOPARS] #3087904
10/20/22 07:59 PM
10/20/22 07:59 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
I always run my LQ fridge on house current or 12V before leaving on a trip so it is cold when I put food in it, then turn it to propane when I am ready to leave. But I generally think with common sense in advance... work
JB Rhinehart, Realist
A-Body's RULE!
Re: Does this look sketchy to you? [Re: Hemi_Joel] #3087911
10/20/22 08:42 PM
10/20/22 08:42 PM
IMGTX Offline
IMGTX  Offline
I see that and cringe but from a physics standpoint it is valid.
Creepy looking but valid.
I would think that extended time on the ramps would deform the front control arm bushings though.
Re: Does this look sketchy to you? [Re: IMGTX] #3087935
10/20/22 09:58 PM
10/20/22 09:58 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The way the front ramps are built is questionable to me. I would think they are a pretty aggressive lift on the front, and the build construction could be better. I suspect putting the truck on those front ramps is pretty nerve racking, simply because of the angle, my concern would be of just one ramp sliding. One ramp sliding just a few inches would cause some serious shift in the weight distribution.
That 1st step out of the cab, once its parked would be exciting, and getting back into the truck to move it wouldn't be much fun either.
I must admit, I've seen much more sketchy camping set ups then this one. Those people can take sketchy to a whole new level.
Re: Does this look sketchy to you? [Re: poorboy] #3087936
10/20/22 10:03 PM
10/20/22 10:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Ramps aside, the truck is more level than it would be if parked in the existing driveway. One should see some of the hills in San Francisco that people have parked o for years twocents
Re: Does this look sketchy to you? [Re: TJP] #3088165
10/21/22 08:47 PM
10/21/22 08:47 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Seems it would be MUCH simpler to level the refrigerator inside so I'm guessing it's for more than just the that. But it's hard to tell how sturdy those ramps are but they appear to be fairly well built. I don't see a problem as long as ramps are sturdy and parking brake is set.
Facts are stubborn things.
Re: Does this look sketchy to you? [Re: larrymopar360] #3088439
10/23/22 02:02 AM
10/23/22 02:02 AM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
Pretty much impossible to level the fridge inside. Most RV fridges are built right in. My only issue would be those ramps. It does appear that the load-bearing section is in shear.
Re: Does this look sketchy to you? [Re: 360view] #3088488
10/23/22 06:43 AM
10/23/22 06:43 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
My second thought has little to do with engineering,
it is the truck owner should call his insurance company and ask
“Will my policy pay if anything goes wrong with this parking set up?
Better know in advance than risk it.
