Re: Bore out lifter bores to .937 ?
[Re: hemienvy]
#3087981
10/21/22 05:42 AM
10/21/22 05:42 AM
Posts: 761 Southington Ct.
turbobitt
Southington Ct.
I'm going through this now. The BHJ lifter tooling my machine shop used was cutting the bores to .992" so we had BHJ make bushings to fit that with the appropriate press. Typically the standard is 1.0000" To be honest I'm sure cutting the bore to .937 would work but the oil intersection feed hole starts getting really big at that point and may just bleed to much oil. AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: hemienvy]
#3088099
10/21/22 03:06 PM
10/21/22 03:06 PM
Posts: 4,210 New York
polyspheric
New York
Olds Rocket, diesel and 425/455 big block: .921" tappet
Boffin Emeritus
[Re: hemienvy]
#3088393
10/22/22 08:39 PM
10/22/22 08:39 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
Probably because most if not all of the machine shops put in bushings. But you might be on to something. Maybe it will become a trend? The bushings do have the benefit of oil control.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3088428
10/22/22 11:26 PM
10/22/22 11:26 PM
turbobitt
Southington Ct.
FWIW, this was mine in the BHJ lifter true fixturing. AG.
[Re: hemienvy]
#3088434
10/23/22 01:34 AM
10/23/22 01:34 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
A rare bump. I find it hard to believe more are not interested in this topic. I think maybe because of what was mentioned, the oil hole is huge to start and only gets bigger. If you're running enough lobe lift that could benefit a .937 lifter I think it would be tough to -not- uncover that oil gallery.
[Re: hemienvy]
#3088493
10/23/22 08:21 AM
10/23/22 08:21 AM
Posts: 6,149 Melbourne , Australia
LA360
I think anyone going up to 0.937" in lifter diameter, would want the oil control a bushing can provide.
That being said, with tie bar lifters in this diameter being more common, it might be something you start seeing more often.
Alan Jones
[Re: Blucuda413]
#3097814
11/28/22 03:15 PM
11/28/22 03:15 PM
Posts: 1,165 Loudoun County, VA
Brad_Haak
Loudoun County, VA
My concern with a basic passenger car block is how much meat there is for the lifters when they're taken that much further out plus the OD of the bronze bushing for oil control. Here's what mine look like with a standard 440 block, .904 lifters plus bronze bushings.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3097820
11/28/22 03:32 PM
11/28/22 03:32 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
My concern with a basic passenger car block is how much meat there is for the lifters when they're taken that much further out plus the OD of the bronze bushing for oil control. Here's what mine look like with a standard 440 block, .904 lifters plus bronze bushings. I recently saw a hemi block w/ lifter bushings that broke the whole lifter boss off. It was an early megablock that didn't have all the extra meat cast into the bosses. It broke on either #1 or #2 cylinder...can't recall exactly which.
[Re: Brad_Haak]
#3097951
11/28/22 10:45 PM
11/28/22 10:45 PM
polyspheric
New York
What's the OD/ID of the bushing and what material used?
BB Buicks (400, 430, 455) have notoriously weak lifter banks, and split from too much power NA: be careful.
Boffin Emeritus
[Re: hemienvy]
#3097996
11/29/22 07:02 AM
11/29/22 07:02 AM
polyspheric
New York
Thanks, that's thinner wall than I would have guessed. I'm working on an engine with .990" tappets being bushed down to take a different roller tappet.
Boffin Emeritus
[Re: an8sec70cuda]
#3098013
11/29/22 08:50 AM
11/29/22 08:50 AM
Posts: 8,033 Tulsa OK
Bad340fish
Tulsa OK
My concern with a basic passenger car block is how much meat there is for the lifters when they're taken that much further out plus the OD of the bronze bushing for oil control. Here's what mine look like with a standard 440 block, .904 lifters plus bronze bushings. I recently saw a hemi block w/ lifter bushings that broke the whole lifter boss off. It was an early megablock that didn't have all the extra meat cast into the bosses. It broke on either #1 or #2 cylinder...can't recall exactly which. I assume you are talking about the same one I am about to post. This was a Local guys Hemi.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3098022
11/29/22 09:28 AM
11/29/22 09:28 AM
an8sec70cuda
My concern with a basic passenger car block is how much meat there is for the lifters when they're taken that much further out plus the OD of the bronze bushing for oil control. Here's what mine look like with a standard 440 block, .904 lifters plus bronze bushings. I recently saw a hemi block w/ lifter bushings that broke the whole lifter boss off. It was an early megablock that didn't have all the extra meat cast into the bosses. It broke on either #1 or #2 cylinder...can't recall exactly which. I assume you are talking about the same one I am about to post. This was a Local guys Hemi. Yessir! The one Wayne built. Not a lot of meat there at all. HUGE difference in that block versus the style that turbobitt posted above.
[Re: an8sec70cuda]
#3098500
11/30/22 07:53 PM
11/30/22 07:53 PM
Posts: 3,505 DFW
mr_340
DFW
Trend 15TrendPerform.com INNER DIAMETER OUTER DIAMETER LENGTH TYPE STOP HEIGHT RECOMMENDED BORE SIZE APPLICATION PART # MOPAR 0.875 0.995 1.380 Step 0.120 0.993 Mopar 340 02-5054 0.875 0.996 1.380 Step 0.120 0.994 Mopar oversize 02-5070 0.903 1.002 1.700 Straight n/a 1.000 BB Mopar wedge 02-5071 0.875 0.995 1.700 Step 0.120 0.993 Universal bushing 02-5075 UNIVERSAL 0.903 1.002 1.500 Step 0.120 1.000 Universal bushing 02-5072 0.903 1.002 1.600 Straight n/a 1.000 Universal bushing 02-5073 0.810 0.935 1.770 Step 0.120 0.933 Universal bushing 02-5085 0.825 0.935 1.770 Step 0.120 0.933 Universal bushing (.995" O.D. step) 02-5091 0.900 1.025 1.750 Step 0.120 1.023 Universal bushing (1.055" O.D. step) 02-5092 LIFTER BORE BUSHINGS Note: Lifter bore bushing must be bored or honed after installation. Minimum press: .001" Maximum press: .002" #609 Loctite® is recommended
Floyd Lippencott IV
