Bore out lifter bores to .937 ? #3087963
10/21/22 02:56 AM
10/21/22 02:56 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Instead of lifter bushings, has anyone just bored out to .937 lifter diameter ?
If you install bushings, what is the OD of the bushing ?
Re: Bore out lifter bores to .937 ? [Re: hemienvy] #3087981
10/21/22 05:42 AM
10/21/22 05:42 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I'm going through this now. The BHJ lifter tooling my machine shop used was cutting the bores to .992" so we had BHJ make bushings to fit that with the appropriate press. Typically the standard is 1.0000"
To be honest I'm sure cutting the bore to .937 would work but the oil intersection feed hole starts getting really big at that point and may just bleed to much oil.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Bore out lifter bores to .937 ? [Re: hemienvy] #3088099
10/21/22 03:06 PM
10/21/22 03:06 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Olds Rocket, diesel and 425/455 big block: .921" tappet
Boffin Emeritus
Re: Bore out lifter bores to .937 ? [Re: polyspheric] #3088366
10/22/22 07:26 PM
10/22/22 07:26 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
A rare bump. I find it hard to believe more are not interested in this topic.
Re: Bore out lifter bores to .937 ? [Re: hemienvy] #3088393
10/22/22 08:39 PM
10/22/22 08:39 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Probably because most if not all of the machine shops put in bushings. But you might be on to something. Maybe it will become a trend? The bushings do have the benefit of oil control.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Bore out lifter bores to .937 ? [Re: Hemi_Joel] #3088428
10/22/22 11:26 PM
10/22/22 11:26 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
FWIW, this was mine in the BHJ lifter true fixturing.
AG.
Re: Bore out lifter bores to .937 ? [Re: hemienvy] #3088434
10/23/22 01:34 AM
10/23/22 01:34 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I think maybe because of what was mentioned, the oil hole is huge to start and only gets bigger.
If you're running enough lobe lift that could benefit a .937 lifter I think it would be tough to -not- uncover that oil gallery.
Re: Bore out lifter bores to .937 ? [Re: INTMD8] #3088486
10/23/22 05:47 AM
10/23/22 05:47 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
INTMD8, I was thinking more about using a stronger more robust lifter on an existing cam, for reliability's sake.
The oil band argument is a good one, that could negate the deal.
Re: Bore out lifter bores to .937 ? [Re: hemienvy] #3088493
10/23/22 08:21 AM
10/23/22 08:21 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I think anyone going up to 0.937" in lifter diameter, would want the oil control a bushing can provide.
That being said, with tie bar lifters in this diameter being more common, it might be something you start seeing more often.
Alan Jones
Re: Bore out lifter bores to .937 ? [Re: LA360] #3097805
11/28/22 02:51 PM
11/28/22 02:51 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I'm also surprised that this is not a more common subject especially since mopar delivered some blocks with lifter bores of .912. I bought a block that unknowingly to me did have all 16 lifter bores at .912. It took me some time to determine where my oil pressure was going after the engine warmed up. I finally figured it out and was lucky to buy 16 of the last 52 lifters in mopar inventory. Since it cost so much to bush lifters I will definitely try a resurface on the lifters I have. If there were other reasonably priced options I would definitely consider them. I'm lucky that the block is currently sitting awaiting determination on what I want to do with it. Anyone had this problem before?
Re: Bore out lifter bores to .937 ? [Re: Blucuda413] #3097814
11/28/22 03:15 PM
11/28/22 03:15 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
My concern with a basic passenger car block is how much meat there is for the lifters when they're taken that much further out plus the OD of the bronze bushing for oil control. Here's what mine look like with a standard 440 block, .904 lifters plus bronze bushings.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Bore out lifter bores to .937 ? [Re: Brad_Haak] #3097820
11/28/22 03:32 PM
11/28/22 03:32 PM
an8sec70cuda Offline
iagree I recently saw a hemi block w/ lifter bushings that broke the whole lifter boss off. blush It was an early megablock that didn't have all the extra meat cast into the bosses. It broke on either #1 or #2 cylinder...can't recall exactly which.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Bore out lifter bores to .937 ? [Re: hemienvy] #3097821
11/28/22 03:32 PM
11/28/22 03:32 PM
Cab_Burge Online work
Cab_Burge  Online Work
I prime one of my stock unbush motors with the valley pan off, the lifter bores on most stock Mopar block leak a large amount of oil from them, A BUNCH whiney
Those stock type blocks converted to busing with don't up shock
In my opinion, after having one roller valve spring break years ago, allowing the lifter to be pushed out and cocked high enough in the stock lifter bore to unshroud that oil galley losing all pressure at 5600 RPM in high gear puke
My goal now is to have every stock block bush that will get a roller cam in it up work
Re: Bore out lifter bores to .937 ? [Re: Brad_Haak] #3097951
11/28/22 10:45 PM
11/28/22 10:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
What's the OD/ID of the bushing and what material used?
BB Buicks (400, 430, 455) have notoriously weak lifter banks, and split from too much power NA: be careful.
Boffin Emeritus
Re: Bore out lifter bores to .937 ? [Re: polyspheric] #3097977
11/29/22 12:40 AM
11/29/22 12:40 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Jesel doesn't have the OD on their website. I have not called to inquire.
I recall reading somewhere that their SMALLER bushings are 1.060" OD.
I don't think that leaves a lot of original meat left on the OE bore.
Re: Bore out lifter bores to .937 ? [Re: hemienvy] #3097996
11/29/22 07:02 AM
11/29/22 07:02 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Thanks, that's thinner wall than I would have guessed. I'm working on an engine with .990" tappets being bushed down to take a different roller tappet.
Boffin Emeritus
Re: Bore out lifter bores to .937 ? [Re: an8sec70cuda] #3098013
11/29/22 08:50 AM
11/29/22 08:50 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I assume you are talking about the same one I am about to post. This was a Local guys Hemi.
68 Barracuda Formula S 340
Re: Bore out lifter bores to .937 ? [Re: Bad340fish] #3098022
11/29/22 09:28 AM
11/29/22 09:28 AM
Yessir! The one Wayne built. Not a lot of meat there at all.
HUGE difference in that block versus the style that turbobitt posted above.
CHIP
Re: Bore out lifter bores to .937 ? [Re: an8sec70cuda] #3098500
11/30/22 07:53 PM
11/30/22 07:53 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Trend
15TrendPerform.com
INNER
DIAMETER
OUTER
DIAMETER LENGTH TYPE STOP HEIGHT RECOMMENDED
BORE SIZE APPLICATION PART #
MOPAR
0.875 0.995 1.380 Step 0.120 0.993 Mopar 340 02-5054
0.875 0.996 1.380 Step 0.120 0.994 Mopar oversize 02-5070
0.903 1.002 1.700 Straight n/a 1.000 BB Mopar wedge 02-5071
0.875 0.995 1.700 Step 0.120 0.993 Universal bushing 02-5075
UNIVERSAL
0.903 1.002 1.500 Step 0.120 1.000 Universal bushing 02-5072
0.903 1.002 1.600 Straight n/a 1.000 Universal bushing 02-5073
0.810 0.935 1.770 Step 0.120 0.933 Universal bushing 02-5085
0.825 0.935 1.770 Step 0.120 0.933 Universal bushing (.995" O.D. step) 02-5091
0.900 1.025 1.750 Step 0.120 1.023 Universal bushing (1.055" O.D. step) 02-5092
LIFTER BORE BUSHINGS
Note: Lifter bore bushing must be bored or honed after installation.
Minimum press: .001" Maximum press: .002"
#609 Loctite® is recommended
Floyd Lippencott IV
