Does this look sketchy to you?
#3087651
10/19/22 11:53 PM
10/19/22 11:53 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
A guy devised this to level the camper because the fridge needs to be level. I think it's too much stress on the driveline. Maybe if he used chocks to hold it, then put it in park it would be better. What do you think?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Does this look sketchy to you?
[Re: Ramrod39]
#3087655
10/20/22 12:17 AM
10/20/22 12:17 AM
Hemi_Joel
Minnesota
It looks to me like the ramps are very steep, More that the driveway behind the rear wheels. So it would be trying very hats to roll down the ramps.
[Re: Hemi_Joel]
#3087709
10/20/22 08:36 AM
10/20/22 08:36 AM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
It looks to me like the ramps are very steep, More that the driveway behind the rear wheels. So it would be trying very hats to roll down the ramps. I'd at least chock the rear wheels. I also agree w/ kerndog on the ramp design. Not how I would have done it, but if it works...
[Re: Kern Dog]
#3087718
10/20/22 09:21 AM
10/20/22 09:21 AM
Posts: 3,123 N.W. Florida
Fat_Mike
N.W. Florida
The top board of the ramps should lay over the top of the vertical member. The wood should be in "shear" , not the bolts holding it together. I'm no engineer, but that's the same thought I had. The way those ramps are built look like a disaster waiting to happen (to me).
[Re: Fat_Mike]
#3087726
10/20/22 09:38 AM
10/20/22 09:38 AM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
The top board of the ramps should lay over the top of the vertical member. The wood should be in "shear" , not the bolts holding it together. It's hard to tell in the picture but I think it's designed that way already. He just has the outer 2 vertical members running past to sandwich everything together. The inner ramps that are supporting the weight are sitting on top of the verticals. But it's hard to be 100% without a better picture.
[Re: Dart 500]
#3087762
10/20/22 11:36 AM
10/20/22 11:36 AM
Posts: 16,542 On the run…
BloFish
On the run…
Yes, they need to remain level.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3087803
10/20/22 01:59 PM
10/20/22 01:59 PM
Posts: 19,624 north of coder
moparx
maybe it's just me, but i would have made those ramps out of steel, welded together, with rubber gripper strips bolted to the bottom. definitely chock the rear wheels, and if that would be a semi-permanent parking spot, i would think seriously about sinking some anchoring points in the driveway [front and rear] to chain the truck fast so it couldn't possibly move in either direction while up in the air. of course that's just me thinking. your mileage will vary.
[Re: BloFish]
#3087820
10/20/22 02:34 PM
10/20/22 02:34 PM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
It doesn't matter if the refrigerator is level unless you're using it, right?
Are they planning to live in that or something?
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
