Re: Hydraulic vs. Solid Roller Cam
[Re: hudsonhornet7x]
#3085040
10/11/22 09:19 AM
10/11/22 09:19 AM
Posts: 1,202 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I don't have much faith in the current hydraulic roller lifters for BBM, primarily wrt RPM capability. I'd go w/ a solid roller and make sure the lobes are designed for street durability. Those generally don't require as much spring loads as typical race lobes, either.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
#3085083
10/11/22 11:46 AM
10/11/22 11:46 AM
Brad_Haak
Loudoun County, VA
I've heard it's a good idea to keep any solid-type cam idling at 1000+ to encourage oil splash at low RPMS. Mine has enough cam that it idles about 1200, so I never gave it much thought.
#3085084
10/11/22 11:46 AM
10/11/22 11:46 AM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
Saw on engine master where they ran Hyd roller with solid rollers.Seemed to pick up HP and torque.Seems the hyd cam has less steep ramps They did say that Crane lifters were some of the best Also said some cheaper lifters were problems in hyds.
Chrysler Firepower
#3085121
10/11/22 01:10 PM
10/11/22 01:10 PM
Posts: 4,213 New York
polyspheric
New York
If you go solid, you have to watch lash frequently, loose hammers the needles in the roller.
Boffin Emeritus
#3085149
10/11/22 02:57 PM
10/11/22 02:57 PM
Posts: 43,368 Bend,OR USA
Cab_Burge
Thanks for the advice. I have been reading up on hydraulic roller problems too. So, with a solid roller, do you need to keep your idle rpm higher? No, Mopar stock blocks have a lot of clearances (.003+) in the lifter bores to the lifters, way more than they should have ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) That being said that does allow a lot of oil to drip down onto the cam lobes and around the lifters, even at idle RPM under 1000 RPM ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) As far as maintenance on the solid roller lifters buy a good set, I like Crowers, and good rocker arm parts and run good clean oil to make the motor live. My last pump gas fast street car had a Comp Cams custom ground solid roller cam with their lifters and Harland Sharp aluminum roller rocker arm set up with their 1.65 ratio, I would check the lash after break in around once a year after everything was broken in and stop wearing the high points off the new moving parts like the pushrod and roller tips on the rocker arms ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
#3085199
10/11/22 05:50 PM
10/11/22 05:50 PM
Posts: 1,770 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
... What is a good cam/lifter setup for my application? ( Hydraulic or solid?)... Are you asking for specific size/part# combination recommendations, or for general feedback re: hydraulic vs solid? If specific size, I'd say there is a boat-load of info that needs to be shared before anyone can really comment: intended RPM range, drivetrain combo (if auto, what stall on the converter), what rear-end gearing and what tire size, vehicle weight, intake (single or dual) and exhaust setup (header sizing), engine CR, intended fuel use (you said street, so 87 or are you willing to cough up the cost of "arm&leg" to run premium - 93/94?), etc.
#3085252
10/11/22 09:28 PM
10/11/22 09:28 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Almost every BB we do now gets lifter bore bushings...idle pressure is 50+lbs. hot, little to no leaks, little to no air in the oil leading to the mains and rods...and much less engine noise. Bam DLC coated solid roller lifters, and a good smooth lobe with some lift will make great power...you'll need good rockers though... Brian
Brian Hafliger
[Re: Brian Hafliger]
#3085280
10/11/22 11:06 PM
10/11/22 11:06 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
Almost every BB we do now gets lifter bore bushings...idle pressure is 50+lbs. hot, little to no leaks, little to no air in the oil leading to the mains and rods...and much less engine noise. Bam DLC coated solid roller lifters, and a good smooth lobe with some lift will make great power...you'll need good rockers though... Brian What are some good rockers you recommend?
[Re: Diplomat360]
#3085385
10/12/22 11:40 AM
10/12/22 11:40 AM
Posts: 1,545 USA
hudsonhornet7x
USA
... What is a good cam/lifter setup for my application? ( Hydraulic or solid?)... Are you asking for specific size/part# combination recommendations, or for general feedback re: hydraulic vs solid? If specific size, I'd say there is a boat-load of info that needs to be shared before anyone can really comment: intended RPM range, drivetrain combo (if auto, what stall on the converter), what rear-end gearing and what tire size, vehicle weight, intake (single or dual) and exhaust setup (header sizing), engine CR, intended fuel use (you said street, so 87 or are you willing to cough up the cost of "arm&leg" to run premium - 93/94?), etc. My original question was for what type, hydraulic or solid. Does anyone know who makes the Trick Flow hydraulic lifters? I assume they buy them from someone else but not sure. Do they have a good rep?
#3087454
10/19/22 12:15 PM
10/19/22 12:15 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
I prefer solid rollers over everything else. Just my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: fast68plymouth]
#3087478
10/19/22 01:25 PM
10/19/22 01:25 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
My thoughts on a solid setup. Lash it a few times early on and get a feel for it. Once its set it really shouldn't move unless there is a problem. You will learn what it sounds like and will know if it needs attention. Know that long highway drives usually add to the noise from the prolonged heat soak that isn't normally present in main street cruisers. Mine usually needs some tiny adjustment to make me feel good, and I mean tiny, tiny enough that it could easily be chalked up to the engine position not being 100% the same as when it was set last time. That is a downside to checking it using the EOIC method and the starter I suppose.
If I drove my solid roller car daily I would probably check it once a month. It takes me 5-10 minutes at most to zip the covers off and run through the valves.
68 Barracuda Formula S 340
[Re: 69dart]
#3087496
10/19/22 02:17 PM
10/19/22 02:17 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
You wouldn’t be the first, or last person to do it.
You can plan on needing different length pushrods as well.
[Re: calrobb2000]
#3087541
10/19/22 05:17 PM
10/19/22 05:17 PM
polyspheric
New York
Noisy hydraulic tappets: something is wrong. Too much lifter body to bore clearance, misalignment of oil feed holes to the tappet, or not enough oil pressure. Other cause: are you sure your rockers are doing the right thing?
A solid roller tappet is struck violently by the cam lobe's opening ramp during the lash take-up, large tappet clearance amplifies this, and the entire shock load is taken by a small number of needles (not even half) in the roller assembly. Not real numbers, but if the roller OD is .750", the roller ID has to be at least .375" (roller is 3/16" wall). Allowing for 1/16" needles, there are only about 16 to 20 needles , and only those at 6:00 position (5-6?) are loaded.They don't like it.
Boffin Emeritus
[Re: polyspheric]
#3087554
10/19/22 06:08 PM
10/19/22 06:08 PM
Posts: 7,502 Minnesota
Hemi_Joel
Minnesota
For street use, if you go with a solid roller, it is important to go with a lifter that has pressure oiling to the roller axle. Do not us a splash lube roller lifter, it is very likely that you will have problems if you do. Also, the bushed lifters are pretty tuff, and there are no needles to fail.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
