WELL ITS THAT TIME AGAIN... CARS PUT IN HIBERNATION
#3087239
10/18/22 05:36 PM
10/18/22 05:36 PM
Posts: 14,471 renton, Washington
ph23vo
renton, Washington
CLEANED, FULL OF FUEL [GALLON OF RACE GAS ADDED TO EACH ON LAST DRIVE].. TIRES AT 50 PSI..BATTERIES OUT... SUCKS..BUT IN SEATTLE ITS A 3 MONTH SEASON IF WE ARE LUCKY..
FIRST TIME IN MY LIFE I HAVE MORE GARAGE THAN CARS... 9 MONTHS TO WAIT NOW..
Re: WELL ITS THAT TIME AGAIN... CARS PUT IN HIBERNATION
[Re: ph23vo]
#3087244
10/18/22 06:08 PM
10/18/22 06:08 PM
Posts: 16,546 On the run…
BloFish
On the run…
I could never wait 9 months. But they do say time flys as you get older.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3087271
10/18/22 08:20 PM
10/18/22 08:20 PM
ph23vo
renton, Washington
I could never wait 9 months. But they do say time flys as you get older. SADLY IT DOES FLY...BUT 9 MONTHS IS FOREVER WHEN ITS GRAY AND DARK OUTSIDE.... HOPE TO BE BACK SOUTH BY END OF NEXT SUMMER
[Re: BloFish]
#3087391
10/19/22 07:02 AM
10/19/22 07:02 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Mine usually doesn't get driven unless I have to move it out of the garage. If I have to move it I will go drive it regardless of the temp as long as the roads are clear. I don't like to start it unless I can get it to operating temp. Its amazing how much condensation gets in the motor on a short start in cold weather.
We have crazy winters in Oklahoma, it can be negative temps one week and 70 degrees that weekend. The downside is they salt the roads pretty heavy if we get bad road conditions.
68 Barracuda Formula S 340
[Re: DynoDave]
#3087766
10/20/22 11:42 AM
10/20/22 11:42 AM
Posts: 4,182 here.
Remy-Z
here.
Same here. The weather is getting colder, days are getting shorter. Time to prepare for winter building season. I've got a list on mine that needs to be addressed after a great year of driving. Edit - starting with the blown-out radiator that put the car in the garage about a week early. ![rant rant](/ubbthreads/images/graemlins/custom/rant.gif)
[Re: moparmarks]
#3088163
10/21/22 08:45 PM
10/21/22 08:45 PM
Posts: 21,512 It's a dry heat
gtx6970
It's a dry heat
": WELL ITS THAT TIME AGAIN... CARS PUT IN HIBERNATION"
A phrase members from SoCal will never have to use. Or here either. Drive them all year. I drive mine year round
[Re: ph23vo]
#3088250
10/22/22 08:46 AM
10/22/22 08:46 AM
Posts: 12,305 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Here in southern Illinois, it is hardly a paradise. But today is supposed to be a nearly perfect day, near 80 and sunny. There is a little Mopar oriented get together an hour or so south of us. Several of us will caravan down and spend the day cooking out and talking Mopar and some other things. Just a fun relaxing day with friends. Really looking forward to it.
We are just far enough south that I don't have to put the Cuda in moth balls. Every few weeks through the winter, there is usually a day or so that is warm and dry enough that I can get the Cuda out, drive it a bit, and put some fresh gas in it. Just enough to keep it limbered up and fresh.
Master, again and still
[Re: Big-Bo-Hemoth]
#3088539
10/23/22 12:55 PM
10/23/22 12:55 PM
ph23vo
renton, Washington
I live about 3 hours north of you. On 12 -24-2021 it was a great day, so I took the car out for a 50 mile drive. Perfect. WE SOMETIMES GET SOME GOOD WEATHER...[SEATTLE] I WILL TAKE THEM OUT IF WE HAVE A 3-4 DAY GOOD FORECAST..OTHERWISE THEY STAY HIBERNATED.. TOO MUCH WORK CLEANING THEM TO PUT BACK IN A DAY..YOU GUYS SEEM TO HAVE MUCH MORE INCIDENCE OF NICE WEATHER THAN HERE [OCEANS]
[Re: ph23vo]
#3088551
10/23/22 01:40 PM
10/23/22 01:40 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
I live about 3 hours north of you. On 12 -24-2021 it was a great day, so I took the car out for a 50 mile drive. Perfect. WE SOMETIMES GET SOME GOOD WEATHER...[SEATTLE] I WILL TAKE THEM OUT IF WE HAVE A 3-4 DAY GOOD FORECAST..OTHERWISE THEY STAY HIBERNATED.. TOO MUCH WORK CLEANING THEM TO PUT BACK IN A DAY..YOU GUYS SEEM TO HAVE MUCH MORE INCIDENCE OF NICE WEATHER THAN HERE [OCEANS] I’m two hours east of you on Chinook pass now. 6 car garage and 4 cars. 250ish days of sun but the winter snowfall is normally brutal Jan and Feb.
[Re: Pacnorthcuda]
#3088562
10/23/22 02:33 PM
10/23/22 02:33 PM
Posts: 2,924 Calgary, Alberta Canada
a12rag
I live about 3 hours north of you. On 12 -24-2021 it was a great day, so I took the car out for a 50 mile drive. Perfect. WE SOMETIMES GET SOME GOOD WEATHER...[SEATTLE] I WILL TAKE THEM OUT IF WE HAVE A 3-4 DAY GOOD FORECAST..OTHERWISE THEY STAY HIBERNATED.. TOO MUCH WORK CLEANING THEM TO PUT BACK IN A DAY..YOU GUYS SEEM TO HAVE MUCH MORE INCIDENCE OF NICE WEATHER THAN HERE [OCEANS] I’m two hours east of you on Chinook pass now. 6 car garage and 4 cars. 250ish days of sun but the winter snowfall is normally brutal Jan and Feb. Had a weather pattern change this past Friday night/Saturday morning . . . damn system parked over us, and has DUMPED 20cm (8 inches) of snow on us here. Glad I tucked everything away and been ready for this . . . UGGHHH - worst of it, is that the temp is around 0-2C (32-34F) and it's that damn WET SLOPPY COASTAL type snow - not the light fluffly powder we normally get . . . spent 2hrs shovelling yesterday !! . . . and now for today and rest of next week, temps coming back to normal and sunshine . . .
