Re: 67 - 69 Barracuda battery disconnect
[Re: 4mopower]
#3087272
10/18/22 08:20 PM
10/18/22 08:20 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
Not a great picture, but my disconnect handle comes through on the right hand side just above the bumper. See the red handle - the battery and switch is just inside the trunk on that side. (Push / Pull Switch / Rod combo)
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: EvilB1Dart]
#3087352
10/19/22 01:20 AM
10/19/22 01:20 AM
Posts: 16,550 On the run…
BloFish
On the run…
There is a factory hole here, and that is what I used.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: 19swinger70]
#3088259
10/22/22 10:21 AM
10/22/22 10:21 AM
Posts: 162 Chicago-area Illinois
4mopower
19Swinger70 -
Looks to be enough room between the bumper and tail lamp. I was wondering that. Thanks for the pic.
[Re: BloFish]
#3088260
10/22/22 10:25 AM
10/22/22 10:25 AM
4mopower
BloFish - Is there enough room to get your hand in between the bumper? I currently do not have the bumper mounted.
Thanks.
[Re: 4mopower]
#3088280
10/22/22 11:28 AM
10/22/22 11:28 AM
BloFish
On the run…
Thanks. Yes, it is just below the bumper. I use the Moroso cut off switch.
[Re: 4mopower]
#3088400
10/22/22 09:04 PM
10/22/22 09:04 PM
Posts: 276 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Dumb question, but does anyone know if the switch must be labeled? So far it hasn't been an issue for me, but just trying to stay out in front of anything
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: metallicareload]
#3088491
10/23/22 08:04 AM
10/23/22 08:04 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
Dumb question, but does anyone know if the switch must be labeled? So far it hasn't been an issue for me, but just trying to stay out in front of anything It is supposed to be. Mine is not and sometimes that gets mentioned in tech. I usually write PUSH with a sharpie on the bumper about once a year and it makes them happy. Maybe someday I will put a sticker on there.
68 Barracuda Formula S 340
