Dorman steering coupler issues ??? #3086672
10/16/22 09:59 PM
10/16/22 09:59 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
The mopar ones have dried up.
And now i need one.
Ive heard the dorman brand is junk?
So what exactly is wrong with them
Re: Dorman steering coupler issues ??? [Re: gtx6970] #3086965
10/17/22 08:06 PM
10/17/22 08:06 PM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
I've had some Dorman lug nuts and studs and they have been ok.
inherited a 69 roadrunner from my grand pop.
Re: Dorman steering coupler issues ??? [Re: gtx6970] #3087030
10/18/22 01:30 AM
10/18/22 01:30 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Did you ask Mr. Google? He says there are some Mopar ones out there. Also NAPA, eBay.
Would help to know power or non-power, model, year...
Re: Dorman steering coupler issues ??? [Re: gtx6970] #3087275
10/18/22 08:36 PM
10/18/22 08:36 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Hey Bill
So I was thinking about making the coupler kits once the Mopar ones dried up. I had a dozen columns and couplers of various years. So I pulled them all apart. Even bought a press to push the pin outta the shaft. Bought some EXPENSIVE name brand micromerters and inside micromerters.
What I found out over the dozen couplers I pulled apart was that all were within like +/- .0003", THREE TENTHS! Same as the 40 NEW Mopar kits I had at the time.
Other thing I relized is I'd have to find a damn good company to be able to make the pin that goes in the shaft to +/-.0001" Then be able to bore/broach the hole in the "shoes" +/- .0001 I didn't want to go down that road.
I'd bet most couplers (all the ones I had) would just need a good cleaning and filled with grease (why didn't Mopar add a zerk fitting?).
I measured the Dorman parts and they were sloppier than any old 60's coupler parts I had by a factor of 10 or worse. Just toltal garbage. Even the spring that spreads the shoes didn't fit THIER shoes. ZERO quality control.
Scammers are selling Dorman pieces a "genuine" Mopar pieces on Ebay. All the Mopar kits are GONE or for sale for a BUNCH of $.
Mopar Coupler Rebuild Kit On Ebay
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Dorman steering coupler issues ??? [Re: 71TA] #3087339
10/18/22 11:30 PM
10/18/22 11:30 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Jim,
Problem is. this car has play inside the coupler. I havent pulled it apart yet to see what is loose.
But no amount of clean and pack with grease is gonna fix this one Im afraid
Re: Dorman steering coupler issues ??? [Re: kentj340] #3087340
10/18/22 11:32 PM
10/18/22 11:32 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
1966 B body power steering. But the shoes and insides of the coupler are no different than say a 1994 truck . via it power or manual
Re: Dorman steering coupler issues ??? [Re: gtx6970] #3087404
10/19/22 08:41 AM
10/19/22 08:41 AM
MetroWest, MA.
BeeOrange Offline
BeeOrange  Offline
MetroWest, MA.
I bought a coupler from Steer and Gear in Columbus Ohio. The have a redesign for the firewall facing seal. Nice product.
70 Super Bee FK5 383 4-Speed
68 GTX RR1 426 Auto
70 Cuda FC7 440 Auto
Psalm 37:5: Commit your way to the Lord; trust also in Him and He will do it
Re: Dorman steering coupler issues ??? [Re: gtx6970] #3087413
10/19/22 09:35 AM
10/19/22 09:35 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Originally Posted by gtx6970
Jim,
I know you are VERY capable, but where is the wear? That coupler is such a POS design. Everyone replaces the guts but how well does all that fit in the CRUDE, stamped coupler body. There could be a better design. Same pin through the steering shaft but with rollers bearing wheels that ride up and down in CNC machined slots and a screw on cap with o-ring seal. And a zerk smile
I'd grab that one off Ebay. Cheapest I've seen an Mopar set.
Re: Dorman steering coupler issues ??? [Re: 71TA] #3087445
10/19/22 11:34 AM
10/19/22 11:34 AM
Lakewood, WA
rick@laysons Offline
Lakewood, WA
Re: Dorman steering coupler issues ??? [Re: rick@laysons] #3087537
10/19/22 04:56 PM
10/19/22 04:56 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have a couple of the mopar ones 4443436AC if you still need them. Mine have the orange boot .
Re: Dorman steering coupler issues ??? [Re: mopars4ever] #3087906
10/20/22 08:03 PM
10/20/22 08:03 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
pm me details
Re: Dorman steering coupler issues ??? [Re: gtx6970] #3088023
10/21/22 10:47 AM
10/21/22 10:47 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
And now i need one.
Bill have you taken yours apart yet?? If you see play there is always the chance someone installed the shoes wrong which would cause that.
Ron
Re: Dorman steering coupler issues ??? [Re: RJS] #3088162
10/21/22 08:42 PM
10/21/22 08:42 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Not yet.
Thats the plan for this weekend.
I have all my cooling system parts and goal is get it running driving this weekend
I want to take it to Phoenix next weekend for a show in Glendale
