Page 2 of 4 1 2 3 4
Re: "Detonation problems" rebuild 440-6 [Re: Mr.Yuck] #308621
05/06/09 11:14 AM
05/06/09 11:14 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Assuming 4.350 bore , stock correct length rods , 7 cc for valve reliefs , .300 down to the top ring , 4.410 bore I get 10.43 ...
Using a steel shim it would have been 10.89 , so I'd have to agree with your local guru a bit on that , but since you might have to mix anyway I would have opted for the higher ratio and good quench , rolled the timing back a little on the street
cross your fingers
Re: "Detonation problems" rebuild 440-6 [Re: JohnRR] #308622
05/06/09 11:17 AM
05/06/09 11:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
cross your fingers
I can always put the steels in, I have a set on the shelf. I'm goint to start the timing at 35* and go form there.
Re: "Detonation problems" rebuild 440-6 [Re: Mr.Yuck] #308623
05/06/09 11:25 AM
05/06/09 11:25 AM
JohnRR Offline
JohnRR  Offline
I just said screw it on my 383 stroker build since I was going to have to mix anyway, good quench or not, and upped the compression from 11.4 to 12.5 ...
Re: "Detonation problems" rebuild 440-6 [Re: JohnRR] #308624
05/06/09 02:44 PM
05/06/09 02:44 PM
Sweden
6pakdude Offline OP
6pakdude  Offline OP
Sweden
Checked the cylinder pressure after work today.
Cold engine 170psi.
Is this to muck for my voodoo cam? If so what head gasket should I use to lower the pressure/comp ratio.
Have located colder plugs here in Stockholm, I gonna buy a set this weekend, Accel 124 should be one colder step then the champion plug.
(I might have the wrong number of the plugs, forgot the note at work.
Peter
Re: "Detonation problems" rebuild 440-6 [Re: 6pakdude] #308625
05/06/09 02:56 PM
05/06/09 02:56 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
You have a lot of cylinder pressure there, but not too much. You have no quench, but that should not be an issue. You ned to add fuel, as you suspect. You should get the Pro Max metering plates that will use standard jets to adjust the outboard mixtures. I seem to recall that Euro 98 is about the same as our 93. So it's not octane. i think you're lean as you think. So instead of rebuilding the engine, give it the fuel it wants. You should NOT be running that engine until you figure it out. KBs and pinging are NOT GOOD at all. Also, you should be able to go to the purple springs in your outboard vacuum pods after you get some jet in it. What is you timing curve? You should be around 15° initial, and total around 36° with it all in somewhere around 3K.
Re: "Detonation problems" rebuild 440-6 [Re: moper] #308626
05/06/09 03:37 PM
05/06/09 03:37 PM
Sweden
6pakdude Offline OP
6pakdude  Offline OP
Sweden
Before I asked this question on moparts. I decided to try to shorten the slots in the distributor. before 2x10 degree, now 2x7. used epoxy so it's easy to remove.
So timing and curve of today is inital 16 w vacum, total 30. full timing comes at 2300 RPM.
Havn't run this combo yet, because of rain ,hopefully this weekend.
I drive the car, but not going over 4500 RPM until problem sorted out.
Yes thats my thoughts to, using those billet plates from ProMax, because of the cost I need to know that it solves my problem.
I have long yellow springs in the vac pods.
Thanks peter
Re: "Detonation problems" rebuild 440-6 [Re: moper] #308627
05/06/09 04:27 PM
05/06/09 04:27 PM
JohnRR Offline
JohnRR  Offline
Dave , I have seen KB spec a max of 34* total ???
Edit I just reread your first post , I'm with moper it sounds like you are too lean .
Re: "Detonation problems" rebuild 440-6 [Re: 6pakdude] #308628
05/06/09 04:30 PM
05/06/09 04:30 PM
JohnRR Offline
JohnRR  Offline
Thanks peter
Peter , the Pro Max plates allow you to use standard holley jets to change jet size to richen or lean out as needed , right now the plates in those outboards just have a drilled hole , you can drill the hole bigger as needed, but it's not easy to undo if you go to big .
Re: "Detonation problems" rebuild 440-6 [Re: JohnRR] #308629
05/06/09 05:21 PM
05/06/09 05:21 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
John, the pistons will take whatever the engine can, right up until it pings. With all the variables involved in mass production pistons and a thousand things that could go wrong that are not KB's fault, I think it's one of those "Publish it so we have an out" when something does go wrong that is not thier problem. They can take a little detonation and ping, but on a fresh build... I cringe at audible ping.
Re: "Detonation problems" rebuild 440-6 [Re: 6pakdude] #308630
05/06/09 07:11 PM
05/06/09 07:11 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Cold engine 170psi.
No. But everything needs to be right.
Re: "Detonation problems" rebuild 440-6 [Re: BSB67] #308631
05/06/09 07:28 PM
05/06/09 07:28 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
It's leaning out for some reason. High RPM ping is lean low rpm is compression / cam / fuel.
My gut feeling is the vacuum carbs are not coming open???
Re: "Detonation problems" rebuild 440-6 [Re: BSB67] #308632
05/06/09 08:12 PM
05/06/09 08:12 PM
dulcich Offline
dulcich  Offline
I doubt your problem is detonation, do yourself a favor and figure out what all that racket you hear up top really is. I would suspect that you'll hear the same "detonation" on race gas. Try it.
-dulcich
Re: "Detonation problems" rebuild 440-6 [Re: dulcich] #308633
05/07/09 01:17 AM
05/07/09 01:17 AM
Sweden
6pakdude Offline OP
6pakdude  Offline OP
Sweden
Have had a paperclip on the rod to the vacumpod, to see if it opens, it does.
Last year tried the purple spring, it didn't open.
Might thou be a different story this year with more comp and vacum.
Anyone have a recommendation what size jet in front and rear carb to use for my engine.using the Promax plates
Those metering plates I use right now, does anybodt know what size they are. Same for the stock plates.
Accel 124 should be a step colder than the champ12
Peter
Re: "Detonation problems" rebuild 440-6 [Re: 6pakdude] #308634
05/07/09 01:46 AM
05/07/09 01:46 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Secondary metering plates are identified by the number stamped into them... This chart gives you main jet sizes plus idle jet size & the full holley part numbers...
http://www.junkyardgenius.com/holley/2ndplates.html
Re: "Detonation problems" rebuild 440-6 [Re: 1_WILD_RT] #308635
05/07/09 02:12 AM
05/07/09 02:12 AM
Sweden
6pakdude Offline OP
6pakdude  Offline OP
Sweden
Wild R/T thanks
If I Understand the chart, the stock metering plates 34R-6153-35. means size 35 0,071" jet size ? or
But the plates 34R-9716B
34R-5113B
How do I decode that number.
Or do I have to look for a stamped number on all plates.
peter
Re: "Detonation problems" rebuild 440-6 [Re: 6pakdude] #308636
05/07/09 02:24 AM
05/07/09 02:24 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I looked but couldn't find a good image, the raised number isn't the one you need, the two digit stamped number is the identifying number...
Re: "Detonation problems" rebuild 440-6 [Re: 6pakdude] #308637
05/07/09 02:25 AM
05/07/09 02:25 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I got this chart from Promax.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: "Detonation problems" rebuild 440-6 [Re: 70sixpkrt] #308638
05/07/09 02:27 AM
05/07/09 02:27 AM
70sixpkrt Offline
70sixpkrt  Offline
The left is Promax chart and the right is out of the Speed Secret Mopar Engine book.
4-speed
3:54 Dana
Re: "Detonation problems" rebuild 440-6 [Re: 70sixpkrt] #308639
05/07/09 02:29 AM
05/07/09 02:29 AM
70sixpkrt Offline
70sixpkrt  Offline
Hopefully this comes out clearer.
4-speed
3:54 Dana
Re: "Detonation problems" rebuild 440-6 [Re: 70sixpkrt] #308640
05/07/09 02:32 AM
05/07/09 02:32 AM
70sixpkrt Offline
70sixpkrt  Offline
I am using 65 jet in the center and 80s on all 4 corners.
4-speed
3:54 Dana
Page 2 of 4 1 2 3 4
