Any F Body Experts? Manual to Power Brakes in a Volare
#308594
05/05/09 02:16 PM
05/05/09 02:16 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I want to convert my 80 Volare from manual to power brakes. The power booster is still available with a master cylinder. Does anyone know if this is a direct bolt in for the manual brake setup? I have 2 concerns 1) is the proportioning valve the same and 2) is there any difference in the brake pedal setup will the rod from the booster bolt right up to the existing brake pedal.
Thanks Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
Re: Any F Body Experts? Manual to Power Brakes in a Volare
[Re: nomore65BelvJim]
#308598
05/05/09 10:36 PM
05/05/09 10:36 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
I thought all F body cars came standard with power brakes I know discs were standard
From '76 brochure: Manual front disc brakes are standard on coupes and sedans; power front disc brakes are standard on wagons and models with V8 engines, optional on models with /6 engines.
[Re: finadk]
#308600
05/06/09 12:42 AM
05/06/09 12:42 AM
finadk
East Brunswick, NJ
This Volare has the leaning tower of power, so I guess power brakes were an option the original owner omitted (along with AC and just about everything else).
I ordered the booster with the MC from rock auto and the picture shows the pushrod. I will see what I get. I have a used setup I pulled from a 81 Cordoba so I should have another rod if it does not come with it, if not I will go for the adjustable one everything I need.
Thanks, Scott
Scott
1976 Corvette
