850XP Holley good for 508" RB? #3085400
10/12/22 12:10 PM
10/12/22 12:10 PM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
I'm getting close to having all my parts after 6 months of ordering and waiting for parts to arrive. Most people tell me I'll need a 950 or bigger. But on these forums I see some saying they are using an 850 with good results with a similar size engine.
Quick summary of my build. 440 block, .040 over. ~10.5 to1 compression expected. 4.25 stroke, 6.8 rods. Trickflow trackheat intake ported. Trickflow 270 heads. Jones or Bullet hydraulic roller cam. (Got one from each, long story.) Cam will likely be 253/260 @.050", .390"/.390" Lobe Lift, .624"/.624" Valve Lift, 114 LSA. TTi 2 1/8th step headers. MSD billet distributor w/6AL. Car is a 1969 GTX, ~4000lbs. Dana 60 4.10 and hemi 4-speed.
Thoughts on this carb meeting the need?
Re: 850XP Holley good for 508" RB? [Re: GTXMEX] #3085404
10/12/22 12:13 PM
10/12/22 12:13 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
you need to look at venturi size on the carbs, as some of the old 850's are actually a larger venturi than the 950 carbs.
for example, are you talk about an 850 carb with a 1.53" venturi vs. a 950 carb with a 1.45" venturi?
Re: 850XP Holley good for 508" RB? [Re: krautrock] #3085412
10/12/22 12:22 PM
10/12/22 12:22 PM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
Re: 850XP Holley good for 508" RB? [Re: GTXMEX] #3085416
10/12/22 12:28 PM
10/12/22 12:28 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
QF 4150 1050AN
Re: 850XP Holley good for 508" RB? [Re: krautrock] #3085419
10/12/22 12:32 PM
10/12/22 12:32 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Exactly!!!
The 1050/4150 is a 1.59. Other than that an old 1.53 850 would be my choice. It’ll handle a big carb. Hell I run a 1050 1.69 Venturi dominator on my 500 ci 4000# street car at times. Works well.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: 850XP Holley good for 508" RB? [Re: GTXMEX] #3085424
10/12/22 12:46 PM
10/12/22 12:46 PM
WI
mopar873 Offline
mopar873  Offline
WI
I think that'll be a very strong combo with great throttle response. Should be a blast to drive.....definitely going to find any weakspots in the drivetrain
Re: 850XP Holley good for 508" RB? [Re: GTXMEX] #3085425
10/12/22 12:47 PM
10/12/22 12:47 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
You went with ported 270's...You will want the 950 or a 1050 in a 4150 carb.......850 is too small. The Proform Race series are almost perfectly calibrated to this type of combo and I highly recommend one of those or a Thumper carb if budget allows.
Re: 850XP Holley good for 508" RB? [Re: Dragula] #3085434
10/12/22 01:19 PM
10/12/22 01:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
What use will the car see ? For mainly street, the smaller carb could likely be smoother off-idle and cruising.
If it'll see the track - for which the build seems targeted - it'll want more CFM; I'd be thinking 1050 or so.
Either way, at that weight with a stick and good hook, you're likely to find what parts of the drivetrain become consumables...
Re: 850XP Holley good for 508" RB? [Re: topside] #3085437
10/12/22 01:28 PM
10/12/22 01:28 PM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
This is and will be a street/strip car. Will need good street manners as will go to car events, light to light fun, and occasional strip visits. I'd expect it to be a strong street bruiser. BTW, I also in the past have run up to a 15 shot of NOS. Will have it but likey not use it as won't be able to build another engine in this life time. :-)
Re: 850XP Holley good for 508" RB? [Re: GTXMEX] #3085441
10/12/22 01:37 PM
10/12/22 01:37 PM
AndyF Online content
AndyF  Online Content
That 850 should work just fine. Those XP carbs are very nice to work with. For max power you could go larger but it might not drive as nice. For street driving I'd use a really nice 750 carb but it will give up a little bit of top end power. If you are computer savvy you should consider a Holley Sniper EFI setup since it will do a lot more for you for not much more money. But if you aren't computer savvy then don't bother since it is easy to get lost in an EFI conversion.
Re: 850XP Holley good for 508" RB? [Re: GTXMEX] #3085453
10/12/22 01:53 PM
10/12/22 01:53 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Nice components, questionable out-of-the-box tune
My suggestion is to join this forum, then do some searches and/or ask questions on that particular carb model: http://racingfuelsystems.com/viewforum.php?f=5
What are the specs of both cams? I gotta say the 114 LSA for that combination strikes me as... odd.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: 850XP Holley good for 508" RB? [Re: Brad_Haak] #3085456
10/12/22 02:08 PM
10/12/22 02:08 PM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
Thanks for sharing that forum. I will check it out. The 114 is to help with power brakes and I've heard the wider spread can help with NOS?
Bullet cam specs are Intake
248 @.050”
.382” lobe lift, .573 with 1.5 rocker
300 duration @.006”
Exhaust
254 @.050”
.380” lobe lift, .570” with 1.5 rocker
310 duration @.006”
113 lobe separation
109 intake centerline
Re: 850XP Holley good for 508" RB? [Re: GTXMEX] #3085466
10/12/22 02:23 PM
10/12/22 02:23 PM
Dragula Offline
Dragula  Offline
Seems like your not convinced....We run an old 512 with ported iron heads and 2.14/1.81 valves with a .560" lift cam and no duration.....We run a 1050 on it in the street class....It would run out of leg before 5000rpm until we switched. And get this, our nice little street car with 3.91 gears, no convertor and 512 runs 10.76 in the 1/4 at 125mph....Its an unreal little sleeper.
Re: 850XP Holley good for 508" RB? [Re: Dragula] #3085475
10/12/22 02:36 PM
10/12/22 02:36 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Q's for the OP:
Are your tracks 1/8th mile or 1/4?
How tall are your rear tires?
How much RPM are you expecting to turn?
You've driven a stick car on the bottle before?
Re: 850XP Holley good for 508" RB? [Re: Brad_Haak] #3085477
10/12/22 02:42 PM
10/12/22 02:42 PM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
No I'm convinced a larger carb is the way to go. Seems like based on some feedback I could get away with using the 850, but would leave a lot on the table. Looking to stick with a 4150 model to work with the ported intake. Like your list in your profile. Clear you have a lot of experience. Thank you!
Re: 850XP Holley good for 508" RB? [Re: Brad_Haak] #3085479
10/12/22 02:44 PM
10/12/22 02:44 PM
California
GTXMEX Offline OP
GTXMEX  Offline OP
California
1/8th mile. 28' tall, 10.5 inch Mickey Thompsons. I've just gotten into 4th in the 8th in the past. Yes, have run NOS with my stick for over 20 years.
Re: 850XP Holley good for 508" RB? [Re: GTXMEX] #3085501
10/12/22 03:26 PM
10/12/22 03:26 PM
I did a lot of carb size testing back in the early 1990s when I wanted to race in NHRA S/ST class with a stock bore and stroke 440 motor in a lightweight Duster (2800 Lbs. with driver boogie) with ladder bars and leaf springs on a floater kit.
I started off with Holley 650 D.P. thinking it would 60 ft. better with the smaller carb to make the reaction times better, WRONG. I ended up going to a 750 D.P. then a 850 D.P. then a 950 HP D.P. and finally ended up with changing the intake for a single List # 9375 1050 Dominator CFM non-HP carb.
My message is the more air and fuel I fed it the faster and quicker it went boogiework
I've seen the same thing on engine dyno testing on BB Mopar stroker motors and stock stroke 440 motors, I could NOT[ over carb them rascals shruggy work
I would try your carb first and see if you want the car to go faster after max tuning that combination. twocents scope up
What are the cam specs on the other cam? 114 LSA is way too wide for most single carb non race only motors in my opinion twocents work
BTW, is this a race car, street and strip or street only car?
I used to have a dyno only motor I used for testing, it was a 440 block bored to 4.380 with a 4.375 stroke, one of the last dyno test I did on that motor was swapping the Indy 440-3 intake with a Holley 1050 CFM Dominator carb to a tunnel ram intake and two Holley 1050 CFM carbs, that combination made 30 more HP at peak RPM than the single carb set up did shruggy
BB Mopars motors like more air and fuel for WOT driving boogie
Be careful please luck
Re: 850XP Holley good for 508" RB? [Re: GTXMEX] #3085545
10/12/22 05:40 PM
10/12/22 05:40 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
OK; I was wondering how high you were gonna have to rev it, considering hydraulic rollers have the rep of not handling high RPM well.
If you're putting the emphasis on performance while spraying, then the wide LSA makes more sense. But if NA is the primary mode and nitrous is less frequent, then IMO it's too wide for best NA use.
Re: 850XP Holley good for 508" RB? [Re: GTXMEX] #3085555
10/12/22 06:51 PM
10/12/22 06:51 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Not an answer to your question, but a radiused exit directly below the carburetor's mounting surface will always raise CFM.
A 3/8" thick plate (matching the base flange) with sized holes matching the throttle plates, and 3/8" radius leading from each bore into the manifold improves the flow discharge coefficient.
Boffin Emeritus
Re: 850XP Holley good for 508" RB? [Re: Cab_Burge] #3085603
10/12/22 10:02 PM
10/12/22 10:02 PM
Mo.
racerx Offline
racerx  Offline
Mo.
BB Mopars motors like more air and fuel for WOT driving.
I had a 60 over 440 years ago with a set of stock Hughs stage 3 ported 906's with one of their cam shafts the cam shaft was the HEV56 I believe any long story short the engine would run on the lean side with a 750 DP. Switch to a 1050 Dom and all was good up never made the car any faster i think the extra fuel cool the combustion chambers.
