old Keith Black HEMI-engine: which shop for build?
#3084801
10/10/22 11:43 AM
10/10/22 11:43 AM
Posts: 91 good ol' Germany
TobiasM
good ol' Germany
Hi fellows,
I’ve been offered an old Keith Black 426-HEMI-block, that needs works (checking measurements, machining, boreing, honeing, new sleeves).
Which shop is the most competent on these old KB-blocks, so that they can build me a complete engine out of it?
Is it “go back to the source” and is the NEW KB-company best choice (do they still care about their old stuff?)?
Or is an independent shop the place to go, like Ray Barton, Bob Mazzolini, Marsh, Arruzza or Mancini?
Thanks for your advice!
EDIT: or Mr. „SixPak“ Karakashian or FHO ( Tim Banning).
Thanks and best regards,
Toby
Re: old Keith Black HEMI-engine: which shop for build?
[Re: elmor353]
#3085047
10/11/22 09:37 AM
10/11/22 09:37 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
There are many variations of "old Keith Black blocks". I assume you have made sure it's compatible with your application. And I agree with the earlier post, I would call Ray Barton.
2011 Drag Pak Challenger
[Re: rickseeman]
#3085052
10/11/22 10:01 AM
10/11/22 10:01 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
There are many variations of "old Keith Black blocks". I assume you have made sure it's compatible with your application. And I agree with the earlier post, I would call Ray Barton. There's a whole lotta old junk floating around for sale. Depending on how old it is, it could be a can of worms depending on application. I would NOT suggest dealing w/ "KB".
[Re: an8sec70cuda]
#3085057
10/11/22 10:08 AM
10/11/22 10:08 AM
TobiasM
good ol' Germany
Thanks for your replies, Gentlemen!
Added 2 more specialists: Mr. „SixPak“ Karakashian and FHO (Tim Banning).
@block-specs: it is an early block, meaning only 4-bolt-mains, not 6-bolts, blocknumber is below #1000, has 2 windows/repairs, it is a water-block, both heads & block are aluminum, intended use is a street-car.
Toby
[Re: TobiasM]
#3085062
10/11/22 10:31 AM
10/11/22 10:31 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
@block-specs: it is an early block, meaning only 4-bolt-mains, not 6-bolts, blocknumber is below #1000, has 2 windows/repairs, it is a water-block, both heads & block are aluminum, intended use is a street-car. Call FHO
[Re: TobiasM]
#3086415
10/16/22 02:17 AM
10/16/22 02:17 AM
Posts: 4,728 Moved to N.E. Tennessee
GomangoCuda
Your in Germany? Is it worth shipping an old beat up block to the U.S. and back to Germany? That must be very expensive.
[Re: GomangoCuda]
#3086533
10/16/22 03:09 PM
10/16/22 03:09 PM
TobiasM
good ol' Germany
No, block is in the US...otherwise you were right and it would make even less sense economically ;-)
Toby
