old Keith Black HEMI-engine: which shop for build? #3084801
10/10/22 11:43 AM
10/10/22 11:43 AM
good ol' Germany
TobiasM Offline OP
TobiasM  Offline OP
good ol' Germany
Hi fellows,
I’ve been offered an old Keith Black 426-HEMI-block, that needs works (checking measurements, machining, boreing, honeing, new sleeves).
Which shop is the most competent on these old KB-blocks, so that they can build me a complete engine out of it?
Is it “go back to the source” and is the NEW KB-company best choice (do they still care about their old stuff?)?
Or is an independent shop the place to go, like Ray Barton, Bob Mazzolini, Marsh, Arruzza or Mancini?
Thanks for your advice!
EDIT: or Mr. „SixPak“ Karakashian or FHO ( Tim Banning).
Thanks and best regards,
Toby
Re: old Keith Black HEMI-engine: which shop for build? [Re: TobiasM] #3084878
10/10/22 03:10 PM
10/10/22 03:10 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
The first name that popped into my head was Ray Barton.
Re: old Keith Black HEMI-engine: which shop for build? [Re: elmor353] #3085047
10/11/22 09:37 AM
10/11/22 09:37 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
There are many variations of "old Keith Black blocks". I assume you have made sure it's compatible with your application. And I agree with the earlier post, I would call Ray Barton.
2011 Drag Pak Challenger
Re: old Keith Black HEMI-engine: which shop for build? [Re: rickseeman] #3085052
10/11/22 10:01 AM
10/11/22 10:01 AM
an8sec70cuda Offline
iagree There's a whole lotta old junk floating around for sale. Depending on how old it is, it could be a can of worms depending on application. I would NOT suggest dealing w/ "KB".
CHIP
'06 GMC 2500HD LBZ Duramax
Re: old Keith Black HEMI-engine: which shop for build? [Re: an8sec70cuda] #3085057
10/11/22 10:08 AM
10/11/22 10:08 AM
good ol' Germany
TobiasM Offline OP
TobiasM  Offline OP
good ol' Germany
Thanks for your replies, Gentlemen!
Added 2 more specialists: Mr. „SixPak“ Karakashian and FHO (Tim Banning).
@block-specs: it is an early block, meaning only 4-bolt-mains, not 6-bolts, blocknumber is below #1000, has 2 windows/repairs, it is a water-block, both heads & block are aluminum, intended use is a street-car.
Toby
Re: old Keith Black HEMI-engine: which shop for build? [Re: TobiasM] #3085062
10/11/22 10:31 AM
10/11/22 10:31 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Call FHO
Re: old Keith Black HEMI-engine: which shop for build? [Re: TobiasM] #3086415
10/16/22 02:17 AM
10/16/22 02:17 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Your in Germany? Is it worth shipping an old beat up block to the U.S. and back to Germany? That must be very expensive.
Re: old Keith Black HEMI-engine: which shop for build? [Re: GomangoCuda] #3086533
10/16/22 03:09 PM
10/16/22 03:09 PM
good ol' Germany
TobiasM Offline OP
TobiasM  Offline OP
good ol' Germany
No, block is in the US...otherwise you were right and it would make even less sense economically ;-)
Toby
Re: old Keith Black HEMI-engine: which shop for build? [Re: TobiasM] #3086543
10/16/22 03:21 PM
10/16/22 03:21 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Ray Barton
Abe Lincoln
