tiei down car #3084866
10/10/22 02:49 PM
10/10/22 02:49 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
When towcar in trailer I have always been told to put in neutral while towing.why not park leave in neutral while tie down when everything is tied just put in park to help keep in place. I head of a lot of car coming lose in trailers this year and doing lots of damages I would think this would help I know they say it puts presure on park pin but it tie down it should not move that much. In your street car or truck you park on a big hill and it don't hurt them with that weight. What is real reason? THANKS
Re: tiei down car [Re: dragon] #3084875
10/10/22 03:00 PM
10/10/22 03:00 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
I always put mine in park because I know someone who had one in neutral and a tiedown came loose and it caused damage to the car.
I don't see what damage can be done, if its tied down right it won' be an issue. If its not tied down right you will be glad it was in park.
The procedure my dad and I use with an enclosed is to winch the car in, strap it down, then lastly put it in park.
68 Barracuda Formula S 340
Re: tiei down car [Re: Bad340fish] #3084877
10/10/22 03:09 PM
10/10/22 03:09 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Do what you feel comfortable with. With a stick car, mine is always in neutral. 4 heavy straps, and I keep tension on the winch cable as well. We check straps every single time we get off the road for something.
69 GTX 68 Road Runner
Re: tiei down car [Re: JERICOGTX] #3084882
10/10/22 03:31 PM
10/10/22 03:31 PM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
I'm about to send a car 50 miles away for metal work - no motor, transmission, or e-brake. I waver between worrying and thinking if something goes wrong putting the car in park or in gear isn't likely to help anything. It's either strapped down right or it's not.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: tiei down car [Re: dragon] #3084896
10/10/22 04:29 PM
10/10/22 04:29 PM
I've tow a lot of different cars on open trailers, car hauler trucks and enclosed race trailers. I used to use only two tie downs until we wrecked and totaled 1969 Hemi GTX on a borrow open trailer with one tie down on the front and rear. The rear tie down (dog chain size tie down realcrazy) chain broke when I slammed the brakes on my pickup very hard after hitting a dog that ran out in front of my 1/2 ton pickup truck, the car ran up and over the front tire stops and onto the back of my pickup and then flip over onto its roof totaling it puke whiney
I now use 4 5000 Lb. rated ratchet tie downs, one on each corner, and make them tight as I can get them, if I'm going more than 30 miles I try to stop after 50 miles or more and retighten the rear ones around the rear axle to remove any slack in them from rocking, normally one to two more clicks and then they stay tight no matter if I tow it another 100 to 800 miles up
I leave it in neutral and i back off the winch line to get slack on the cable, so I don't trip on it when I go in to untie the tie downs to unload the car wrench I use to leave the winch line tight until I wore out one winch from the rocking the gears in it when stopping and starting forward again in traffic. That tore up the gears in that winch whiney realcrazy, No more problems since loosening them up a little up scope twocents
Re: tiei down car [Re: Bob Stinson] #3084928
10/10/22 06:15 PM
10/10/22 06:15 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
In case of an accident you're probably right, but I've seen lots of clowns through the years just tow the car in park (no straps)
So park must be doing something!
Re: tiei down car [Re: dizuster] #3084936
10/10/22 06:58 PM
10/10/22 06:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've never had a problem with an AT car in Park - stick cars I usually use E-brake - towing literally across the Country.
Worked for a guy who would use E-brake & neutral on AT cars, never an issue either.
Never less than 4 proper ratcheting tie-downs, crossed left/right at both ends - TIGHT, and checked from time to time - plus the winch cable.
Nothing's moved yet (in many thousands of miles), and some of those cars were worth more than my home (as in Pebble Beach Concours).
Main thing is the car doesn't move back or forth, or for that matter side to side, hence the crossed tie-downs.
Whether I'm towing locally or across the US, same tie-down method, as I've had to avoid some real idiocy and/or junk road surfaces.
Best tie-downs in the world are Mac's, though I've used arguably lesser ones.
Re: tiei down car [Re: topside] #3084954
10/10/22 07:43 PM
10/10/22 07:43 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
I always have my car in park when it's on the trailer. No problems thus far. I use an over-the-wheel strap on each wheel, anchored at 3 spots per tire into e-track.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: tiei down car [Re: DynoDave] #3085004
10/10/22 10:55 PM
10/10/22 10:55 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I put mine in Park because my trans guy said to.
Re: tiei down car [Re: slantzilla] #3085005
10/10/22 10:55 PM
10/10/22 10:55 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I put mine in park because it just makes sense.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: tiei down car [Re: BloFish] #3085023
10/11/22 07:33 AM
10/11/22 07:33 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
We always have our cars in park. Never had an issue with doing it this way. I look at it this way, if a strap would happen to break or come loose, if the car is in park it may help prevent extra damage.
Re: tiei down car [Re: DusterKid] #3085030
10/11/22 08:50 AM
10/11/22 08:50 AM
an8sec70cuda Offline
I always put mine in park also. Never had an issue. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: tiei down car [Re: an8sec70cuda] #3085060
10/11/22 10:13 AM
10/11/22 10:13 AM
A727Tflite Offline
A727Tflite  Offline
The only risk of towing in park is if the roads cause the car to rock for and aft from suspension compressions.
Undulating roads. As long as the car doesn’t go through those conditions you should be good.
At Chrysler we learned that pretty quick. Railcars and some trailers were notoriously known for this condition. We eventually had to transport them in neutral with the IOD connector pulled.
Result of this towing in park was broken or cracked extension housings. Back in the 90’s.
Always place in park last after setting the emergency brake. While criss crossing the tie downs is best to keep the car from moving side to side on the trailer, it does offer more fore and aft movement.
I wonder if some guys cracked extension housings and blamed it on some other event. shruggy
Re: tiei down car [Re: A727Tflite] #3085095
10/11/22 12:16 PM
10/11/22 12:16 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
my twocents
I always tow in neutral, Un crossed straps and winch loose... never an issue.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: tiei down car [Re: W.I.N. Racing] #3085147
10/11/22 02:51 PM
10/11/22 02:51 PM
I don't cross my tie downs anymore, I do make them pull on the car's K member and rear end towards the outside edge of the trailer where the tie down hooks are to make sure the car won't slide either way while I'm going through corners and same thing on front to rear movements wrench :: up:
Re: tiei down car [Re: Cab_Burge] #3085226
10/11/22 07:42 PM
10/11/22 07:42 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
I think what op is saying is do you put it in park before or after you strap it down ?
Fwiw only time I had any issue was when I forgot to put it in park. Came loose , I hit the brakes and thought I got rear ended. Ruined both bumpers , toolbox and trailer door. Hard lesson learned.
Re: tiei down car [Re: Wirenut] #3085286
10/11/22 11:15 PM
10/11/22 11:15 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Keep it in neutral until strapped down tight, then place it in park. up
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: tiei down car [Re: BloFish] #3085297
10/12/22 12:36 AM
10/12/22 12:36 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've always towed mine in neutral, even with an open trailer. The chassis car had glass doors with lexan windows and I would winch it in and out with the door on, So I couldn't get to the shifter.
Use good tie downs and tie it down right. I'm not sure being in park would do a whole lot to keep it in one spot if it did get loose.
Re: tiei down car [Re: CMcAllister] #3085341
10/12/22 09:49 AM
10/12/22 09:49 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
i have seen one car get jammed in park after a tow , when i had steel doors and roll up windows i would put in park after i pulled the straps tight. Now i have glass doors and lexan windows. So yea i winch it in, tie it down and its still in neutral. However i have been chocking the wheels in case it does get loose. But as mentioned before, i have added opening the trailer door and peek inside to my fuel stop routine. Cant check things too many times!
....BAD A$$ STREET CAR.....
Re: tiei down car [Re: n20mstr] #3085363
10/12/22 10:40 AM
10/12/22 10:40 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I winch mine in. Leave in neutral. Leave winch cable on front tow hook. Add rear straps and tighten winch until rear straps are tight. Never have to loosen ot adjust rear straps this way (for my car anyway). Add front straps and tighten them. Put in park.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
