Pistol grip ID #3084058
10/07/22 01:26 PM
10/07/22 01:26 PM
an8sec70cuda Offline OP
Is this a '70 only shifter, or '70-'71?
If it fits a '71, then it could be from an E or B body...correct?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pistol grip ID [Re: an8sec70cuda] #3084059
10/07/22 01:28 PM
10/07/22 01:28 PM
More pics
CHIP
Re: Pistol grip ID [Re: an8sec70cuda] #3084099
10/07/22 04:32 PM
10/07/22 04:32 PM
That looks like a E body only shifter to me, all the 1966 to 1971 B body with and without consoles all had a lot longer shifter handle the 1970 4 speed Cuda I owned and raced, same thing on the A body shifters twocents
I've owned more than one E body 4 speed cars, they all had that shifter without the consoles up
Re: Pistol grip ID [Re: Cab_Burge] #3084127
10/07/22 07:38 PM
10/07/22 07:38 PM
Tennessee
CUDASCOTT Offline
CUDASCOTT  Offline
Tennessee
That’s a 71’-74 B/E body shift mechanism
Re: Pistol grip ID [Re: CUDASCOTT] #3084228
10/08/22 08:12 AM
10/08/22 08:12 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
iagree
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Pistol grip ID [Re: moparmarks] #3084236
10/08/22 09:24 AM
10/08/22 09:24 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
That mech and shifter will work in any E-body 70-74 and 71-74 B-body with buckets seats.
But IMHO, 70 E-body only, perhaps some early 71's used that slide in shifter handle and mechanism as pictured above.
71 and up E & B used the bolt in shifter handle and mechanism as pictured here.
Re: Pistol grip ID [Re: mccannix] #3084733
10/10/22 08:30 AM
10/10/22 08:30 AM
Thanks yall. I was thinking 1970 and maybe some 1971 models used the slide-in handle, but I'm certainly no expert.
CHIP
Re: Pistol grip ID [Re: an8sec70cuda] #3084745
10/10/22 08:58 AM
10/10/22 08:58 AM
Kirkland, Washington
Pacnorthcuda Offline
My very early build 70 Cuda has the slide in shifter. Stock.
Re: Pistol grip ID [Re: Pacnorthcuda] #3084881
10/10/22 03:21 PM
10/10/22 03:21 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Generally I would say it's 1970 E body. But...I have seen them in early 71 cars also. Have also seen bolt on E body pistol grips in late built 70 cars.
Most of the 71 B body cars used press-in also regardless of bench or bucket seats.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Pistol grip ID [Re: Dan Brewer] #3085207
10/11/22 06:10 PM
10/11/22 06:10 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
I have an early '71 build RR and it has the slide in handle just like the one pictured.
