Any one using the short 2 post lift. #3084316
10/08/22 01:54 PM
10/08/22 01:54 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
I'm looking at maybe getting something like the Maxjack portable two post lift. I am limited on space and ht. I think it would be a nice step up from jackstands. Just wondering if anyone has them and how you like them.
Re: Any one using the short 2 post lift. [Re: galen] #3084322
10/08/22 02:21 PM
10/08/22 02:21 PM
moparx Offline
moparx  Offline
i too, have the same situation.
years ago when i put a new roof on my garage, i thought about raising it to accommodate a lift.
well me, being a dumazz, didn't do that, so now in my "golden years" [and everyone knows what those are like], i'm still stuck with a jack and jack stands.
and let me tell ya, gettin' up off the floor is almost a comedic act around here any more. biggrin
beer
Re: Any one using the short 2 post lift. [Re: moparx] #3084369
10/08/22 04:57 PM
10/08/22 04:57 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
beer
I'm in the same boat 65 in January. I been in a manual wheelchair since 2000 from a broken back. So I work out of my chair ,leaning or on a creeper. Watching me get back up is down right ugly, and quite humorous with some cursing involved.. I think the short lift would be a nice step up. And the ability to shove them up against the wall if I need the side room..
Re: Any one using the short 2 post lift. [Re: galen] #3084507
10/09/22 11:19 AM
10/09/22 11:19 AM
moparx Offline
moparx  Offline
sorry to hear of your back problems !
i have MS, but i'm not as bad off as you are.
i have always said, it doesn't matter how bad i have it, there are people out there that are way worse than me.
and unfortunately, you are one of those people.
ok guys out there, i know some of you have experience with these shorty lifts.
please help Galen out with a review if you can.
a big TIA for any info you guys can provide. up bow
beer
Re: Any one using the short 2 post lift. [Re: moparx] #3084618
10/09/22 06:45 PM
10/09/22 06:45 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
I have no complaints. Wife, kids, grandkids, life is good. I have a good friend struggling with MS. He is a hot rod guy too, sold his business a few years ago as his disease progressed. Built hot rod Cummins B engines for pickups..I know like you, things may take a little longer and we just do things a little different. I have full use of my upper body so I am blessed.. I use shortened gear drive engine stands, benches, etc. Set my shop up as accessible as possible. Even got heat and AC. I'm going todrill a test hole and make sure my concrete is thick enough. If it is I may pull the trigger on these. Being able to do brakes from my chair would be really nice. Appreciate talking to you.
Re: Any one using the short 2 post lift. [Re: galen] #3084622
10/09/22 07:00 PM
10/09/22 07:00 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
If I could get the roof up close to the ceiling it would be great. My shop is a 3 car garage. Middle bay would give me a lot of room to move around the car. I know my wheelchair will not fit under it, but I have a plan,LOL.
Re: Any one using the short 2 post lift. [Re: galen] #3084678
10/09/22 10:36 PM
10/09/22 10:36 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I have a MaxJax in my garage. It is a nice alternative when you have lower than optimum ceiling height. I use it for my Belvedere and Dart. Don't think I would want to put a full sized pickup on it. The reservoir and hose set-up is kind of a pain and I'm had some hydraulic leak issues with the hose connections on the reservoir but I just keep the reservoir is a large pan and bleed the lift periodically. If I wasn't chronically behind on everything in life I would replace all the fittings and mount the reservoir on the wall.
The lift allows me to comfortably work under the car while rolling around on a wheeled shop stool. Sure beats jack stands.
Re: Any one using the short 2 post lift. [Re: Ramrod39] #3084686
10/09/22 11:06 PM
10/09/22 11:06 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Any pictures?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Any one using the short 2 post lift. [Re: BloFish] #3084816
10/10/22 01:02 PM
10/10/22 01:02 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Pics
Re: Any one using the short 2 post lift. [Re: Ramrod39] #3084885
10/10/22 03:41 PM
10/10/22 03:41 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Thank you Sir, I appreciate it. Looks like it would work well for my situation.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Any one using the short 2 post lift. [Re: BloFish] #3084931
10/10/22 06:27 PM
10/10/22 06:27 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Nice. And I see your helper fits under it with room to spare.
