Page 3 of 3 1 2 3
Re: Damaged cylinder head repair [Re: carnut68] #3084301
10/08/22 01:13 PM
10/08/22 01:13 PM
Texas
Chief Offline
Chief  Offline
Texas
Who to use in central Texas area for head and block weld/repair?
I've been jacking around since March to get mine welded up after dropping a valve seat on the dyno..
It's been sitting in 2 different machine shops and all they done is walk around it.
Dave Covey
Re: Damaged cylinder head repair [Re: Chief] #3084353
10/08/22 03:34 PM
10/08/22 03:34 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Call Slawko, not in Texas by any means but can fix you up. Assume Indy is still doing this work but not sure....
Re: Damaged cylinder head repair [Re: Al_Alguire] #3084398
10/08/22 07:09 PM
10/08/22 07:09 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Yes Indy is. I talked to Deanna. She said send repairs Attn to her.
America First!
Re: Damaged cylinder head repair [Re: carnut68] #3084594
10/09/22 04:49 PM
10/09/22 04:49 PM
Texas
Chief Offline
Chief  Offline
Texas
This is what I'm talking about. Dropped valve seat did this on 4th dyno pull.
Dave Covey
Re: Damaged cylinder head repair [Re: Chief] #3084663
10/09/22 09:20 PM
10/09/22 09:20 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
I'd say I got lucky compared to that. Hope you get it fixed.
America First!
Re: Damaged cylinder head repair [Re: carnut68] #3084818
10/10/22 01:05 PM
10/10/22 01:05 PM
Texas
Chief Offline
Chief  Offline
Texas
Thanks Carnut, So far it has been in 2 different shops that promised to get it done. Stuff just sits in the floor while they walk around it to work o other stuff.
I bought another Indy block, but I'm going to use my B1 heads on it since I have them. Now I have to order a set of pistons for the B1. Wierd bore at 4.400.
Dave Covey
Re: Damaged cylinder head repair [Re: carnut68] #3103584
12/19/22 01:36 PM
12/19/22 01:36 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Indy did the repair portion of this job, then I touched up the valve job and opened the ports to MW size.
Looks like they’ll be able to race another day......
Re: Damaged cylinder head repair [Re: fast68plymouth] #3103591
12/19/22 02:06 PM
12/19/22 02:06 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Excellent as always! Yeah.
America First!
Page 3 of 3 1 2 3
