An embarrassing question #3084112
10/07/22 05:54 PM
10/07/22 05:54 PM
robertop Offline OP
robertop  Offline OP
I am really embarrassed to ask such a basic question after owning my Mopar for over 50 years, but here it is: my 69 roadrunner has had a brake failure due to a bad master cylinder; now it has been rebuilt, but I need to bleed the whole system. The car has power brakes, and the question is: does the engine have to be on while bleeding each wheel or can I do it with the engine off? Thank you.
Re: An embarrassing question [Re: robertop] #3084113
10/07/22 06:04 PM
10/07/22 06:04 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
You can do it with engine off, I like to take the check valve off the master to make the pedal easier while doing it.
Some may not agree with me but that's how I do it after bench bleeding the master.
Ron
Re: An embarrassing question [Re: robertop] #3084115
10/07/22 06:08 PM
10/07/22 06:08 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I have never bled power brakes with the engine running nor have I ever seen someone else bleed power brakes with the engine running. That's just me. Don't see why the engine would need to be running just to make vacuum for the power booster when all you are doing is pushing fluid mechanically through the system and not trying to stop a three or four thousand pound vehicle?
BTW I was always taught that no question is dumb and not, I'll also say, be embarrassing. I think this was a good question up
Re: An embarrassing question [Re: A12] #3084116
10/07/22 06:22 PM
10/07/22 06:22 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
As an aside, I used a Motive power bleeder. Oh does it make it so easy to bleed the brakes.
Re: An embarrassing question [Re: robertop] #3084124
10/07/22 07:17 PM
10/07/22 07:17 PM
IMGTX Offline
IMGTX  Offline
Nothing to be embarrassed about. That's a legitimate question.
I do not bleed with the engine running. The booster makes it hard to feel the brakes get hard or "pump up" when bleeding.
Bleed the master cylinder cylinder first. Some do it before they put it in the car but I use hoses connected to the ports that push the fluid back into the reservoir. Fill the reservoir above the hose ends and slowly press the pedal to the floor 2 or 3 times making sure the hose ends do not get air in them.
I then gravity bleed followed by pump bleeding the system.
Re: An embarrassing question [Re: IMGTX] #3084126
10/07/22 07:37 PM
10/07/22 07:37 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Must be something in this Fall air, my master cylinder just failed on my 69 Road Runner a few weeks ago. Mine is a manual brake set up though.
Hope your failure wasn't as interesting as mine, I lost all brakes and took a little trip around the side on my garage, through some gravel, over my man door walkway, through my back yard and got it slowed down enough to slam it in park. Didn't hit or touch anything though. Could have been much worse.
Bench bled the new master last weekend, threw it on the car and bled the brakes, good to go now.
Re: An embarrassing question [Re: parksr5] #3084154
10/07/22 09:52 PM
10/07/22 09:52 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
For those of you replacing masters, It's a good time to inspect / replace the wheel cylinders and calipers as well. Had one just this week that I assumed were fine due to us replacing them ~ 10 years back. For some reason after all was done and bled I decided to pull a rea drum and the W/C was just damp with fluid. Peeling back the dust seal revealed rust shock. So, I got to bleed the system again after replacing the W/C and calipers
whistling spank spank
Re: An embarrassing question [Re: robertop] #3084165
10/07/22 10:37 PM
10/07/22 10:37 PM
Cab_Burge Online work
Cab_Burge  Online Work
i know several good DIY guys that open one bleeder screw at a time amd wait until they get a solid flow of brake fluid out of it and then do the next one,
I was taught when bleeding brakes with the older single piston master cylinders to start bleeding at the right rear and then do the left rear, then move up to the right front and then finish at the L.F. the one closest wheel cylinder to the master cylinder up wrench
I do the same way on the new dual piston M.C., bleed the farthest one first and then do the closet one to the MC, front or rear first doesn't matter to me twocents
Re: An embarrassing question [Re: Cab_Burge] #3084206
10/08/22 06:13 AM
10/08/22 06:13 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i would think that using one of those "one man" bleeders like a Mighty Vac would do everything you need.
Re: An embarrassing question [Re: Cab_Burge] #3084225
10/08/22 08:01 AM
10/08/22 08:01 AM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
My one-person method is to put a piece of vac hose over the bleeder screw, stick the other end of the hose in a partially filled jar of brake fluid so the end of the hose is submerged. Then open the bleeder and pump the brakes until there are no bubbles coming out into the jar.
The only trick to it is getting in a position where you can see the jar and pump the pedal at the same time.
I have never heard of anyone starting the car to bleed the brakes.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: An embarrassing question [Re: robertop] #3084314
10/08/22 01:42 PM
10/08/22 01:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Before you go any further with the bleeding of the system, seeing that the master has been rebuilt/replaced, best to check the air gap between the booster's rod and the bore of the new master, even if it's the original unit rebuilt, dimensions can change, too large an air gap, the pedal will always be on the floor, too tight or no gap will result in the front calipers dragging....Mopars generally are good with .060 air gap.....and can we assume you have/plan to bench bleed the master before install?
Here's some pics to understand the "air gap"...
Re: An embarrassing question [Re: DAYCLONA] #3084354
10/08/22 03:34 PM
10/08/22 03:34 PM
moparx Offline
moparx  Offline
i ask "stoopid old guy questions" all the time. whistling biggrin
nothing to be ashamed about asking ! [what was the topic again ? panic laugh2]
all good things added to check as well.
remember : "Speed doesn't Kill. It's the SUDDEN STOP that does you in every time !".................. devil
beer
Re: An embarrassing question [Re: parksr5] #3084550
10/09/22 01:13 PM
10/09/22 01:13 PM
robertop Offline OP
robertop  Offline OP
My failure occurred while I was on an expressway to see my painter. I was doing around 60 mph and the red “brake” light in my dash came suddenly on and went off after about 30 seconds, so I did not worry much, but when I got to my exit I realized I had no brakes! Luckily it was Sunday morning and the car managed the exit and I made it to the shop, but that was a pucker moment I will not forget.
Re: An embarrassing question [Re: robertop] #3084586
10/09/22 03:56 PM
10/09/22 03:56 PM
Let off the throttle all the way and downshift into 2nd gear and get ready to use the emergency brake when needed to complete the stop.
'I'm glad you and the car were not hurt or injured: up:
I went through a 6 ft. tall chain link fence at work when my old 1963 Plymouth M.W. car throttle stuck at WOT while goofing around driving it into our work yard one morning due to the left rear wheel cylinder failing when I jump on the brakes hard to try and stop it.
I'm glad that didn't tear the car up more than it did, it tore the 426 hood emblem off and scratched the front of the hood and roof above the windshield, not good.
That incident scared the keck out of me and made me think a lot more after that before doing stupid things in a car with some power blush work:
Re: An embarrassing question [Re: robertop] #3084624
10/09/22 07:05 PM
10/09/22 07:05 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
My brake failure story:
Out in our storage yard in Phoenix, AZ., I was tasked with airing-up the tires on a '65 GTO & moving the car. I started it & backed it out of the slot - it was obviously hard to roll because all 4 tires were flat, but it felt like it had brake pedal pressure. I aired the tires, started it & it was on a high idle, I put it in gear (automatic), & forward I went kind of quickly - I went for the brakes & nothing - NO BRAKES at all! I had about 50' to make a decision on what to do - either plow into a beautiful 1975 Roadrunner I had purchased at a used car lot (with 35,000 original miles I might add), or take the GTO out the gate & into a busy road - Broadway. I took the GTO into the Roadrunner to stop it & I let out a helluva yell as I hit it. I didn't even have time to think about hitting the emergency brake or jam it into park - it happened so fast. I tried to pump-up the brakes but the system had to be empty. I was SO pissed! I stove-in the RR quarter panel behind the wheel about 10", but the GTO came to a rest. I feel the sickening feeling every time I think about it!
Re: An embarrassing question [Re: DAYCLONA] #3084946
10/10/22 07:09 PM
10/10/22 07:09 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Any idea where I could find one of those tools?
Re: An embarrassing question [Re: 71birdJ68] #3084996
10/10/22 10:08 PM
10/10/22 10:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Never mind, I found them on ebay
