Control box #3083695
10/05/22 11:50 PM
10/05/22 11:50 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Anyone know what will dissolve that goo in the back of the factory electronic control boxes?
Re: Control box [Re: cudaman1969] #3083697
10/05/22 11:54 PM
10/05/22 11:54 PM
I would try some lacquer thinner covering the goo and let it sit from 5 to 20 minutes and see if it will fallout or scrape out easier twocents
I remember faintly someone doing that years ago but I can't remember the details now confused
Re: Control box [Re: Cab_Burge] #3083789
10/06/22 12:16 PM
10/06/22 12:16 PM
moparx Online content
moparx  Online Content
the next question is, what does one re-fill the back of the box with ?
beer
Re: Control box [Re: moparx] #3083826
10/06/22 01:31 PM
10/06/22 01:31 PM
beer
Non conducting epoxy? confused
Re: Control box [Re: Cab_Burge] #3083839
10/06/22 02:02 PM
10/06/22 02:02 PM
fredericksburg,va
fredericksburg,va
I’m thinking silicone it’s still pliable after 50 years
Re: Control box [Re: moparx] #3083844
10/06/22 02:21 PM
10/06/22 02:21 PM
IMGTX Offline
IMGTX  Offline
beer
Industry uses "Electronics Potting Compound"
Epoxy usually.
Easily found on Amazon or many other places
Re: Control box [Re: cudaman1969] #3083852
10/06/22 02:58 PM
10/06/22 02:58 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Re: Control box [Re: cudaman1969] #3083860
10/06/22 03:41 PM
10/06/22 03:41 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Yeah just mount it on the inner fender of your brand new paint job and it will start melting in a few weeks eek
I had an orange box do that before.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Control box [Re: fourgearsavoy] #3083960
10/07/22 12:26 AM
10/07/22 12:26 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Let me leave it on my shelf for a few years. Mess on shelf then.
I want my fair share
Re: Control box [Re: A12] #3084051
10/07/22 12:48 PM
10/07/22 12:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by A12
I'd be concerned about the temperature affecting the other components shruggy
Re: Control box [Re: TJP] #3084072
10/07/22 01:46 PM
10/07/22 01:46 PM
IMGTX Offline
IMGTX  Offline
That video was with a circuit board.
For circuit board electronics they are baked on the board in a heated chamber filled with an inert gas which acts like a flux to keep the oxygen out of the solder joints. They are heated a lot more than the 210 degrees boiling water will reach.
Our older stuff was not IC chips but full size resisters and transistors so I would tend to agree with you that they are more heat prone but I think 210 degrees is still below what they see in our old cars in the summer heat. shruggy
