Dana 60 obvious question #3083378
10/04/22 08:38 PM
10/04/22 08:38 PM
robertop Offline OP
robertop  Offline OP
My 69 hemi bird has a different Dana 60 taken from another bird with a blown hemi engine. We installed it in the middle 70’s, and I am sure that nobody opened it up since it was put in that car. My car has about 65,O00 miles and soon it will have more. Do you think it’s a good idea to change the Dana lube? The answer is obviously Yes! Well, I had to ask.
Re: Dana 60 obvious question [Re: robertop] #3083380
10/04/22 08:45 PM
10/04/22 08:45 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Yes I would change it and replace the gasket to get a look inside at the gears. Just regular 80-90 wt, with a bottle of Ford Motorsport friction modifier added. twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Dana 60 obvious question [Re: fourgearsavoy] #3083385
10/04/22 09:02 PM
10/04/22 09:02 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Should have changed it years ago. Cheap Insurance.
Re: Dana 60 obvious question [Re: robertop] #3083418
10/04/22 10:43 PM
10/04/22 10:43 PM
Change it and add the posi additive along with 75 80Wt H.D. gear oil twocents
Re: Dana 60 obvious question [Re: Cab_Burge] #3083423
10/04/22 11:26 PM
10/04/22 11:26 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Nah, why change it, does it go bad? Stick your finger in the hole to check the condition.
Re: Dana 60 obvious question [Re: cudaman1969] #3083438
10/05/22 01:57 AM
10/05/22 01:57 AM
shock Are you kidding ME shruggy
It has been hot and cold multiple times and absorb moisture when cooling off (if I'm remembering my high school chemistry correctly oil, liquid petroleum grease and water heated up will make sulfuric acid when it cools down, not pure acid but minute amounts, correct?) and you think it doesn't go bad tsk scope
Re: Dana 60 obvious question [Re: Cab_Burge] #3083500
10/05/22 09:51 AM
10/05/22 09:51 AM
fredericksburg,va
fredericksburg,va
That’s what the vent is for, now IF you start cooking oil to the flash point by all means change it. But then the oil is the least of the problem. My 65 Plym still has the original rear and trans fluid, still good.
Re: Dana 60 obvious question [Re: cudaman1969] #3083517
10/05/22 10:54 AM
10/05/22 10:54 AM
central il.
second 70 Offline
second 70  Offline
central il.
I've only changed fluid once in a rear end in 45 years and have never had any problems. The 1 I that I changed the modifier had worn out and rear would stick & clank going around corners. Probably could have just added the modifier and been fine. Also I have never changed trans fluid in my regular driver trucks and cars and have never had a tranny problem but my friends who changed their fluid in the same models did.
Re: Dana 60 obvious question [Re: second 70] #3083540
10/05/22 12:34 PM
10/05/22 12:34 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I’ve been surprised at trans guides that state something is lifetime fill. I saw an old mopar service film that stated a 727 had lifetime fill fluid for normal service. I changed an NP435 one time where it had milkshake coming out. 22,000 mile truck that was 20 years old. I’m sure it was factory fill.
I want my fair share
Re: Dana 60 obvious question [Re: SomeCarGuy] #3083568
10/05/22 01:59 PM
10/05/22 01:59 PM
moparx Offline
moparx  Offline
the go to additive at one time [at least around here] was the GM stuff.
some now recommend jeep brand additive.
what's the difference ? i don't have a clue. shruggy
what i do know, however, is that adding a container of the "strange" brand additive cures a sticky lock up converter clutch !
that worked perfectly in my wife's 94 concorde front drive transaxle.
i don't know where i heard about that, or who told me, but i couldn't believe how good it worked.
just my personal experience in life.
your results will vary.
beer
Re: Dana 60 obvious question [Re: moparx] #3083581
10/05/22 03:13 PM
10/05/22 03:13 PM
fredericksburg,va
fredericksburg,va
beer
Ok so now I got to know the brand and type for my Van!
Re: Dana 60 obvious question [Re: cudaman1969] #3083582
10/05/22 03:25 PM
10/05/22 03:25 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I believe the oil does not wear out very quickly. 90 weight and Mopar additive is what I use. Putting 100K on an axle I would be looking inside of it because usually if it is Dana in a car it has been used well. So both Cuda and Cab are correct in their thinking. If you feel you need to change the oil do it. If I put another rearend in the a car I change the oild because I want to do it once, and take the cover off inspect everything pull axles check flange to flange. I have not check my Dana in my Challenger since the gear change in 1971 but it has only had maybe 600 miles put on it at the race track and I do not hear any noise or feel anything bad in the rear end. Me, I would take it apart look it over make it like new and forget about it for another 75K.
1971 HEMI E BODY REGISTRY
Re: Dana 60 obvious question [Re: hemicar1971] #3083762
10/06/22 10:20 AM
10/06/22 10:20 AM
central il.
second 70 Offline
second 70  Offline
central il.
This is what I used that was recommended for clutch type and solved the sticking problem.
https://www.amazon.com/Genuine-GM-88900330-Lubricant-Additive/dp/B0028CMPIS
Re: Dana 60 obvious question [Re: cudaman1969] #3083835
10/06/22 01:54 PM
10/06/22 01:54 PM
Condensation occurs when the outside weather drops the temps and humidity, a hot rear end makes heat and the breather lets out that hot air, once the car stops and sits overnight the rear end sucks in outside air through as it cools down, just like the motor and transmission does shruggy
