Damaged cylinder head repair
#3082292
10/01/22 04:14 PM
10/01/22 04:14 PM
Posts: 3,190 Md.
carnut68
Md.
Since I dropped a valve and damaged the head [Indy SEZ] the guide is split open for sure haven't pulled the head just intake. I'm weighing options here. Try to repair, it looks pretty bad. Replace the single head. Or buy a pr of Edelbrock E Streets and be done with it. With the economy taking a crap I want to be careful with $, but I also don't want it to sit for months not running. Thoughts? The 446 is probably toast hint of water in the oil. I have another shortblock ready..512 with a smallish roller. This happened yesterday, but I did make my quickest passes ever. 10.66@125.4 1.47/60 and picking up with each pass.
America First!
Re: Damaged cylinder head repair
[Re: carnut68]
#3082299
10/01/22 04:30 PM
10/01/22 04:30 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You won’t know till it’s taken apart and stripped but I’m betting it’s fixable. Jump on it and get it to a shop before everyone else. Winters coming. Indy may even fix it.
[Re: carnut68]
#3082322
10/01/22 06:17 PM
10/01/22 06:17 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
A head broke off a valve? Intake or exhaust? The most common reasons I see that are usually because there was something unhappy in the valvetrain, valve to piston contact, or in the case for exhaust valves, it can be a corrosion issue.
I would carefully inspect the cam & lifter that correspond to that valve, along with checking to see that the spring hasn’t given up.
Also, I’d look for witness marks in the heads near where the pushrods go. It’s pretty rare that a valve breaks “for no reason”...... as in just fatigue. With some detective work, you can usually find the reason.
[Re: fast68plymouth]
#3082326
10/01/22 06:24 PM
10/01/22 06:24 PM
Posts: 3,190 Md.
carnut68
Md.
Also, I’d look for witness marks in the heads near where the pushrods go. It’s pretty rare that a valve breaks “for no reason”...... as in just fatigue. With some detective work, you can usually find the reason. Intake valve. Broke all the way off. Valve spring is not broke as far as I can tell.
America First!
[Re: carnut68]
#3082327
10/01/22 06:25 PM
10/01/22 06:25 PM
fast68plymouth
So. Burlington, Vt.
The head broke off, or it broke up by the retainer?
#3082329
10/01/22 06:32 PM
10/01/22 06:32 PM
Posts: 3,190 Md.
carnut68
Md.
The head broke off, or it broke up by the retainer? The head of the valve. You can see it with intake off. The guide is split open.
America First!
[Re: carnut68]
#3082333
10/01/22 06:52 PM
10/01/22 06:52 PM
fast68plymouth
So. Burlington, Vt.
It’s very rare for an intake valve to “just break”....... without some sort of help.
Look everything over carefully when you pull it apart.
The last broken intake valve I can think of was in a 452 head. That motor was running an aggressive SFT cam with 1.6 rockers.
The actual failure that resulted in the broken valve was the tangs got sheered off the locks from the valve hammering shut repeatedly. The locks had actually worked there way towards the top of the valve, and the roller wheel from the rocker had pounded a trough into the top of the locks. When the tangs finally let go, the valve slid down the guide, the piston whacked it, and then the head of the valve snapped off.
The cause of the valve hammering shut and pounding the locks into oblivion was that the spring had died. Only that one spring was dead........ down like 30-40lbs. The other 15 tested within a few pounds of new.
Why that one spring died was the unanswered question on that failure.
#3082384
10/01/22 11:04 PM
10/01/22 11:04 PM
Posts: 3,190 Md.
carnut68
Md.
The valve stem is still attached and the keeper still holding retainer. With the spring pulled tight. The head is off and there is a hole in the piston luckily it didn't scar up the cylinder. The head of the valve is wedged in the port and the guide is cracked, the exhaust valve looks to be bent also. The chamber and seat is scarred up.
America First!
[Re: Cab_Burge]
#3082391
10/01/22 11:50 PM
10/01/22 11:50 PM
Posts: 3,190 Md.
carnut68
Md.
Weak valve springs lead to death and destruction in high performance engines when driven aggressively No arguments here. I'm just glad it ruin the block. Especially since it's a 65 year block.
America First!
[Re: carnut68]
#3082433
10/02/22 10:31 AM
10/02/22 10:31 AM
fast68plymouth
So. Burlington, Vt.
My main point was, especially with regards to intake valves........ they very rarely break without a reason.
#3082439
10/02/22 10:57 AM
10/02/22 10:57 AM
Posts: 3,190 Md.
carnut68
Md.
My main point was, especially with regards to intake valves........ they very rarely break without a reason. I understand. I didn't see any obvious, that point to any one thing. I need to drop the pan and check #5 rod bearing since it was that cylinder. There is a small witness mark on #7 piston. So it's possible the springs lost control of the valves. It happened at 1-2 shift [6400 rpms] a friend said he could hear the engine sound change.
America First!
[Re: Cab_Burge]
#3082647
10/03/22 09:17 AM
10/03/22 09:17 AM
Posts: 4,457 Washington
madscientist
Washington
I’ve fixed way worse than that. That’s a relatively easy fix. As Cab said replace all the valves. And I would double check the spring load.
[Re: carnut68]
#3082838
10/03/22 01:23 PM
10/03/22 01:23 PM
Posts: 1,130 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I've seen worse that were repaired successfully... but they weren't mine
Regardless, ouch!
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3082848
10/03/22 01:58 PM
10/03/22 01:58 PM
fast68plymouth
So. Burlington, Vt.
Well, I see what’s 99% likely the cause of the failure.
#3082850
10/03/22 02:02 PM
10/03/22 02:02 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
Well, I see what’s 99% likely the cause of the failure. Yep, & replace ALL the intake valves, new springs & double check PV clearance
