Re: external oil lines
[Re: BigFish69]
#3081589
09/28/22 10:59 PM
09/28/22 10:59 PM
Posts: 11,705 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Aeroquip. Fragola. I like the lightweight nomex or nylon hose. Or you can use the stainless braid stuff.
The Fragola nylon has a single layer of wire braid in it, making it tougher with a slight weight increase.
Whichever you use, do not mix and match hose and ends between manufacturers.
[Re: BigFish69]
#3081598
09/29/22 12:03 AM
09/29/22 12:03 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
Which lines are you asking about? Oil pan to oil pump pickup lines or ? Regardless of the application make sure and use Teflon line PTFE lines for the heat and pressures on oil lines
[Re: BigFish69]
#3081611
09/29/22 01:53 AM
09/29/22 01:53 AM
Posts: 31,076 Oregon
AndyF
What is the best quality fitting and hose for external oil lines. I use Aeroquip on most everything. They usually have what I need and they have a very wide selection of parts. Summit carries most of the Aeroquip stuff so I can get it fairly quickly. There is also a couple of large Aeroquip dealers within 20 miles of my shop so I can go there is something isn't available at Summit.
[Re: BigFish69]
#3081625
09/29/22 08:25 AM
09/29/22 08:25 AM
Posts: 13,401 Marion, South Carolina [><]
an8sec70cuda
Whatever I have on the shelf when I need to make one. I have a mixture of Aeroquip, Jegs, Fragola, and some Summit hose ends. Usually use the Jegs or Summit house brand stainless braided hose...the normal stuff, not PTFE. Never had an issue w/ any of my lines on the oil side. Fuel lines I've had to replace a couple once they get over 10 years old and develop pinholes.
[Re: an8sec70cuda]
#3081634
09/29/22 10:21 AM
09/29/22 10:21 AM
Posts: 4,584 Motor City
6PKRTSE
Motor City
I run mostly Fragola's black nylon hose on my cars. I wrapped it with heat wrap because of how close it come to my headers.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3081666
09/29/22 12:44 PM
09/29/22 12:44 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Once you plumb something with the lightweight stuff - Aeroquip Startlite or Fragola Black Nylon hose - you won't ever want to use external stainless braid again.
PTFE lined is the way to go. Once you get into the bigger stuff - > -8 - you have less options. Fragola Racerite is the good stuff and is available up to -16. But, it is for crimp ends only and gets to be $30/ft.
But, you did say "best", not "cheap".
[Re: CMcAllister]
#3081668
09/29/22 12:50 PM
09/29/22 12:50 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Speaking of oil lines I’m pretty sure on my heads up car I’m having a change of plans. After running a dual line pickup for years I think I’m switching to a single line setup. Pretty tight on this car and I see many of you guys running a single line system with lots of success.
[Re: pittsburghracer]
#3081673
09/29/22 12:59 PM
09/29/22 12:59 PM
an8sec70cuda
No problems w/ a simple single line static pickup system here. My "new" pan, if I ever get motivated to put it on. will be a single line also, but w/ a swinging pickup. Current setup on top. "New" pan on the bottom.
[Re: an8sec70cuda]
#3081677
09/29/22 01:08 PM
09/29/22 01:08 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
I use Fragola on everything. American made and a huge selection of fittings and hose. Summit carries a large selection of Fragola hose and fittings in stock. I prefer the lite black nylon stuff if you want some added security they sell internal springs for things like oil lines. FWIW I have NEVER run a dual line set up. All three of our current deals are single -16 lines pretty much all I have used for years.
[Re: an8sec70cuda]
#3081681
09/29/22 01:23 PM
09/29/22 01:23 PM
Posts: 2,937 A shed in England
Tig
A shed in England
No problems w/ a simple single line static pickup system here. My "new" pan, if I ever get motivated to put it on. will be a single line also, but w/ a swinging pickup. Current setup on top. "New" pan on the bottom. Dude, I need one of those Charlies pans real bad
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
#3081685
09/29/22 01:37 PM
09/29/22 01:37 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The dual line advantage is it provides a feed to both sides of the pump gears. The theory is it makes it easier for oil to fill that void as the pump rotates and prevent cavatation. Making it easier to get oil in on the suction side, makes the pump more efficient. An idea that was presented in some of the old Direct Connection books and used on some small block stuff you obtained from some dummy a few years ago.
[Re: Tig]
#3081687
09/29/22 01:39 PM
09/29/22 01:39 PM
an8sec70cuda
No problems w/ a simple single line static pickup system here. My "new" pan, if I ever get motivated to put it on. will be a single line also, but w/ a swinging pickup. Current setup on top. "New" pan on the bottom. Dude, I need one of those Charlies pans real bad I looked for one for a long time! Found this one on ebay...guy was converting his challenger from drag only back to a street car and didn't want this pan anymore.
[Re: an8sec70cuda]
#3081696
09/29/22 01:46 PM
09/29/22 01:46 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some of use oldtimers are stockpiling those oil pans because they became hard to find.
#3081699
09/29/22 01:54 PM
09/29/22 01:54 PM
Al_Alguire
Las Vegas
Since Charlies has gone out f business again good luck finding one. There are an alternatives for sure. One is Shortys Perfromance Fabrcation in Clovis, CA, they do great work that is 100% better than charlies.
