Oil Change At Chrysler Dealer Upsell? #3081172
09/27/22 03:47 PM
09/27/22 03:47 PM
Highland, MI.
Sunroofcuda Offline OP
Highland, MI.
So my wife is at our local Dodge dealer right now to buy a new oil change package for our 2018 Jeep Grand Cherokee with the 3.6L Pentastar. They are telling her it calls for full-synthetic 0W20 oil - the package is $145.00 vs. $100.00 for semi-syn. I end up talking with the service manager who tells me I might be out of luck if there is an engine failure while running semi-synthetic oil - the car is certified, so it has a 100k drivetrain warranty. So I asked when Chrysler changed oil requirements on the 3.6L, because they use semi-syn in my 2016 300 that also has the 3.6L motor, & same with my two other previous 300's (a 2012 & 2014) that also both had the 3.6? He could not tell me when these engines started requiring the full-syn.
So the question I have is this: is what they are telling me legit? I have never heard of this scenario before. This same service manager also tells me he has never heard of ANY valvetrain issues with the 3.6 engine. I think this guy is FOS.
Re: Oil Change At Chrysler Dealer Upsell? [Re: Sunroofcuda] #3081173
09/27/22 03:51 PM
09/27/22 03:51 PM
BDW Offline
BDW  Offline
What does the service manual call for?
EDIT: Owners manual?
Re: Oil Change At Chrysler Dealer Upsell? [Re: BDW] #3081183
09/27/22 04:37 PM
09/27/22 04:37 PM
Highland, MI.
Highland, MI.
I called a second dealer & a service manager I know - he said the 2018 Jeep 3.6 calls for 0W20. He said ALL 0W oils are full-synthetic. I'd just like to know when the 3.6L engines changed from 5W20 to 0W20? Sounds legit, but I've never heard of this change before today.
Re: Oil Change At Chrysler Dealer Upsell? [Re: Sunroofcuda] #3081185
09/27/22 04:42 PM
09/27/22 04:42 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
OMG he hasn't heard of valvetrain issues with the 3.6??????????????? Is he high??????????????? Valve train and heads.
Facts are stubborn things.
Re: Oil Change At Chrysler Dealer Upsell? [Re: Sunroofcuda] #3081187
09/27/22 04:46 PM
09/27/22 04:46 PM
Kirkland, Washington
Pacnorthcuda Offline
My 2012 3.6 calls out for 5w-30. Jeep Wrangler.
Re: Oil Change At Chrysler Dealer Upsell? [Re: Pacnorthcuda] #3081190
09/27/22 04:52 PM
09/27/22 04:52 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
0w20...I would use full synthetic.
What do you get for $145? You can get 5qt of Mobil 1 or Pennzoil Platinum, with a premium filter at Advance for $40.
ETA...looks like 0w20 in the 3.6 and 5w30 in the 2.0. Semi-synthetic 0w20 is not easy to find.
Re: Oil Change At Chrysler Dealer Upsell? [Re: Sunroofcuda] #3081194
09/27/22 05:02 PM
09/27/22 05:02 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
That MAY be a requirement for the 3.6 PUG engines. check your owners manual to be sure. How many oil changes are included in the package?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Oil Change At Chrysler Dealer Upsell? [Re: 3hundred] #3081200
09/27/22 05:49 PM
09/27/22 05:49 PM
Highland, MI.
Highland, MI.
3 oil changes. I've been doing this 3-fer package with the Chrysler dealers for years. These were $85.00 for a long time, then went up to $100.00 for semi-syn - still current. They are a great deal, plus documented oil changes through the dealers.
Re: Oil Change At Chrysler Dealer Upsell? [Re: CMcAllister] #3081201
09/27/22 05:50 PM
09/27/22 05:50 PM
Highland, MI.
Highland, MI.
THREE oil changes (plus filters of course) for $145.00. GREAT deal if you ask me!
Re: Oil Change At Chrysler Dealer Upsell? [Re: Sunroofcuda] #3081270
09/27/22 09:05 PM
09/27/22 09:05 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Did you check the owners manual?
Re: Oil Change At Chrysler Dealer Upsell? [Re: Sunroofcuda] #3081278
09/27/22 09:32 PM
09/27/22 09:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
True.
Re: Oil Change At Chrysler Dealer Upsell? [Re: CMcAllister] #3081284
09/27/22 09:43 PM
09/27/22 09:43 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I went through the same thing when we bought our 2010 Cummins. Owners manual calls for 5W-40 full synthetic or "engine damage may occur". OK, I call up the dealership and ask them about this. I tell them that the other Cummins we had never had this requirement (1998, 2001, 2005) and all I ever used was 15W-40 conventional. They tell me that they use 15W-40 conventional in all their Cummins and have not had any problems. So I ask if I use 15W-40 conventional and have an engine problem, will they warranty it? Crickets at first and then the music began with the dancing to follow. So I've been using the Valvoline 5W-40 full synthetic. Cheap insurance.
Re: Oil Change At Chrysler Dealer Upsell? [Re: justinp61] #3081312
09/28/22 12:14 AM
09/28/22 12:14 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I looked it up, 2018 Jeep GC owners manual, pages 445 & 446
Engine Oil Viscosity (SAE Grade) — 3.6L Engine
Mopar SAE 0W-20 engine oil approved to FCA Material
Standard MS-6395 such as Pennzoil, Shell Helix or equivalent is recommended for all operating temperatures. This
engine oil improves low temperature starting and vehicle
fuel economy
If they've decided a full synthetic is required there should be an OM addendum or TSB.
Synthetic Engine Oils
You may use synthetic engine oils provided the recommended oil quality requirements are met, and the recommended maintenance intervals for oil and filter changes are
followed.
Synthetic engine oils which do not have both the engine oil
certification mark and the correct SAE viscosity grade
number should not be used.
Chrysler MS-6395 approved oils linky
FWIW, to me, synthetic oil and nitrogen for tires are of quite dubious benefit, and considering the cost, given a choice, I wouldn't pay the difference. Near 50 years ago I was a mechanic, I've NEVER seen an oil failure, seen plenty of lack of maintenance failures. Just keep the oil and fluids changed. 2¢
'69 300 Convertible
'16 300 S Hemi
Re: Oil Change At Chrysler Dealer Upsell? [Re: 6PakBee] #3081319
09/28/22 01:39 AM
09/28/22 01:39 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If you trust how the viscosity numbers work, and you can look it up on data sheets, 5w40 and 15w40 will be essentially the same viscosity once it gets up to temperature (210*F)
Re: Oil Change At Chrysler Dealer Upsell? [Re: CMcAllister] #3081361
09/28/22 09:05 AM
09/28/22 09:05 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
You are preaching to the choir.
Re: Oil Change At Chrysler Dealer Upsell? [Re: 6PakBee] #3081403
09/28/22 11:16 AM
09/28/22 11:16 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I recently had he oil changed in my 2008 D3500 Cummins at one of the local Dodge dealerships.
I was told they had nothing but synthetic oils.
Re: Oil Change At Chrysler Dealer Upsell? [Re: CMcAllister] #3081463
09/28/22 03:22 PM
09/28/22 03:22 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
The key here is viscosity at operating temp. There may be a reason the need the oil to flow more freely on a cold engine.
Re: Oil Change At Chrysler Dealer Upsell? [Re: MoonshineMattK] #3081467
09/28/22 03:36 PM
09/28/22 03:36 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
clearly you are going to the dealer because of your engine warranty, so in that case, just keep going with what they say, if you make a decision now and change it, then they might say they never said that.But as you can tell, they have you over the barrel on oil changes for the warranty, do your own and save the receipts and mark down the mileage and you are good.
Re: Oil Change At Chrysler Dealer Upsell? [Re: 340Cuda] #3081469
09/28/22 03:37 PM
09/28/22 03:37 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Getting hard to find conventional oil in parts stores, unless you buy the house brand (NAPA, Fram).
Re: Oil Change At Chrysler Dealer Upsell? [Re: CMcAllister] #3081504
09/28/22 05:29 PM
09/28/22 05:29 PM
Highland, MI.
Highland, MI.
This is very true - products in general. I use Castrol Syntec 0W40 for my 2016 Challenger Scat Pack & cannot find it in any stores around me. I just ordered two jugs of it online today through Amazon. Hey - what are you gonna do? I prefer to support brick & mortar, but they ain't got!
