Page 3 of 4 1 2 3 4
Re: Has Comp fixed their cams? [Re: TJP] #3080155
09/23/22 11:16 PM
09/23/22 11:16 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by TJP
Originally Posted by CMcAllister
Three words...
Industrial Opportunity Partners
Comp Cams started in 1975, Did their people all of a sudden forget how to do it?
No they were likely let go for cheaper entry level people with no long term knowledge by Industrial Opportunity Partners
if one thinks about it, a 25 year old college grad that was hired on in 1982 is now 65 and making $$ plus bennies.
IOP says we can get 2 or more for what we're paying the old fart. So out the door all that experience goes. Eager beaver new hire want's to make a name for himself so they start tweaking things to save cost and make themselves look good. yeah there's some problems cropping up but the focus is on Current technology and $$$$$ so no one's really paying attention or cares.
twocents
Have heard that more than once. MSD, Racepak, Edelbrock, probably some others I've forgotten...
Re: Has Comp fixed their cams? [Re: TJP] #3080165
09/24/22 12:03 AM
09/24/22 12:03 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Three words...
twocents
Yep! My wife was in manufacturing for 35+ years at the same company. They decided she made too much $$ and "eliminated" her position. She took a few months off then landed a place where she's appreciated. Her old place reached out to her after a year saying they needed her experience back...lol....she told them to pack sand. The place won't make it another year.
Re: Has Comp fixed their cams? [Re: Dcuda69] #3080228
09/24/22 11:07 AM
09/24/22 11:07 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Three words...
twocents
Unfortunately, I've witnessed it to many times. I think ones best bet might be to look for smaller independently owned suppliers/ manufacturers as they have to pay attention to their sourcing quality and will suffer much more if they don't. IE: Howard's cams, Isky, Hughes, etc. twocents
Re: Has Comp fixed their cams? [Re: TJP] #3080272
09/24/22 01:51 PM
09/24/22 01:51 PM
A727Tflite Offline
A727Tflite  Offline
Three words...
twocents
Every time we had a quality issue at Chrysler that I was involved in, it usually came from the manufacture not following established and agreed to quality control measures. If we were the manufacturer (internal plant) we didn’t maintain the existing quality controls and inspections.
External suppliers, usually the same thing. Sometimes they would purposely “thrift” the process or materials.
Sometimes someone would make a change not realizing the impact of the change.
I have never seen any internal or external supplier do it knowing it would cause quality issues.
As for 25% failure - 97.5% of estimates are made up.
As for the earlier mentioned issue of some used parts being recycled as new - at Chrysler, General Counsel stated that was against Federal Law.
Re: Has Comp fixed their cams? [Re: TJP] #3080374
09/24/22 09:39 PM
09/24/22 09:39 PM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
Three words...
twocents
Hughes does not make cams. Thet buy them and resell.
When the 1st started had Engle grind them. And it was Engle profiles
My last 3 cams were Engle custom grinds. Just ordered a,Custom Ground Solid Flat Tappet.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Has Comp fixed their cams? [Re: 340SIX] #3080435
09/25/22 07:48 AM
09/25/22 07:48 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
yesterday i did a 180+ mile road trip on an Engle solid flat tappet. probably have 22,000+ miles on it. i really believe, no matter the tappet, that if you want longevity be careful about what lobes you pick. for longevity and reliable use i like some of those old crane profiles. some of those old crane lobe profiles are still being ground out there.
Re: Has Comp fixed their cams? [Re: fourgearsavoy] #3080442
09/25/22 08:28 AM
09/25/22 08:28 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
While there always will be installers who make mistakes this current rash of lifter failures is years old and not due to installer neglect. Across all makes- GM Ford Mopar the failures are high. Not just with cams and lifters but all aftermarket go fast parts. But say- a poorly made MSD box or Pertronix conversion kit wont fill your engine with metal like a wiped cam.
Keep old mopars alive.
Re: Has Comp fixed their cams? [Re: Guitar Jones] #3080447
09/25/22 08:51 AM
09/25/22 08:51 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by Guitar Jones
Roller lifters have been in OEM applications since the late 80's. How much more OE life span can you get? I'm either going to put mechanical rollers in mine or figure out a way to mount the stock magnum spider and yokes in my LA block so I can use stock magnum lifters, or I may just build a stroker magnum, I haven't decided yet.
I am going down that same route. I've been asked why, why don't you just use a Magnum engine and be through with it? If I can pull this off with a 360, there is no reason I can see that you couldn't do it on a 340. Stock exterior appearance with a modern, proven, streetable, valve train. That is the ultimate goal. Then I've been told I'll be giving up all that potential horsepower with this arrangement. Not everything needs 500 hp. Just my twocents
Re: Has Comp fixed their cams? [Re: 6PakBee] #3080451
09/25/22 09:08 AM
09/25/22 09:08 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
The good news is the 318/360 Magnum was made from 1993 to 2003 and currently can EASILY be found in any pick and pull yard.
Re: Has Comp fixed their cams? [Re: 340SIX] #3080514
09/25/22 01:13 PM
09/25/22 01:13 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
just to clarify, I did not say Hughes made their own cams. My point was a smaller supplier like hughes is going to be real careful on choosing their supplier. I also wonder if it is the Cam or Lifter causing the issue shruggy years ago there were limited manufactureres on lifters. not sure if that's still true today beer
Re: Has Comp fixed their cams? [Re: 6PKRTSE] #3080545
09/25/22 02:58 PM
09/25/22 02:58 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Originally Posted by 6PKRTSE
We always get our hyd f.t. cams ground on steel cores at an extra cost or pay for the extra nitride process on cast cams.
I paid the extra money for the nitride process twice and they lasted an extra 5 minutes. So the last time I bought the steel core and the tool steel lifters.
2011 Drag Pak Challenger
Re: Has Comp fixed their cams? [Re: rickseeman] #3080558
09/25/22 03:37 PM
09/25/22 03:37 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
My last 2 solid flat cams had EDM lifters and they both lived until I decided to change them. Maybe there is something to this little oil hole shruggy
Has anyone here heard of a failure when using EDM lifters?
Gus beer
64 Plymouth Savoy
Dana 60
Re: Has Comp fixed their cams? [Re: rickseeman] #3080570
09/25/22 04:32 PM
09/25/22 04:32 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a Comp XE292 hyd f.t. in my Charger. I broke it in with outer springs only. After break in I put the inner springs back in and has been fine since. I have around 55,000 miles on it so far.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Has Comp fixed their cams? [Re: 6PKRTSE] #3080649
09/25/22 09:20 PM
09/25/22 09:20 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
How long ago was the cam purchased (in years)? Just asking as they WERE a good source wink
Re: Has Comp fixed their cams? [Re: TJP] #3080770
09/26/22 10:21 AM
09/26/22 10:21 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Wow, thinking back on it more now I guess that this engine has been back together since 2007. Man, how time flies as you get older.
Re: Has Comp fixed their cams? [Re: 6PKRTSE] #3080802
09/26/22 11:55 AM
09/26/22 11:55 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Quote
.Man, how time flies as you get older.
The older you get the faster you get older
Re: Has Comp fixed their cams? [Re: 6PKRTSE] #3080996
09/26/22 09:41 PM
09/26/22 09:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
In 2007 they were still a reputable company IMO. they started hitting the shi--er about 7 years back maybe a bit earlier.
Re: Has Comp fixed their cams? [Re: GomangoCuda] #3083299
10/04/22 04:44 PM
10/04/22 04:44 PM
moparx Offline
moparx  Offline
Originally Posted by GomangoCuda
Quote
and "it's friday again, already !".................. eek biggrin panic laugh2
beer
Re: Has Comp fixed their cams? [Re: rickseeman] #3083663
10/05/22 08:33 PM
10/05/22 08:33 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Youtuber out of Canada named D and D Speed shop installed a Hyd flat tappet Thumper cam in a smogger 454 about 2 months ago. He just released a video of a ground to a pulp lifter. https://www.youtube.com/watch?v=4WfDM-nonLQ
Re: Has Comp fixed their cams? [Re: 2boltmain] #3083670
10/05/22 09:05 PM
10/05/22 09:05 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Hard call on that one, guy does not seem that well versed on much.
STOP POTATO HATE!
Page 3 of 4 1 2 3 4
