1971 leaf springs #3080708
09/26/22 01:18 AM
09/26/22 01:18 AM
USA
1971d21 Offline OP
1971d21  Offline OP
USA
Who makes the most accurate and original looking rear leaf springs
For a 1971 R/T Challenger to go back stock and for the correct factory stance?
Also, do they have the correct factory PN on them
Thanks for any info.
Re: 1971 leaf springs [Re: 1971d21] #3080734
09/26/22 08:01 AM
09/26/22 08:01 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I’ve heard Eaton springs has the most accurate springs. I believe they were even OEM “back in the day”.
They do not have the original part numbers on them, nor does any spring manufacturer make a Chrysler licensed to put their part number on it spring.
However, Tony’s Parts sells bottom leafs with original part numbers that can be used to replace the lower leaf, to build your own correct reproduction leaf springs, if you have a car that was equipped with one of the part number repro leafs he sells. He sells the leafs for ‘71 V code and hemi cars.
https://www.tonysparts.com/all-part...-6bbl-Hemi-Lower-Leaf-Springs-p372008385
Re: 1971 leaf springs [Re: Mastershake340] #3081663
09/29/22 12:13 PM
09/29/22 12:13 PM
USA
1971d21 Offline OP
1971d21  Offline OP
USA
Where is Eaton Leaf Springs based out of?
TIA
Re: 1971 leaf springs [Re: 1971d21] #3081779
09/29/22 07:43 PM
09/29/22 07:43 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
TIA
If we are talking about the same company, it's Eaton Detroit Spring. And they are indeed in Detroit.
https://www.eatondetroitspring.com/
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
