Painting cabinets
#3080652
09/25/22 09:24 PM
09/25/22 09:24 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
I am trying to paint my kitchen cabinets.
I want to fill in the woodgrain and have a semi gloss finish.
It has been a fiasco.
I used Aquacoat grain filler and Valpar oil enriched cabinet enamel.
I filled, sanded, filled, sanded, then filled and sanded again. And then repeated.
Figured I had a pretty smooth surface.
Then I tried to paint it. Spray gun wouldn't work, too thick and nothing will thin it. Brushing left streaks so I settled on a foam roller.
Seems to be better but even at 2 coats you can still see grain. Also the face is oak and the sides are sanded whiteboard 3/4" plywood. It is noticeable how the wood absorbs the paint differntly.
If it were a car I'd use a high build primer but everything I have tried didn't work well.
Any good suggestions?
Re: Painting cabinets
[Re: Stanton]
#3080678
09/25/22 10:35 PM
09/25/22 10:35 PM
IMGTX
you could use an airless sprayer like a wagner The can said it could be sprayed hut it wouldn't spray worth a crap. I looked at a can today and the label changed to say a 2000 psi airless sprayer for spraying. I started looking and for one to do it right would cost way too much. In my opinion oak was never meant to take paint. Pine can take paint without the grain showing as long as there are NO knots. Poplar will also take paint. Plywood ... forget it.
Maybe shoot everything with a coat of truck bed liner then paint it ... it won't be smooth but it'll hide the grain and be consistent !! Ouch Not what I wanted to hear but more importantly it is what I need to hear. Thank you. I am looking at maybe trying this instead of bed liner. Is it any good?
[Re: IMGTX]
#3080705
09/26/22 12:15 AM
09/26/22 12:15 AM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
I’ll try to help, been painting cabinets for over 40 years, I have a cabinet business. Oak can be filled with a grain filler, it’s a very thick paint, it’s spread in with a squeegee. Then block sanded but here’s the secret trick. Get a pack of the razor box cutting blades, the ones that are beveled on both sides. Used like a squeegee to scrape across the finish and it’ll leave it flat and smooth, you’re taking off the high spots but leaving the grain filled. Work with the back of a door to get the hang of it. Then beg borrow steal cabinet grade catalyzed lacquer. Then spray with a good HPLV garden hose gun-turbine, you might be able to rent one. I’ve used the same one forever, Croix brand but most all are the same. After the first coat I go back over with the blade again, dust off, spray the last coat, I thin 2-1 with high grade lacquer thinner. Dries in 30 minutes or less but hardens up over 7 days. M L Cambell is the paint name. Never Never use polyurethane that’s for floors! Any latex is junk This filler works ok
