which oil pump drive shaft for melling HV63 #3080602
09/25/22 06:20 PM
09/25/22 06:20 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Which Milodon oil pump drive shaft with melling 63HV on a lo deck? I'm looking at the 21525, not sure on the length.
Re: which oil pump drive shaft for melling HV63 [Re: mopar dave] #3080606
09/25/22 06:37 PM
09/25/22 06:37 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, the stock length. That one is stock length and has a bronze gear.
2011 Drag Pak Challenger
Re: which oil pump drive shaft for melling HV63 [Re: rickseeman] #3080608
09/25/22 06:46 PM
09/25/22 06:46 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks. Ill will get it and pump ordered.
Re: which oil pump drive shaft for melling HV63 [Re: mopar dave] #3080609
09/25/22 07:03 PM
09/25/22 07:03 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Just a note, the HV pump also has the high pressure spring in it
Re: which oil pump drive shaft for melling HV63 [Re: CSK] #3080637
09/25/22 08:50 PM
09/25/22 08:50 PM
Mt Morris Michigan
Mt Morris Michigan
Does that matter? I'm replacing a Milodon aluminum pump. I think it has the heavy spring as well. Thanks for the heads up.
