Re: Tunnel Ram Carbs
[Re: clovis]
#3080498
09/25/22 12:16 PM
09/25/22 12:16 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
[Re: Hot 340]
#3080581
09/25/22 05:15 PM
09/25/22 05:15 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
Sideways mounted in much easier.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: clovis]
#3080584
09/25/22 05:25 PM
09/25/22 05:25 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I remember seeing a transfer tube on a factory Holley dual feed from a Cobra Jet Mustang before. I think a found a pic. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3080600
09/25/22 06:13 PM
09/25/22 06:13 PM
Posts: 554 Kentucky
clovis
Kentucky
Savoy, thanks for the picture, as that does answer what I was asking. It actually has me processing the idea of making a hard line from some brake line, but I think I may have enough fittings already to make it up in a braided line.
I will have to plug the transfer tube, which I did stick an 1/8” NPT tap in the hole it seemed like it would work. I’ll do some measuring just to confirm. I was hoping I could tap them without having to drill out the step for where transfer tube sits, so in case it didn’t work I can go to plan B and just run the 1850’s. A gentlemen that goes by “Tuner” over on Speed-Talk has a recipe for modifying the blocks in the 1850 and adding the balance tube which is supposed to help. Based on how well the other information I have used from him has worked, I would give his recipe a try.
I have had a tunnel ram on the car before with the 451, and used the 1850’s then switched to the 4224. The 4224 picked up a tenth, so for the cost to buy a pair now I would stick with the 1850’s.
I did quick search in ebay and there are some linkages now for around $100, so that may be a solid plan C. Again, I was hopping not to have to go that route since it not only has extra expense for the linkage, but would require more cut in the hood (already cut for inline) and possibly a different scoop.
Thanks again for all the help.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
