Re: W9 Best 4150 size carb?
[Re: Dragula]
#3079790
09/22/22 10:25 PM
09/22/22 10:25 PM
Posts: 43,272 Bend,OR USA
Cab_Burge
For a 440ci W9 small block that revs to around 7800, what size carb? I can tell you, its bigger than 950, but curious what others have run. Time for you to find out Enjoy
[Re: Dragula]
#3079791
09/22/22 10:30 PM
09/22/22 10:30 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I don't think i would run anything smaller than a dominator.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3079793
09/22/22 10:37 PM
09/22/22 10:37 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My little 408 loves it’s 1000cfm carb but I only shift at 6700 rpm.
[Re: Dragula]
#3079813
09/23/22 01:10 AM
09/23/22 01:10 AM
Posts: 31,061 Oregon
AndyF
For a 440ci W9 small block that revs to around 7800, what size carb? I can tell you, its bigger than 950, but curious what others have run. Do you know how much power it makes? If you know how much power then you can do a rough conversion to CFM.
[Re: justinp61]
#3079927
09/23/22 11:57 AM
09/23/22 11:57 AM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Bigger the better. Have yet to put a bigger carb on any smallblock I have ever had, and not picked up.
[Re: Dragula]
#3079953
09/23/22 01:14 PM
09/23/22 01:14 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
We run a carb with a 2.45" throttle plate on the Vette with is a good amount smaller than your engine is. Bigger for all out race stuff is usually the better option. As for how big that depends on the combo and power. If I were "stuck"on a 4150 type carb I would look at the BLP stuff or get Em Garage twin blades. I run a twin blade on the B1
[Re: Dragula]
#3079984
09/23/22 02:07 PM
09/23/22 02:07 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
So it might not be too outlandish to try my 1250 Dominator on it....Maybe knock some of the squirterr out of it. Does your intake have a dominator flange?
[Re: Dragula]
#3079994
09/23/22 02:32 PM
09/23/22 02:32 PM
justinp61
W. Kentucky
No, his intake is 4150....I have a 2" and 1" tall 4500 adapters.... When I built my 434 Brett told me that I needed a dominator, but my intake has a 4150 flange. He told me to run the 4150 and not a Dominator on an adapter.
[Re: justinp61]
#3080050
09/23/22 04:45 PM
09/23/22 04:45 PM
Posts: 1,366 Out of the State of Confusion
blue_stocker
Here's a formula if you care to try the mathmatical way...
The formula for calculating how much CFM (cubic feet per minute) your engine requires is: CFM = Cubic Inches x RPM x Volumetric Efficiency ÷ 3456
OR
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
[Re: blue_stocker]
#3080082
09/23/22 06:54 PM
09/23/22 06:54 PM
Posts: 4,210 New York
polyspheric
New York
The N/A CFM calculator is accurate for a V8* (assuming a single plane manifold) in that it gives the result of the formula. So, of course, that's true whether the manifold is "hood clearance" height, or tunnel ram, since no correction is made for plenum volume. * For 1, 2, 3, 4, 5 or 6 cylinder engines the demand is slightly higher.
It also assumes that the 4 bbl. carburetor is designed to operate accurately with a working vacuum of 1.5 Hg" (1 & 2 bbl. are rated at 3.0 Hg"). A carburetor’s CFM rating is only accurate if your individual engine produces the rated vacuum with that carburetor. If not, the carburetor flows a different volume, and is therefore somewhat self-adjusting. An engine will draw more CFM that its rating from a carburetor smaller than the traditional calculations (viz., a 440" V8 with a 500 AFB will not completely “run out of steam”), and less CFM than its rating from a carburetor larger than the traditional calculations (viz., a 1050 Holley on a 300" V8 will flow less than 1050 CFM). If the carburetor's vacuum in service falls below 1.5 Hg. the booster and venturi system timing is disturbed, and the emulsion function (A:F curve with rising RPM) will change, generally becoming leaner.
Boffin Emeritus
[Re: polyspheric]
#3080369
09/24/22 09:31 PM
09/24/22 09:31 PM
Posts: 2,521 PA
moparacer
PA
Dominator.....
When I seen W9 and 4150 I was like, nope.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
