W9 Best 4150 size carb? #3079754
09/22/22 08:41 PM
09/22/22 08:41 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
For a 440ci W9 small block that revs to around 7800, what size carb? I can tell you, its bigger than 950, but curious what others have run.
Re: W9 Best 4150 size carb? [Re: Dragula] #3079790
09/22/22 10:25 PM
09/22/22 10:25 PM
Time for you to find out up wrench Enjoy up
Re: W9 Best 4150 size carb? [Re: Dragula] #3079791
09/22/22 10:30 PM
09/22/22 10:30 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't think i would run anything smaller than a dominator.
68 Barracuda Formula S 340
Re: W9 Best 4150 size carb? [Re: Bad340fish] #3079793
09/22/22 10:37 PM
09/22/22 10:37 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
My little 408 loves it’s 1000cfm carb but I only shift at 6700 rpm.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: W9 Best 4150 size carb? [Re: Dragula] #3079810
09/23/22 12:10 AM
09/23/22 12:10 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I use to run a 1050, turning 7000. Worked perfectly.
Re: W9 Best 4150 size carb? [Re: Dragula] #3079813
09/23/22 01:10 AM
09/23/22 01:10 AM
AndyF Offline
AndyF  Offline
Do you know how much power it makes? If you know how much power then you can do a rough conversion to CFM.
Re: W9 Best 4150 size carb? [Re: AndyF] #3079826
09/23/22 06:19 AM
09/23/22 06:19 AM
Dragula Offline OP
Dragula  Offline OP
The power is deceiving as its all over the map right now....Tough to get a good idea of what its going to do.
Re: W9 Best 4150 size carb? [Re: Dragula] #3079844
09/23/22 08:10 AM
09/23/22 08:10 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
On my 434 I run a BLP BX4 1.59" venturi 4150 main body that I sent to Dom, He added all BLP parts to it, according to BLP its 1050-1100 cfm. I'm only running Indy heads, no W9's.
Re: W9 Best 4150 size carb? [Re: justinp61] #3079927
09/23/22 11:57 AM
09/23/22 11:57 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Bigger the better.
Have yet to put a bigger carb on any smallblock I have ever had, and not picked up.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: W9 Best 4150 size carb? [Re: B3422W5] #3079950
09/23/22 01:11 PM
09/23/22 01:11 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Dominator from your favorite manufacture
Re: W9 Best 4150 size carb? [Re: Dragula] #3079953
09/23/22 01:14 PM
09/23/22 01:14 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We run a carb with a 2.45" throttle plate on the Vette with is a good amount smaller than your engine is. Bigger for all out race stuff is usually the better option. As for how big that depends on the combo and power. If I were "stuck"on a 4150 type carb I would look at the BLP stuff or get Em Garage twin blades. I run a twin blade on the B1
Re: W9 Best 4150 size carb? [Re: Al_Alguire] #3079956
09/23/22 01:17 PM
09/23/22 01:17 PM
Dragula Offline OP
Dragula  Offline OP
So it might not be too outlandish to try my 1250 Dominator on it....Maybe knock some of the squirterr out of it.
Re: W9 Best 4150 size carb? [Re: Dragula] #3079984
09/23/22 02:07 PM
09/23/22 02:07 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Does your intake have a dominator flange?
Re: W9 Best 4150 size carb? [Re: justinp61] #3079992
09/23/22 02:26 PM
09/23/22 02:26 PM
Dragula Offline OP
Dragula  Offline OP
No, his intake is 4150....I have a 2" and 1" tall 4500 adapters....
Re: W9 Best 4150 size carb? [Re: Dragula] #3079994
09/23/22 02:32 PM
09/23/22 02:32 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
When I built my 434 Brett told me that I needed a dominator, but my intake has a 4150 flange. He told me to run the 4150 and not a Dominator on an adapter.
Re: W9 Best 4150 size carb? [Re: justinp61] #3080050
09/23/22 04:45 PM
09/23/22 04:45 PM
Out of the State of Confusion
blue_stocker Offline
Here's a formula if you care to try the mathmatical way...
The formula for calculating how much CFM (cubic feet per minute) your engine requires is: CFM = Cubic Inches x RPM x Volumetric Efficiency ÷ 3456
OR
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: W9 Best 4150 size carb? [Re: justinp61] #3080073
09/23/22 06:04 PM
09/23/22 06:04 PM
I've had several 4150 intakes changed over to 4500 bolt patterns to use Dominator carbs on up scope wrench
Re: W9 Best 4150 size carb? [Re: blue_stocker] #3080082
09/23/22 06:54 PM
09/23/22 06:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The N/A CFM calculator is accurate for a V8* (assuming a single plane manifold) in that it gives the result of the formula.
So, of course, that's true whether the manifold is "hood clearance" height, or tunnel ram, since no correction is made for plenum volume.
* For 1, 2, 3, 4, 5 or 6 cylinder engines the demand is slightly higher.
It also assumes that the 4 bbl. carburetor is designed to operate accurately with a working vacuum of 1.5 Hg" (1 & 2 bbl. are rated at 3.0 Hg"). A carburetor’s CFM rating is only accurate if your individual engine produces the rated vacuum with that carburetor. If not, the carburetor flows a different volume, and is therefore somewhat self-adjusting.
An engine will draw more CFM that its rating from a carburetor smaller than the traditional calculations (viz., a 440" V8 with a 500 AFB will not completely “run out of steam”), and less CFM than its rating from a carburetor larger than the traditional calculations (viz., a 1050 Holley on a 300" V8 will flow less than 1050 CFM).
If the carburetor's vacuum in service falls below 1.5 Hg. the booster and venturi system timing is disturbed, and the emulsion function (A:F curve with rising RPM) will change, generally becoming leaner.
Boffin Emeritus
Re: W9 Best 4150 size carb? [Re: polyspheric] #3080369
09/24/22 09:31 PM
09/24/22 09:31 PM
PA
moparacer Offline
moparacer  Offline
PA
Dominator.....
When I seen W9 and 4150 I was like, nope.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: W9 Best 4150 size carb? [Re: Dragula] #3080662
09/25/22 09:47 PM
09/25/22 09:47 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’d try this…..
