Mopar transmission ID
#3079458
09/21/22 10:03 PM
09/21/22 10:03 PM
Posts: 643 Toronto, Ontario, Canada
plazomat
Hey all,
Hoping you can help me ID this transmission - supposed to be a 727 behind a small block. I can't seem to cross this number anywhere on the google...PK282931 7L 2540 0706
Re: Mopar transmission ID
[Re: 6bblgt]
#3079472
09/21/22 11:10 PM
09/21/22 11:10 PM
Posts: 1,270 New York, USA
Chargerfan68
New York, USA
Also, the 2540 is the “ten thousand day” date code i think And the 0706 should be the unit number of the day “i think”
[Re: plazomat]
#3079630
09/22/22 12:14 PM
09/22/22 12:14 PM
Posts: 26,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
None of my sources show a 2829xxx, the numbers jump from 2801xxx to 2892xxx. Build date is early '69...timing hole is SB truck or van.
[Re: John_Kunkel]
#3079642
09/22/22 12:51 PM
09/22/22 12:51 PM
Posts: 3,208 Michigan
A727Tflite
2829317 first appeared as a production trans for the compact truck (A100/108) in 1967. It also appears as a production unit under the same p/n for 1968
The date code means one thing and only one thing - when the unit was made, not what model year it fits.
Looking at 2540 date code that is July 11, 1968. Tight but it could have been installed in a 1968 vehicle.
Could be a service unit for a warranty replacement back then.
