MSD Ready to Run #3079688
09/22/22 04:38 PM
09/22/22 04:38 PM
White Plains NY
VitaminCRunner Offline OP
White Plains NY
Went through an issue with my Runner where it would run then stall, run ok , then run like crap. Took the dist cap off and it was all corroded from some MSD issue with lack of ventilation. Changed cap, wires rotor no difference. Did all the electrical tests, changed coil, voltage regulator, even rebuilt the 6 pack carbs still the same. Finally pulled the distributor a MSD ready to run. Figured i would swap out the module but MSD doesn't list a replacement so i called. I got some stiff who read me a part # that cost $150. When I googled it was for a Ford so i called back to confirm. This time i got a decent person who told me they were really hard to change as they had to be sodered in and that MSD has a repair program where you send the entire distributor to them and they diagnose and repair for no more than $140. Sent it to them and they called 2 weeks later saying the module and vacuum advance tested bad so they replaced both for $100. I bought the unit new 25 years ago so this seems pretty fair. A new one today with inflation is $600 which im not sure can be justified.
Put the distributor back in and car runs like a top. Just thought i would share in case someone on the board has a similar issue.
Re: MSD Ready to Run [Re: VitaminCRunner] #3079692
09/22/22 04:50 PM
09/22/22 04:50 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I would get a Mancini Racing ready to run at 169.00 before a MSD.
Re: MSD Ready to Run [Re: NITROUSN] #3083266
10/04/22 03:18 PM
10/04/22 03:18 PM
moparx Offline
moparx  Offline
who manufactures those ?
beer
Re: MSD Ready to Run [Re: moparx] #3083296
10/04/22 04:38 PM
10/04/22 04:38 PM
N
NITROUSN Offline
NITROUSN  Offline
N
beer
Not sure. They sure seem identical to MSD.
Re: MSD Ready to Run [Re: moparx] #3083301
10/04/22 04:46 PM
10/04/22 04:46 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
beer
They look like the Pro Comp and several other Chinese offerings.
Re: MSD Ready to Run [Re: John_Kunkel] #3083343
10/04/22 06:47 PM
10/04/22 06:47 PM
moparx Offline
moparx  Offline
i kind of figured chinesium was in the mix............
when ain't it used in electronics these days ? shruggy
beer
Re: MSD Ready to Run [Re: moparx] #3083406
10/04/22 10:03 PM
10/04/22 10:03 PM
N
NITROUSN Offline
NITROUSN  Offline
N
beer
Wonder where MSD dizzys are made.
Re: MSD Ready to Run [Re: NITROUSN] #3083414
10/04/22 10:38 PM
10/04/22 10:38 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I wonder if E Berg. Hy-Rev and distibuters are still good.
They used to be.
Funny thing was ij restored a distributed I got in 1978-79 and ran for many year's in different small block. I just last week went threw it was going to post about it.
Was in the 1972 340 rally challenger I was given as had a blown 727 slipped bad. Si tget gave the car away. Then found the 340 block was cracked.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: MSD Ready to Run [Re: 340SIX] #3085736
10/13/22 11:26 AM
10/13/22 11:26 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I bought a replacement trigger for the regular msd distributor. Then installed it in the ready to run and run a 6al2. Worked fine until I pulled it.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: MSD Ready to Run [Re: John_Kunkel] #3085828
10/13/22 08:55 PM
10/13/22 08:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
Due to experiences with my customers cars over the years I avoid pro comp at all cost. I believe their hard parts ore OK but the electrical stuff is total CR-P. If a car comes in with a pro comp HEI, The pickup coil, module and coil all get swapped out. Every time I have not done so I get a phone call shortly after the customer leaves down beer
Re: MSD Ready to Run [Re: TJP] #3085841
10/13/22 09:29 PM
10/13/22 09:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Also wanted mention that part of my career having been in electronics some which was both Final test and Military QA for Intel an unknown fact to most is that electrical components are tested to different criteria. During these tests there a different classifications assigned depending on a a components response to these tests.
They are sorted into categories such as a Bin1, Bin 2, 3, 4 or 5. bin 5's are rejects.
Bin 1's are considered a premium part and price d accordingly. Bin 2's a bit less, 3's less yet, 4's are the bottom of the barrel and are sold to places like Fry's electronics or other businesses more concerned with cost than performance or reliability.
Some companies will specify their own test criteria such as IBM, Apple, etc. as well as the Military. And OF course are much more expensive than Commercial grade Bin1's.
So when one looks at any electrical device (and likely other things as well) what appears to be physically identical MAY BE, because it is. It was made at the same time, on the same line, by the same workers, equipment etc. But performance and reliability wise tested poorly so it became a Pro comp part instead of an MSD, or other premium replacement item.
The problem is, only those selling and buying the part know what its category or quality is.
These same manufacturing principles apply to just about everything that is mass produced from drill bits to clothing wink
Thoughts to PONDER beer
