Re: Heading to NMCA finals at Indy [Re: RMCHRGR] #3079929
09/23/22 12:01 PM
09/23/22 12:01 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Originally Posted by RMCHRGR
Go get 'em Doug. Looks like it might be humid.
Haha.
Mineshaft or at the least very good air there all weekend.
DA right now at noon is 757 foot. That is mighty good air
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Heading to NMCA finals at Indy [Re: jwb123] #3079951
09/23/22 01:11 PM
09/23/22 01:11 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Steel rods were a thought until Dart stopped making the blocks. So we will stick with aluminum as we cannot replace the block, if a steel rod breaks the block is DONE, this will just take a little clean up and be good. Between the two of us we have literally TENS of THOUSANDS of runs on aluminum rods and this is a first failure like this. The problem here is with the rod material, not throwing anyone under the bus just yet...
Re: Heading to NMCA finals at Indy [Re: Al_Alguire] #3080138
09/23/22 09:59 PM
09/23/22 09:59 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
First off very thankful that the NMC racer that had a horrific crash at the stripe is going to recover. Most important part of the day. My racing. Air was good. Car was slow, 9.13. We ran this morning at 49 degrees. Track didn't hook. 1.40 60ft. Now if we want to change index we have 30 minutes. I've been 9.12, 9.10, 9.23. Not looking good. We decide to stick with the 9.0 index. So we add jet, soften the rear shock rebound and add tire pressure. The result 9.013@148.9. Now we're in the ballpark. Class eliminations start. Feeling pretty good at the tree since last weekend. Rd 1 .003 /9.008 lifting and tightening the stripe. Rd 2 slid in a little deep. Sat on the tree to be safe .042 /9.008 lifting again. Both runs would've been 9.00 flat out. Rd 3 rain. We'll complete in the AM.
Doug
Re: Heading to NMCA finals at Indy [Re: dvw] #3080388
09/24/22 10:49 PM
09/24/22 10:49 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Couple tough ones today. F/X rd 3. My friend Casey Fauss Johnson. Both AA/FX 9.0 index . My .027 to his .034. My 8.988 to his 8.989. I'm done. Manage to qualify for the Victory vs NMCA with a 9.006. 9.009 is #15 out of 16. First rd Tom Hoffman. He's a tough customer. I've had his number for a few years. Not today. We are both .009. His . 018 over to my .006 under. My lights have been good. Car is good. Stripe has been good. Tomorrow's another day.
Doug
Re: Heading to NMCA finals at Indy [Re: dvw] #3080407
09/24/22 11:42 PM
09/24/22 11:42 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
That is two real tough foot brake, no throttle stop, 9.00 index races there.
Keep it up and those runs will turn to wins....
DVW car 7534.
Re: Heading to NMCA finals at Indy [Re: dizuster] #3080503
09/25/22 12:27 PM
09/25/22 12:27 PM
Dang dude, so close up bow Maybe next time wear some shoes with thicker soles grin
Re: Heading to NMCA finals at Indy [Re: Cab_Burge] #3080617
09/25/22 08:07 PM
09/25/22 08:07 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I wa s good all weekend until I wasn't. .025 red 1st rd. against my competitor who had .100 pac. It was great while it lasted. Oh winning 1st rd had a bye into the 3rd. This is the first full year That this car hasn't made at least one final in 9 years. 'll test and be ready next year.
Doug
Re: Heading to NMCA finals at Indy [Re: dvw] #3080624
09/25/22 08:22 PM
09/25/22 08:22 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
Doug
I'm sure the engine issue put you behind a little. They knew you were there. You sure were making some steam on the right hand time slip.
America First!
Re: Heading to NMCA finals at Indy [Re: carnut68] #3080715
09/26/22 01:55 AM
09/26/22 01:55 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Any info on the fellow who went over the wall in the Cuda? Just saw the replay of that wreck. Brutal.
120 in the lights. Lost an engine. Just a reminder of what a "slow" car can do in a bad situation. Not even fast enough to require a full cage.
Re: Heading to NMCA finals at Indy [Re: CMcAllister] #3080732
09/26/22 07:50 AM
09/26/22 07:50 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I talked to his friend whom I know that night. He had surgery on his left hand and arm, cracked pelvis, and may need surgery on his right arm/shoulder. I heard from other sources that it lost a freeze plug. That concurs with what I saw. Not much liquid scrubbing during clean-up. It looked like it lost water out of the left side of the engine in the video.
Doug
Re: Heading to NMCA finals at Indy [Re: dvw] #3080781
09/26/22 10:59 AM
09/26/22 10:59 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Doug
Sounds right. Smoke/steam and then it was on ice from there. Sounds like he was banged up, but having seen it, I'd say he was fortunate.
I don't know what for bar/cage he had in it, but it came down on the wall upside down and hit just above the drivers door first. Partially collapsed the roof looks like.
This one will be in the back of my mind when talking to guys about bars and cages in the future. 11 second car. Too slow to get hurt, right?
Re: Heading to NMCA finals at Indy [Re: CMcAllister] #3080875
09/26/22 03:52 PM
09/26/22 03:52 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Here's the weekends runs. The runs marked in red at the top were lift/brake runs that were completed via Crew Chief Pro software.
Doug
Re: Heading to NMCA finals at Indy [Re: dvw] #3080888
09/26/22 05:00 PM
09/26/22 05:00 PM
NW Indiana USA
727specialist Offline
NW Indiana USA
I was there Saturday and Sunday running in the open bracket class. Had a 014 and 010 reaction time in the two time trials Saturday. Ran in the dial for dollars Saturday night dialed 6.55 and ran a 6.54 with a a three. Tried to hit the tree hard in the time trial Sunday and had a 018 red. Kept telling myself to take it easy on the tree in the first round of eliminations but went 014 red.
Still a great weekend the NMCA runs a great program. Saw some people i knew. I was running a fresh 904 behind my 440.
DVW I would like to have met you but didn't know where you were pitted. Keith
