Is it worth swaping magnum heads on my 360 #307941
05/04/09 07:26 PM
05/04/09 07:26 PM
NE Oklahoma
71valiant Offline OP
NE Oklahoma
I have a 360 with 480/480 lift cam, headers, rpm airgap, stock pistons etc. I recently aquired a 1999 5.9 motor. Is it worth the swap to put the heads on my LA motor.
Re: Is it worth swaping magnum heads on my 360 [Re: 71valiant] #307942
05/05/09 09:45 AM
05/05/09 09:45 AM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I say yes, it will give you a bit more compression & better flowing ports, 1.6 rockers ETC.. On the down side you loose your airgap unless you re drill your magnum heads for the La pattern. I did a set & did not like how they turned out ( I used the same size bolts as the La & they would of had more meat with a smaller bolt)
