Tie Rod Casting Numbers #3078347
09/18/22 11:01 AM
09/18/22 11:01 AM
Land of 10,000 Lakes
44D6PAKCUDA Online content OP
44D6PAKCUDA  Online Content OP
Can someone tell me what the difference is between tie rod ends with casting numbers 2072434 and 3659010? They look the same but is one correct for earlier cars or ......
Re: Tie Rod Casting Numbers [Re: 44D6PAKCUDA] #3078406
09/18/22 01:08 PM
09/18/22 01:08 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
is one inner & one outer shruggy
Re: Tie Rod Casting Numbers [Re: 6bblgt] #3078411
09/18/22 01:16 PM
09/18/22 01:16 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
most likely an internal change
Re: Tie Rod Casting Numbers [Re: 6bblgt] #3078413
09/18/22 01:17 PM
09/18/22 01:17 PM
Yes,I have 2 inner and 2 outer and all 4 have the same casting number.I'm thinking there are 1968-9 with the "207" starting numbers,although not the part number.
Re: Tie Rod Casting Numbers [Re: 44D6PAKCUDA] #3078723
09/19/22 01:47 PM
09/19/22 01:47 PM
moparx Offline
moparx  Offline
i am going to throw out a wild guess here, but i "think" the 207 number would be for the late 60's cars, while the 300 series numbers would be for the 70's era cars.
am i off base here ? shruggy
please correct my thinking if i am.
beer
