1968 charger master cyl ...with power disc brakes #3077838
09/16/22 02:22 PM
09/16/22 02:22 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ok.
Anyone able to identify the attached master cyl.
I built this car for a client several years ago. And he now has a leak in the rear of the master cylinder.
I thought i used raybestos 36283 .....BUT. that number the lines exit fenderwell side.
The one on the car exits engine side.
And i no longer am able to get into old pc files to look it up
Re: 1968 charger master cyl ...with power disc brakes [Re: gtx6970] #3077855
09/16/22 03:39 PM
09/16/22 03:39 PM
CrazyD Offline
CrazyD  Offline
Re: 1968 charger master cyl ...with power disc brakes [Re: CrazyD] #3077857
09/16/22 03:45 PM
09/16/22 03:45 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Attached PDF document
Re: 1968 charger master cyl ...with power disc brakes [Re: 6PakBee] #3077917
09/16/22 08:12 PM
09/16/22 08:12 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Originally Posted by 6PakBee
That chart is for oem units...which this is not.
I know i didnt use a reman.
But i cant remember which one i used back then
Re: 1968 charger master cyl ...with power disc brakes [Re: gtx6970] #3077921
09/16/22 08:19 PM
09/16/22 08:19 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Somebody was selling one with the outlets on the engine side around 10, 12 years ago. From China. I don’t think they’re available anymore.
I guess you either use a 36283 and reconnoiter the lines, or rebuild what you have.
To further complication matter afaik after market MC kits are not available anymore.
So either look for NORS or buy a 36283 and pirate the piston assemblies to rebuild the old MC.
Re: 1968 charger master cyl ...with power disc brakes [Re: Mastershake340] #3077989
09/16/22 11:23 PM
09/16/22 11:23 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ok, Thanks.
Ive passed said info along.
And I think he is going to just buy a 36283 and buy new master cyl lines and move them to the fender side and call it done
Re: 1968 charger master cyl ...with power disc brakes [Re: gtx6970] #3078004
09/17/22 02:10 AM
09/17/22 02:10 AM
Weren't all the Hemi lines on the other side of both type master cylinders, drums only and rear drums with front disc brakes?
Why not buy a good rebuild kit and fix that one work wrench
I would up
Re: 1968 charger master cyl ...with power disc brakes [Re: gtx6970] #3078005
09/17/22 02:56 AM
09/17/22 02:56 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bill I looked through a lot of photos of '68 B-bodies with power brakes, not sure if any, some or all were disc or drums but one thing that stuck out (pun in a moment) was ALL of the brake lines exited on the engine side of the master cylinders. Then it hit me why they might be on the engine side. The power brake booster moves the master cylinder forward and this puts the brake lines right over the top of the shock and hinders the fender side brake line master cylinders from exiting and going straight down to the proportioning valve. Seems to me this may be the reason for the exit on the engine side on power boosted brakes??? I know my '69 GTX with power disc brakes has the brake lines exit on the engine side and I remember someone saying that was correct for power brakes, drums and discs. Now I see why with the forward location of the master cylinder over the shock inner fender.
Mike
Re: 1968 charger master cyl ...with power disc brakes [Re: Mastershake340] #3078013
09/17/22 07:37 AM
09/17/22 07:37 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
This is what I have found. I bought a couple of spare ones back then. The only ones I’ve been able to buy lately are the fender side exit lines. The factory used engine side exit masters cly on wedge head cars and fender side exit on hemi engine cars. There has been many wedge head cars found with fender side exit masters, though,especially on Superbirds. The master cly shown in the above post are an aftermarket casting made with the ability for machining the lines for either side. Mopar never made one like that.
Re: 1968 charger master cyl ...with power disc brakes [Re: fastmark] #3078020
09/17/22 08:51 AM
09/17/22 08:51 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Im just trying to buy this 69 charger R/T and went through the pics here's the master that was on it. Dont know if that was orginal, didn't ask, but power brakes with fender pointed lines.
Ok I cant'seem to post the pic, its a web file, it says its blocked sorry
Re: 1968 charger master cyl ...with power disc brakes [Re: gygeneral] #3078033
09/17/22 09:46 AM
09/17/22 09:46 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Just throwing this out, in '67 if you ordered power disc brakes in a 'B' body you got the "Hemi" booster with the "Hemi" master cylinder. Here is a '67 GTX with a 440 and power front discs.
Re: 1968 charger master cyl ...with power disc brakes [Re: fastmark] #3078138
09/17/22 03:38 PM
09/17/22 03:38 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I think he is going to open it up.
And see if its buildable.
The decide how to proceed from there.
Re: 1968 charger master cyl ...with power disc brakes [Re: gtx6970] #3078146
09/17/22 04:08 PM
09/17/22 04:08 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bill my '69 GTX's power disc brake master cylinder that I'm certain is the original. SPD December 16, 1968.
The second image is how it was when I bought the car from the original owner. shock blush
I'll check when I get a chance later for the part number.
Mike
Re: 1968 charger master cyl ...with power disc brakes [Re: gtx6970] #3078177
09/17/22 06:28 PM
09/17/22 06:28 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bill the casting number on my original '69 disc brake master cylinder is 2226821 and is listed for '67 -'69 B-body with disc brakes. It looks pretty much like the one in your photo and the 2223821 master cylinders are difficult to find even used. If he's not concerned about "numbers" find a suitable replacement (reman) and sell that one for decent $$$ if it is a 2226821. Personally, I would see about having it professionally rebuilt, again if it is a 2226821 master cylinder. twocents
Re: 1968 charger master cyl ...with power disc brakes [Re: A12] #3078227
09/17/22 10:05 PM
09/17/22 10:05 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Mike.
This is. I repeat NOT an oem castimg master cylinder.
At least i dont remember it being one
Owner is going to pull it off this week and see if these casting numbers are in it.
If thats the case....he may try and rebuild or have it rebuilt
Edit....owner found an nos one.
Turns out the one on the car was indeed an original.
Guessing a Reman unit i came up with.
So it will go in the spares bin.
He wants to find a kit and hang on to it
Just in case
Re: 1968 charger master cyl ...with power disc brakes [Re: gtx6970] #3147341
05/29/23 01:11 AM
05/29/23 01:11 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bill do they offer master cylinder rebuild kits for Bendix master cylinders? Took the GTX out Saturday and I know I filled or topped off the main reservoir (low a few month ago) and then Sunday just out of curiosity I checked it and it was almost dry. I check the garage floor, all of the brake lines and all of the wheels and don't see any sign of brake fluid so I'm guessing it's leaking into the vacuum booster from the first master cylinder seal if that's possible? Going to pull the master cylinder and will probably need to rebuild it if parts are available or find a 2226281 casting Bendix master cylinder but would rather try to rebuild this one as it is the original to the car. All the info says it's an 1-1/8" bore. I could maybe find something that works for now and hopefully find some place reliable to rebuild and return my original? Any recommendations would be greatly appreciated, thanks.
Mike
Re: 1968 charger master cyl ...with power disc brakes [Re: A12] #3147383
05/29/23 09:41 AM
05/29/23 09:41 AM
VA
dragon slayer Offline
VA
Yes you can get kit, though I think they started to get scarce. If your pistons are good, you can also get seals. Orig and orig replacements were 1 1/18" bore.
Below is the data on mc. C body used theses too. The difference was pistons installed. Though you probably would not notice any difference. These are all Bendix units.
2881868 MC Casting 2225621 to Fender 67 All B Body and 68 B with Hemi 4 Piston Bendix
2881870 MC Casting 2226811 to Fender 67-68 C Body Fat and Tall 4 Piston Budd
2883058 MC Casting 2226821 to Engine 68-69 B Body without Hemi 4 Piston Bendix
#1 2944269 MC Casting 2226821 to Engine 68-69 B Body Station Wagon Power Drum
#2 2944376 MC Casting 2225621 to Engine 69 B Body with Hemi 4 Piston Bendix
#3 2883089 MC Casting 2225621 to Fender 69-70 C Body Floating Single Piston Calipers
2944476 MC Casting 2229191 to Fender 70-71 B/E Body with Hemi Fat and Short
#4 2944477 MC Casting 2226821 to Engine 70 B Body without Hemi Floating KH Single Piston Caliper
#5 2944479 MC Casting 2225621 to Fender 70 B Body Taxi Manual Disc has studs
Re: 1968 charger master cyl ...with power disc brakes [Re: dragon slayer] #3147410
05/29/23 12:13 PM
05/29/23 12:13 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
THANK YOU up
Is there a way to determine a rebuild kit part number for a specific casting number or do I search by the master cylinder (i.e., 2883058 MC) number or the casting numbers you provided?
I would need a rebuild kit for: 2883058 MC Casting 2226821 to Engine 68-69 B Body without Hemi 4 Piston Bendix ('69 GTX 440, front power disc brakes)
There are a few listed on eBay but until I take my MC off and apart I don't know what I need to start looking for. On the other hand, I will need to take it apart first to confirm what I need, (duh) but a rebuild kit part number may get me into the right area to search.
Thanks,
Mike
Re: 1968 charger master cyl ...with power disc brakes [Re: A12] #3147574
05/30/23 11:20 AM
05/30/23 11:20 AM
VA
VA
I guess I should start a go fund me page. This is all top secret info I compiled laugh Remember me when I ask a question.
Disc Brakes Repair Kits for 1 1/8” Bore
2808616 MC Kit with 792 Silver/793 Green Pistons 67-68 B Body All Mk662
2808617 MC Kit with 749 Silver/751 Green Pistons 67-68 C Body; Guide on 749 Spring Mk503
#1 3420002 MC Kit with 792 Silver/793 Green Pistons 68-69 B Body Station Wagon Power Drum Mk662
#2 3420117 MC Kit with X/X Pistons 69 B Body and 69 B with Hemi Mk662
3420120 MC Kit with 749 Silver/6877 Gold Pistons 69-70 C Body Mk620
3420967 MC Kit with 749 Silver/6877 Gold Pistons 70 B Body Non-Hemi Mk620
3420968 MC Kit with 9194 Silver/6877 Gold Pistons 70-71 B & E Body Hemi None
3420969 MC Kit with 9174 Gold/748 Green Pistons 70 E Body Non-Hemi 1” Bore None
3420980 MC Kit with X/X Pistons 70 Taxi Manual Disc None
#1 3420002 Has identical pistons as 2808616, but has 2 residual valves since Drum/Drum setup
#2 3420117 May have superseded 2808616 with same pistons; since brake system remained the same
Re: 1968 charger master cyl ...with power disc brakes [Re: dragon slayer] #3147577
05/30/23 11:29 AM
05/30/23 11:29 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Your secret's safe with me, I won't tell anybody if you don't laugh2 THANK YOU this helps greatly beer
Mike
