looking for info on connecting rods, H beams. #3077736
09/16/22 08:57 AM
09/16/22 08:57 AM
Finally a HUSKER again
Moparnut426 Offline OP
Customer brought me a short block to fix, ate 3 lobes off of the cam, long story short, i know its got KB pistons with that goofy compression step, and valve relief, it got a set of H beam rods I believe to be 440 source. but I cant find any definitive info from them on if its a source rod or not. Only thing on the rod is a laser etched number, 3960W.
Customer had a set of Indy heads already bought for it, and is going hydraulic roller, and I know he will be fairly hard on it, and I dont want a parts failures and have read horror story after horror story about Source rods, and Hyperutectic KB pistons.
Can anyone ID these rods?
Re: looking for info on connecting rods, H beams. [Re: Moparnut426] #3077738
09/16/22 09:09 AM
09/16/22 09:09 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Horror stories about 440Source rods? Gulp. I have two sets for Gen II Hemi. What seems to the the major problems?
Re: looking for info on connecting rods, H beams. [Re: Moparnut426] #3077739
09/16/22 09:11 AM
09/16/22 09:11 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
The only horror stories I’ve ever heard about 440source rods came from the OLD I beam rods they used to offer. We warned several members not to use them but they went ahead and tried them with bad results. I personally ran 8.60@155mph with them for 275 passed till I found a crack in the block. The assembly is still going in a street car many years later.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: looking for info on connecting rods, H beams. [Re: pittsburghracer] #3077741
09/16/22 09:12 AM
09/16/22 09:12 AM
PA.
"Little"John
"Little"John
PA.
Ohh and another set went 8.40@160mph. I still have that set.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: looking for info on connecting rods, H beams. [Re: pittsburghracer] #3077743
09/16/22 09:16 AM
09/16/22 09:16 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have over 12 k miles , street strip on my 440 source rods, 512cid LOL
Re: looking for info on connecting rods, H beams. [Re: CSK] #3077744
09/16/22 09:21 AM
09/16/22 09:21 AM
AWESOME!
are these 440 source?
Re: looking for info on connecting rods, H beams. [Re: Moparnut426] #3077762
09/16/22 10:24 AM
09/16/22 10:24 AM
Washington
madscientist Offline
Washington
AWESOME!
It doesn’t really matter. All those rods come off the very same production line. They just get different brand part numbers etched into them. So it doesn’t matter what box they come in they are almost all virtually the same.
Re: looking for info on connecting rods, H beams. [Re: madscientist] #3077763
09/16/22 10:26 AM
09/16/22 10:26 AM
PA.
"Little"John
"Little"John
PA.
I should add I always upgraded the bolts when I ordered them. Cheap insurance as the upgrade was cheap.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: looking for info on connecting rods, H beams. [Re: madscientist] #3077776
09/16/22 11:11 AM
09/16/22 11:11 AM
AWESOME!
I have heard that, but was under the assumption that the higher name brand rods had better machining. I read they come over here as a raw blank, and get machined here.
Re: looking for info on connecting rods, H beams. [Re: Moparnut426] #3077780
09/16/22 11:33 AM
09/16/22 11:33 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
AWESOME!
Yes
Re: looking for info on connecting rods, H beams. [Re: Moparnut426] #3077791
09/16/22 12:15 PM
09/16/22 12:15 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
If your customer chooses to replace those "goofy" pistons I am interested.
Re: looking for info on connecting rods, H beams. [Re: madscientist] #3077796
09/16/22 12:21 PM
09/16/22 12:21 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
AWESOME!
I recall somebody posting a picture on here a long time ago of a bunch of different brand china h beam rods. They were all slightly different. Still may have been forged at the same factory but probably not.
Re: looking for info on connecting rods, H beams. [Re: CSK] #3077797
09/16/22 12:21 PM
09/16/22 12:21 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Going off memory from previous import rod discussions...
No, they don't ALL come from the same factory; there are some very distinct differences between some brands in how they're machined when you compare them up close, e.g. my Eagles vs my K1s
Where the final machining is done has a major influence on the out-of-the-box quality; some companies sell 'em straight from the Chinese box, while others get the semi-finished rods and complete the work in the US. The brands that state clearly they do their final machining on site generally have the better rep for being able to use them as sold... but you gotta look or ask to know for sure.
The only issues I recall w/ 440 Source rods -- and this goes back many years, not necessarily a current problem...
--> the big ends not being round when torqued
--> the small ends being too tight for the pins (which should always be checked and corrected during the build, anyway)
--> possibly as a result of the latter item, the bushings the pins ride in pulling out; this was also a reported issue w/ some RPM International rods, which to my eyes looked identical to the 440 Source pieces (and their crank forgings look identical to me, as well)
wave
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: looking for info on connecting rods, H beams. [Re: Brad_Haak] #3077837
09/16/22 02:21 PM
09/16/22 02:21 PM
NC
440Jim Offline
440Jim  Offline
NC
Brad is right, they are different in both dimensions and machining precision.
Look at the differences in the web thickness, 0.080" to 0.098"; and the beam widths are different too.
NOTE: These dimensions may vary from the same brand with different length rods.
Re: looking for info on connecting rods, H beams. [Re: 440Jim] #3077849
09/16/22 03:15 PM
09/16/22 03:15 PM
NC
440Jim Offline
440Jim  Offline
NC
FWIW,
These are the dimensions on my Molnar 7.100" long H-beam rods (BB Chevy style)
Part 2 Molnar 7.100" connecting rod observations
Re: looking for info on connecting rods, H beams. [Re: 440Jim] #3077865
09/16/22 04:00 PM
09/16/22 04:00 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
cannot tell if that's a ARP bolt, if they are there not 440 source, I have a set of new (latest designed)383-400 rods from 440 source at shop if you need a photo, if anybody wants them $150 free shipping
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: looking for info on connecting rods, H beams. [Re: 440lebaron] #3077882
09/16/22 05:04 PM
09/16/22 05:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
For the rods? Or bolts?
Re: looking for info on connecting rods, H beams. [Re: cudaman1969] #3077935
09/16/22 08:35 PM
09/16/22 08:35 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Thanks guys, the Hemi sets I bought from 440Source were the H-beam variety. Whew, dodged another bullet.
Re: looking for info on connecting rods, H beams. [Re: 6PakBee] #3077941
09/16/22 08:52 PM
09/16/22 08:52 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
my 440source rods,etching is completely different, poor quality, looks hand written
Re: looking for info on connecting rods, H beams. [Re: 440lebaron] #3077973
09/16/22 10:51 PM
09/16/22 10:51 PM
New York, USA
Chargerfan68 Offline
New York, USA
And I’m not 100% sure, but I believe the last 4 sets in the 440Source rotating assys that I’ve dealt with all had only 3 numbers on each rod. I also don’t think those are 440Source. Maybe Scat?
