Re: '67 GTX goes 9.56 @ 137
[Re: 10secGTX]
#3077563
09/15/22 04:06 PM
09/15/22 04:06 PM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
[Re: GY3]
#3077573
09/15/22 05:09 PM
09/15/22 05:09 PM
Posts: 19,378 Las Vegas
Al_Alguire
Las Vegas
Shes working pretty good as the MPH shows less power than the ET does. Signs of a good working combo...
[Re: Al_Alguire]
#3077576
09/15/22 05:32 PM
09/15/22 05:32 PM
Posts: 31,052 Oregon
AndyF
Shes working pretty good as the MPH shows less power than the ET does. Signs of a good working combo... I think that might be because he has 4.30 gears and it is laying over in the lights since it is past the power peak. Just my guess. He is going to swap over to 3.90 gears to see what happens.
[Re: AndyF]
#3077582
09/15/22 05:47 PM
09/15/22 05:47 PM
Posts: 2,117 Cleveland Ohio
10secGTX
Cleveland Ohio
Shes working pretty good as the MPH shows less power than the ET does. Signs of a good working combo... I think that might be because he has 4.30 gears and it is laying over in the lights since it is past the power peak. Just my guess. He is going to swap over to 3.90 gears to see what happens. Any thoughts on this ... 3.90 gears vs 4.10 I have both sets ..
[Re: 10secGTX]
#3077585
09/15/22 05:55 PM
09/15/22 05:55 PM
Posts: 140 Connellsville
71Demon528
Connellsville
Shes working pretty good as the MPH shows less power than the ET does. Signs of a good working combo... I think that might be because he has 4.30 gears and it is laying over in the lights since it is past the power peak. Just my guess. He is going to swap over to 3.90 gears to see what happens. Any thoughts on this ... 3.90 gears vs 4.10 I have both sets .. Nice car and good pass. Gotta love old heavy Mopar B-Bodies running fast. I'd go 4.10 if it was me.
[Re: 71Demon528]
#3077598
09/15/22 06:28 PM
09/15/22 06:28 PM
Posts: 20,191 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m just curious about how many times a year do you race 1/4 mile. That would help me make up my mind. Beautiful car and fast too.
[Re: 10secGTX]
#3077623
09/15/22 07:14 PM
09/15/22 07:14 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Shes working pretty good as the MPH shows less power than the ET does. Signs of a good working combo... I think that might be because he has 4.30 gears and it is laying over in the lights since it is past the power peak. Just my guess. He is going to swap over to 3.90 gears to see what happens. Any thoughts on this ... 3.90 gears vs 4.10 I have both sets .. Fran I really don't think you would see much of a difference from 4.30 to 4.10s Car is still amazing with a full interior and a 9 inch tire. It really shows how much you work to get this car where it's at. Let me know when you want to do the gear swap you know I'm in Nice pass dude it gets faster every month. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3077643
09/15/22 08:19 PM
09/15/22 08:19 PM
10secGTX
Cleveland Ohio
Shes working pretty good as the MPH shows less power than the ET does. Signs of a good working combo... I think that might be because he has 4.30 gears and it is laying over in the lights since it is past the power peak. Just my guess. He is going to swap over to 3.90 gears to see what happens. Any thoughts on this ... 3.90 gears vs 4.10 I have both sets .. Fran I really don't think you would see much of a difference from 4.30 to 4.10s Car is still amazing with a full interior and a 9 inch tire. It really shows how much you work to get this car where it's at. Let me know when you want to do the gear swap you know I'm in Nice pass dude it gets faster every month. Gus Thank You Gus ... to be completely honest i took the passenger seat out to get to the dash so it is minus the passenger seat. I will contact you asap GUS
[Re: 10secGTX]
#3077661
09/15/22 09:12 PM
09/15/22 09:12 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Hookin' bookin', Fran! One of my fav's......
3.90’s....and SEND IT!
"Any fool can know. The point is to understand"
- A. Einstein
[Re: 10secGTX]
#3077708
09/16/22 12:45 AM
09/16/22 12:45 AM
AndyF
Shes working pretty good as the MPH shows less power than the ET does. Signs of a good working combo... I think that might be because he has 4.30 gears and it is laying over in the lights since it is past the power peak. Just my guess. He is going to swap over to 3.90 gears to see what happens. Any thoughts on this ... 3.90 gears vs 4.10 I have both sets .. My advice would be the 3.90 gears. I don't think you'll see enough difference with 4.10 gears to make it worth the time it takes to swap gears. Put the 3.90 gears in there and see what she does. I think it will pick up a little top end speed and the ET won't change much. It really depends on the torque converter. The 3.90 gears will loosen up the converter a touch which will change some things. It could make the car quicker or slower depending on how the chassis reacts. You might have to adjust the shocks or the tire pressure to keep it launching hard.
[Re: 10secGTX]
#3077717
09/16/22 06:09 AM
09/16/22 06:09 AM
Posts: 2,931 A shed in England
Tig
A shed in England
Shes working pretty good as the MPH shows less power than the ET does. Signs of a good working combo... I think that might be because he has 4.30 gears and it is laying over in the lights since it is past the power peak. Just my guess. He is going to swap over to 3.90 gears to see what happens. Any thoughts on this ... 3.90 gears vs 4.10 I have both sets .. For reference we've just gone from 4:10's to 3:73's (Dana 60). So far we've lost 0.1, 1 mph in the 1/4 and 0.05 in the 60 (going off similar weather conditions). Stalls gone up 800rpm and we have 16% slip at the stripe
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
