Page 7 of 8 1 2 3 4 5 6 7 8
Re: 563ci build specs, what will it make? [Re: Hemi_Joel] #3059145
07/14/22 10:34 AM
07/14/22 10:34 AM
MN
JERICOGTX Offline OP
MN
Originally Posted by Hemi_Joel
Make sure the core plugs are in before you pour! Don't ask me how I know. blush bawling laugh2
https://media.giphy.com/media/3Z1fJKVyqPXbHacR0O/giphy.gif
69 GTX 68 Road Runner
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3059174
07/14/22 12:33 PM
07/14/22 12:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Good luck with it, hopefully it is fixed, the only issue I have seen with pressure testing these bocks is NOT heating them up before you test them. Hopefully you have the problems fixed.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3059381
07/15/22 11:46 AM
07/15/22 11:46 AM
an8sec70cuda Offline
Hope the re-rebuild goes smoothly Jeff! Looking forward to some dyno results and seeing it finished!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 563ci build specs, what will it make? [Re: an8sec70cuda] #3059418
07/15/22 01:49 PM
07/15/22 01:49 PM
MN
MN
Thanks Chip.
The RockBlock arrived early this morning, so I delivered it to the machinist. He’s on vacation for a week after today. I’m planning on being ready for Labor Day weekend. Still have to finish up the floor in the car, paint the scatter shield, and if time allows, paint the new hood for the car.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3077394
09/15/22 06:25 AM
09/15/22 06:25 AM
MN
MN
Just an update on this project. The block was welded, and I was lucky to find a sleeve .010 over, locally. After having the cylinder machined to fit the sleeve, it was pressure tested, and a pin hole leak was exposed. I picked up the block on a Monday, had it welded at work the next day, and in the afternoon, it was back in the machinists shop. Got a call this last Monday, and was told that the spot that was welded was now leaking worse... After work, I picked up the block once again, and something didn't look right. The new weld was much different looking than the previous work. Brought it into work, and the welder knew exactly what happened. He grabbed the wrong filler rod, and used a harder rod by mistake. I dug out the recent weld with a die grinder, and opened up a fairly big area. It was then rewelded, with the proper filler rod, and I delivered the block to the machinist last night. It's been a frustrating journey...
At this point, I just want to get the engine together, dyno test it, and get everything in the car before the snow flies.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3077402
09/15/22 07:26 AM
09/15/22 07:26 AM
tboomer Offline
tboomer  Offline
Good luck Jeff!
Re: 563ci build specs, what will it make? [Re: tboomer] #3077419
09/15/22 08:58 AM
09/15/22 08:58 AM
Man, this thing is fighting you aint it! It'll be worth it in the end...just keep plugging away at it. up
CHIP
Re: 563ci build specs, what will it make? [Re: an8sec70cuda] #3077422
09/15/22 09:05 AM
09/15/22 09:05 AM
MN
MN
Fighting me like an old married couple that hate each other. Just been annoying, and disappointing. Hate not being able to make a pass in the car this year.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3077525
09/15/22 01:34 PM
09/15/22 01:34 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hopefully it woudl out for you. As I have stated my luck with the older indy blocks has not been so good.
Re: 563ci build specs, what will it make? [Re: Al_Alguire] #3077545
09/15/22 03:02 PM
09/15/22 03:02 PM
MN
MN
It will work out. If it was easy, everyone would be doing it. Right?
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3077558
09/15/22 03:38 PM
09/15/22 03:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes sir...Lets hope this is the end of your long road...
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3077590
09/15/22 06:06 PM
09/15/22 06:06 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
The wrong filler rod is a kick in the shorts on top of everything else, ugh.
If you get it together after the MN tracks are closed, would you head south with it to make some passes?
Re: 563ci build specs, what will it make? [Re: Blusmbl] #3077624
09/15/22 07:16 PM
09/15/22 07:16 PM
MN
MN
It’s costly enough to hit the local 1/8th mile track, 50 miles away. No way I’m headed South to test.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3077675
09/15/22 09:27 PM
09/15/22 09:27 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Geez. Jeff, I hope things turn for the better man. The cost, the logistics, and hoping it works out takes all the fun out it. That is definitely frustrating. Good luck.
"Any fool can know. The point is to understand"
- A. Einstein
Re: 563ci build specs, what will it make? [Re: EvilB1Dart] #3077862
09/16/22 03:54 PM
09/16/22 03:54 PM
MN
MN
Thanks Wes. You aren’t kidding about taking the fun out of it. What I wouldn’t give right now to yank the handle on that Liberty trans.
Jeff
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3079506
09/22/22 07:30 AM
09/22/22 07:30 AM
MN
MN
Got a phone call from the machinist on Monday. Finally some good news. The new weld was machined, and then the block pressure tested. Passed with flying colors. The new sleeve was going in, right away, then fill the block with Rock Block, bore and hone the cylinder, and cut the deck. He's hoping to be done with everything by early next week. Since Joel and I did not go on Drag Week this year, I went back to work, to save a couple vacation days. Once the block is back, I'll take a day off and reassemble everything, then take another day off for the dyno appointment. If everything goes well, I should have the car back together before the snow flies. At least I will be ready for next year.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3079507
09/22/22 07:32 AM
09/22/22 07:32 AM
tboomer Offline
tboomer  Offline
Good luck with it Jeff! You sure need to catch a break! I hope to see it down here next year! wave
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3079580
09/22/22 11:05 AM
09/22/22 11:05 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
If my potato harvest job is finished, maybe I’ll see you at Grove Creek, Oct 8th. Good luck with it.
Re: 563ci build specs, what will it make? [Re: Leigh] #3079584
09/22/22 11:11 AM
09/22/22 11:11 AM
MN
MN
Last race at GC is Oct 1-2.
Re: 563ci build specs, what will it make? [Re: JERICOGTX] #3082772
10/03/22 12:31 PM
10/03/22 12:31 PM
MN
MN
Picked up the block on Friday. Have only installed the crankshaft, and one piston. Need to cut the pistons down .005 or buy different head gaskets. Cutting the piston will be faster.
