Master Cylinder Problems
#3077257
09/14/22 04:28 PM
09/14/22 04:28 PM
Posts: 10,706 North Dakota
6PakBee
North Dakota
The master cylinder on my '67 Belvedere is leaking like the Missouri river. Four wheel manual drum application. The M/C has the four studs that go through the firewall with the nuts on the passenger compartment side. I can't find ANY replacement M/C's, even NOS ones that have the studs. Do I have to remove the studs from the old M/C and install them in the new one? The '67 FSM does not address this at all. The '67 parts book does not show a listing for the studs as a separate item. In fact, the photo in the parts book for the manual setup shows the pedal bracket that the studs go through, and the M/C, but no studs in the M/C. Can anyone shed some light on this?
Re: Master Cylinder Problems
[Re: stumpy]
#3077262
09/14/22 04:55 PM
09/14/22 04:55 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Yes….i’ve pressed out the old studs and instalked them on the new m/c on many occassions.
[Re: stumpy]
#3077265
09/14/22 05:04 PM
09/14/22 05:04 PM
6PakBee
North Dakota
Can you rebuild your old one? It isn't hard if you can find a kit. What I'm worried about is that it's the piston seal at the input end that is leaking. When I've encountered this before, the combination of brake fluid and atmosphere has corroded the bore to the point that it's junk. But I'm going to pull the M/C tomorrow and see what the bore condition looks like.
[Re: Chargerfan68]
#3077266
09/14/22 05:05 PM
09/14/22 05:05 PM
6PakBee
North Dakota
Yes….i’ve pressed out the old studs and instalked them on the new m/c on many occassions. That's what I needed to know! I have a rebuild kit on the way but if that route proves unworkable, I think Mr. Press will be my friend! Thanks again.
[Re: 469runner]
#3077382
09/15/22 12:49 AM
09/15/22 12:49 AM
6PakBee
North Dakota
I found NOS M/C's with a Google search. If mine is unrebuildable, I think I will go with NOS and transfer the studs.
[Re: 6PakBee]
#3077607
09/15/22 06:48 PM
09/15/22 06:48 PM
6PakBee
North Dakota
Well, I got it out this afternoon and yes, it has serrated head studs. I honed the bore a bit and it cleaned up really well. I think a kit will make it.
[Re: stumpy]
#3077781
09/16/22 11:42 AM
09/16/22 11:42 AM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Fwiw...The studs will tap out easily with just a small hammer it the rebuild doesn't work for whatever reason...
...FAFO...
[Re: skicker]
#3078082
09/17/22 12:49 PM
09/17/22 12:49 PM
Posts: 19,355 north of coder
moparx
Fwiw...The studs will tap out easily with just a small hammer it the rebuild doesn't work for whatever reason... i did just that when i replaced the master on my buddy's 70 super bee. it was an original drum brake car, but i converted it to discs. the original drum master was a 1" bore, but i put a 1 1/32" bore master on it when doing the conversion. it stops 10 times better now !
[Re: moparx]
#3078208
09/17/22 08:57 PM
09/17/22 08:57 PM
Posts: 15,311 Omaha Ne
TJP
Omaha Ne
Fwiw...The studs will tap out easily with just a small hammer it the rebuild doesn't work for whatever reason... i did just that when i replaced the master on my buddy's 70 super bee. it was an original drum brake car, but i converted it to discs. the original drum master was a 1" bore, but i put a 1 1/32" bore master on it when doing the conversion. it stops 10 times better now ! FYI: it would do even better with a 1" bore or smaller but would require a tiny bit more pedal travel
[Re: TJP]
#3078344
09/18/22 10:58 AM
09/18/22 10:58 AM
moparx
you are correct. however when the swap occurred, he had already purchased everything, so i just installed it. i told him if it were me, i would have gone with a 15/16 [i am a wimp] or 1" master. after the swap was made, he was super happy on how good it stopped he didn't want to change anything, so i left it as it was.
