1 7/8 vs 2" #3076599
09/12/22 02:04 PM
09/12/22 02:04 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
For a big block, when should one consider using 2" primaries instead of 1 7/8"? Is there a certain HP or RPM range?
Re: 1 7/8 vs 2" [Re: DusterKid] #3076601
09/12/22 02:12 PM
09/12/22 02:12 PM
AndyF Offline
AndyF  Offline
I wouldn't use 2 inch headers unless the engine was making over 600 hp. Might not use the larger header until close to 700 hp.
Re: 1 7/8 vs 2" [Re: DusterKid] #3076741
09/12/22 09:46 PM
09/12/22 09:46 PM
Every B and RB motor that I have put bigger primary headers on during engine dyno testing made more HP and torque shock shruggy
I haven't done enough header testing at the track to be able to say the same thing so keep that in mind, dyno testing is just that, testing on a engine dyno, not at the track shruggy
The time slip and the spark plugs don't lie whistling work scope
Re: 1 7/8 vs 2" [Re: AndyF] #3076763
09/12/22 10:47 PM
09/12/22 10:47 PM
PA
moparacer Offline
moparacer  Offline
PA
iagree
I have 2 inch on my engine and its making over 800 lol. Granted they are short, unequal length fender exit headers but they work.
Sometimes too big of a header is just as bad as too small.
Over the years every time I have had a header on the large side the 60 ft seems to have suffered.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 1 7/8 vs 2" [Re: moparacer] #3076788
09/13/22 01:53 AM
09/13/22 01:53 AM
Out of the State of Confusion
blue_stocker Offline
Jere Stahl (Stahl headers) once told me in order to use a 2" primary that engine needs to make a minimum of 550 hp. Since he was the inventor/developer of the equal-lenght/4-into-one header, I think he kinda knew something there. I did some testing at Fremont in the early 90s with my stocker and that pretty much proved right, at least on a stock eliminator car...too big=loss of performance/slower et and mph. I never forgot his conversations nor some of the things he told me. Jere was one inovative and very smart cookie, right there with Harvey Crane, Ed Iskedarian, Bruce Crower, Racer Brown, Gene Winfield and many more of that generation.
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: 1 7/8 vs 2" [Re: blue_stocker] #3076794
09/13/22 05:55 AM
09/13/22 05:55 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
lets throw muffflers into this for back pressure.i use pro parts 2 inch headers on my street car with mufflers.stock 440 with 509 cam 906 heads with tunnel ram 2 660s
Re: 1 7/8 vs 2" [Re: dart games] #3076803
09/13/22 07:30 AM
09/13/22 07:30 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
FWIW, I had:
- 1-3/4 on car when I bought it and kept them when it was a 12-sec car... 450-ish HP
- switched to 1-7/8 when engine got upgraded to run into the low 11s... 550-ish HP
- switched to 2" when another upgrade got solidly into the mid 10s... 600 HP
- keeping the 2" w/ the new engine combo that's making 650+ HP
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: 1 7/8 vs 2" [Re: Brad_Haak] #3076810
09/13/22 07:59 AM
09/13/22 07:59 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
If I remember right the Moparts Engine masters entry made it's best power/torque curve with some no name 1-7/8" headers. Years ago I spoke at length with Ed Henaman of Headers by Ed. One of the ideas he stressed was not to go to big with the tube size and was a great advocate of equal length tubes.
Re: 1 7/8 vs 2" [Re: quickd100] #3076815
09/13/22 08:29 AM
09/13/22 08:29 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Ed paid a lot of attention to the transition from tube to collector too.
A lot !
But he made some nice headers.
I bought a lot of parts from him over the years , but never had a combination that he made headers for.
Re: 1 7/8 vs 2" [Re: tubtar] #3076864
09/13/22 10:57 AM
09/13/22 10:57 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
A lot !
I gave him the details of my motor and chassis and he gave me the recs for tube size and lengths. I then bought the header kit from him. I went down to his shop to pick it up and that's a story in itself.
Re: 1 7/8 vs 2" [Re: AndyF] #3076946
09/13/22 03:16 PM
09/13/22 03:16 PM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 1 7/8 vs 2" [Re: an8sec70cuda] #3077157
09/14/22 09:33 AM
09/14/22 09:33 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The other thing on the 2 inch vs 1 7/8 deal is I don’t think you can go to a 2 inch without automatically getting a 3.5 inch collector
