Page 2 of 3 1 2 3
Re: 60 ft issues [Re: Brad_Haak] #3076229
09/11/22 07:33 AM
09/11/22 07:33 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Thanks Brad. Keystone will have videos up toward the end of the week.
America First!
Re: 60 ft issues [Re: carnut68] #3076237
09/11/22 08:06 AM
09/11/22 08:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I doubt that it separates 8”. Separation is dictated by instant center location. You run Cal tracks, so the I/C is short and high. It’s going to separate. You can slow separation with tighter rear shock rebound. As long as it doesn’t spin that will help. But it will not decrease 60 ft a great amount. You are still in the area where you need power/converter flash/tune to come in earlier. How are you checking the converter flash? Converter can make or break a combo. I would have never bet my 15-1 572 would need over 5700. 6000 flash was worth a solid .10 in ET. Why low power NHRA stockers 60 ft so well? Loose converter, optimized carb, and high starting line ratio.
Doug
Re: 60 ft issues [Re: carnut68] #3076256
09/11/22 09:57 AM
09/11/22 09:57 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: 60 ft issues [Re: Brad_Haak] #3076263
09/11/22 11:00 AM
09/11/22 11:00 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Try more initial timing? Might hit the converter a little harder. Most people running 272 @ .050 are locked out.
Whats the CR 12:1?
Have you verified that the balancer TDC mark is correct and not off a few degrees?
Re: 60 ft issues [Re: dvw] #3076264
09/11/22 11:02 AM
09/11/22 11:02 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Doug
No Cal Tracs just superstock springs. I check flash by slow speed in high gear then wap throttle. The convertor is an 8in ATI. single adjustable Calvert shocks set on 7. The carb is fairly new so I'm still working on it, idle and transition is pretty good, now I have to tune pumps, squirters and wot jetting. We put a known good carb on and it picked up mph it had way more jet and we played with squirters. Just ran out of time. Another all day tnt at the end of the month.
So you think I should bring it off idlefrom to flash convertor harder?
I have never heard the term high starting line ratio? Ok so I researched it. 4.30x 2.74=11.78. According to chart my car should somewhere between 10.00 and 10.25. I learned something new today thanks dvw.
America First!
Re: 60 ft issues [Re: GTX MATT] #3076266
09/11/22 11:05 AM
09/11/22 11:05 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Whats the CR 12:1?
CR is 13:3. Balancer was checked whenever the cam was degreed. Initial is now 29/ 37 total.
America First!
Re: 60 ft issues [Re: Brad_Haak] #3076269
09/11/22 11:09 AM
09/11/22 11:09 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
America First!
Re: 60 ft issues [Re: Brad_Haak] #3076423
09/11/22 10:48 PM
09/11/22 10:48 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Here's a qualifying run for the car in the video during Indy qualifying. It is a very well sorted stocker running a 440. Knowing Doug I guarantee it has the best of everything from top to bottom.
Left Doug Duell 350 C/SA 11.40 .018 1.354 4.148 6.547 102.19 8.632 10.420 125.45
Re: 60 ft issues [Re: carnut68] #3076472
09/12/22 07:13 AM
09/12/22 07:13 AM
Indianapolis, In. area
BTBelvedere Offline
BTBelvedere  Offline
How old are your SS springs? I had a very similar thing happen, the engine ran fine but it kept going slower and slower. I began to break things like u joints, the yoke on the rear end, and even the 65 only extension housing. Someone finally told me that they could see the entire top of the rear tire when I launched. He suggested that I look for "witness marks" on the front of the rear shocks since the rear end wrapped up so much. The shocks were almost smashed. I would have never believed the springs would allow that, but it sure did. After speaking with some stocker friends, they said as soon as the 60's begin to fall off, get new springs. Of course, that was in the days before caltracs.
Re: 60 ft issues [Re: BTBelvedere] #3076487
09/12/22 08:28 AM
09/12/22 08:28 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
About 4 yrs old. Thanks
America First!
Re: 60 ft issues [Re: dvw] #3076494
09/12/22 09:03 AM
09/12/22 09:03 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Here's a screen shot of a pass he made during class runoffs at Indy:
Re: 60 ft issues [Re: Brad_Haak] #3076503
09/12/22 09:43 AM
09/12/22 09:43 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
It's easy to see how much ET is tied to the 60 ft when you compare the above with my Challenger's best pass (from 2008) that ran similar MPH. My 60 was a 1.45x, a full tenth slower than Duell's C/SA car:
60' - 1.454
330 - 4.254
660' - 6.653 at 102.03
1000' - 8.745
1320' - 10.523 at 126.44
Re: 60 ft issues [Re: Brad_Haak] #3076696
09/12/22 07:32 PM
09/12/22 07:32 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
60' - 1.454
330 - 4.254
1000' - 8.745
I'm losing alot. My best mph was 126.1 @ Cecil ET was 10.84. I'm going to work on the carb a little. The Proform 950 had a better 60. We swapped to a Holley 1000 it worked better up top.
America First!
Re: 60 ft issues [Re: carnut68] #3076806
09/13/22 07:37 AM
09/13/22 07:37 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Was the Holley 1000 a downleg or an annular booster version? What was the difference in ET slips between them?
Re: 60 ft issues [Re: Brad_Haak] #3076822
09/13/22 09:01 AM
09/13/22 09:01 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You need to realize that running NHRA stocker or S/S numbers isn't the norm. Nor is it cheap. There are a fleet of experts behind the car in the example. I know Doug. He is a perfectionist. He knows how to chose people to get results. Just wanted to show what is possible.
Doug
Re: 60 ft issues [Re: dvw] #3076828
09/13/22 09:26 AM
09/13/22 09:26 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
You need to realize that running NHRA stocker or S/S numbers isn't the norm... Just wanted to show what is possible.
I understand completely; the info I provided was simply to show how dependent upon the 60 ft we are, not as a "You should be running this quick, too!" to the OP. More like "Here's the Gold Standard; you have room for improvement" grin
Re: 60 ft issues [Re: Brad_Haak] #3077019
09/13/22 07:11 PM
09/13/22 07:11 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Standard out of the box Holley 1000, downleg boosters pig fat at idle 86 pmj, 96smj, 35 P squirter, 37 S. The Proform has T slot restricters.081, IFR .035 moved to lower Pmj 79, Smj 86 it was lean up top. Blue pump cam 33 squirters P and S. It had a better 60.
Proform 11.14 @ 119.7
Holley 10.88 @ 123.7
Timing was 37 total for both passes and the same lane.
I appreciate the help. That's how you learn.
America First!
Re: 60 ft issues [Re: carnut68] #3077196
09/14/22 12:00 PM
09/14/22 12:00 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
This is a huge difference imo.
Especially when you factor in the slower carb had a better 60’ time.
Re: 60 ft issues [Re: fast68plymouth] #3077285
09/14/22 06:54 PM
09/14/22 06:54 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Originally Posted by fast68plymouth
Quote
The slower carb is going to get some jet added. I'm going to increase pvrc channel size then add mj. The car responded well to idle and transition calibration.
America First!
Re: 60 ft issues [Re: fast68plymouth] #3077424
09/15/22 09:10 AM
09/15/22 09:10 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
I’d try opening up the lash .004-.005 and see if that impacted the 60’ time
For perspective on the stall speed....... the Normal T/A 8” Race converter for a 440 bracket race engine would flash about 5600.
That configuration was derived long before there were Indy heads.......... so it was lotsa stall....... with small heads.
Typically, the trend would be to increase the stall speed as the heads got bigger.
iagree iagree iagree After watching the video, I think the converter is the main reason the 60' is lazy.
If that's the case, adding some lash should help the 60'. I'd do the change back to back at the track to rule out day to day changes. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Page 2 of 3 1 2 3
