Re: Question about Mr. Norm's six pack (intake / carbs) setup
[Re: Texican]
#3074633
09/05/22 10:10 PM
09/05/22 10:10 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
It's probably the direct connection mechanical carb setup.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: fastmark]
#3074755
09/06/22 11:28 AM
09/06/22 11:28 AM
Posts: 3,316 West Coast, USA
jbc426
West Coast, USA
The Direct Connection mechanical carbs have always been my favorite. I have two sets sitting around here.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: fastmark]
#3074806
09/06/22 01:50 PM
09/06/22 01:50 PM
Posts: 583 Texas
Texican
Texas
Well, if the center carb is 4782, it’s a 350 cfm. If the outboards are 4783, they are 500 cfm and mechanical secondaries. They were an over the counter setup available through a Mopar dealer. The bowls will all be the side hung Holley with driver fuel inlet. If they are center hung bowls with vacuum pods, they are Corvette carbs or bowls. I picture is worth a thousand words. Carb numbers will help too. Good information, thanks. Center carb is 4782 and both outboards are 4783 with the following list numbers: C: 2641 F: 1380 R: 2241
[Re: Texican]
#3074807
09/06/22 01:51 PM
09/06/22 01:51 PM
Posts: 583 Texas
Texican
Texas
[Re: Texican]
#3074972
09/06/22 09:16 PM
09/06/22 09:16 PM
Posts: 16,132 Omaha Ne
TJP
Omaha Ne
Equally important question:
What was the advantage of this setup vs. stock ? Why enter the fuel line from driver’s side ?
Was there an advantage or did he just want to be different ?
Thanks Mechanical vs Vacuum secondaries No secondary idle adjustment Ability to change jets on the secondaries the fuel line is due to the way holley offered them. I have run multiple sets of these carbs on different motors since about 1976. They work REALLY well on 440's and Stroked SB's. When those secondaries open it's much like a passing gear. If you happen to be in an automatic car and it does drop to second or first it's a real experience
[Re: Texican]
#3075018
09/07/22 05:07 AM
09/07/22 05:07 AM
Posts: 6,674 Abilene, Texas
fastmark
Abilene, Texas
Thanks The reason fuel inlet is on the driver side is that is the only bowl that will fit the carb spacing using the regular metering blocks in the rear. One advantage, as mentioned, you can change the jets in the outboards. These were marketed as an over the counter carb or ones that you could get from Holley. The mechanical secondaries do give you a big kick when you get into them. I had a set on a race car and they ran great in testing around on the street. On a race cars with slicks and a sticky track, I had a bad bog. I never could spend the time to try and work that out. I went back to the oem vacuum secondaries and started playing with the springs. It went much faster and consistent without the bog. I figured if the stockers and super stockers could run as fast as they were with vacuum secondaries, I could be satisfied with oem as well.
[Re: Texican]
#3075035
09/07/22 07:42 AM
09/07/22 07:42 AM
Posts: 75,354 A gulag near you.
JohnRR
A gulag near you.
Well, if the center carb is 4782, it’s a 350 cfm. If the outboards are 4783, they are 500 cfm and mechanical secondaries. They were an over the counter setup available through a Mopar dealer. The bowls will all be the side hung Holley with driver fuel inlet. If they are center hung bowls with vacuum pods, they are Corvette carbs or bowls. I picture is worth a thousand words. Carb numbers will help too. Good information, thanks. Center carb is 4782 and both outboards are 4783 with the following list numbers: C: 2641 F: 1380 R: 2241 You should fix that line to the rear carb , that little piece of rubber line is an accident waiting to happen.
Mainstream Media is the new Pravda
[Re: AARCONV]
#3075324
09/07/22 08:16 PM
09/07/22 08:16 PM
Posts: 44,055 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Norm bought the Corvette carbs for his GSS builds because they were $20 cheaper than Chrysler carbs, it was as simple as that...LOL
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3075940
09/09/22 10:11 PM
09/09/22 10:11 PM
Posts: 744 New York
R/T1968R/T
New York
Actually they are not Chevy carbs they are a modified Ford carb. Chevy carbs have the vacuum pods, center hung bowls and only one metering block
[Re: R/T1968R/T]
#3075942
09/09/22 10:16 PM
09/09/22 10:16 PM
Rhinodart
Rhinotruck
Rhinotruck
Actually they are not Chevy carbs they are Ford carbs. Chevy carbs have the vacuum pods. And vacuum pods cannot be removed? Mr. Norm told me which Chevy dealer he bought them from in 1971...
A-Body's RULE!
[Re: Rhinodart]
#3075945
09/09/22 10:28 PM
09/09/22 10:28 PM
Posts: 744 New York
R/T1968R/T
New York
So you think he removed the vacuum pod, added side bowls. metering blocks and pumps? I read somewhere they were Ford carbs. Take a look at the old Ford tri power. They are identical. Here's a 406 Ford Tri Power.
[Re: R/T1968R/T]
#3075976
09/10/22 05:05 AM
09/10/22 05:05 AM
fastmark
Abilene, Texas
Seriously? You can’t see the difference in the two pictures YOU posted? The Mopar carbs he has are made by Holley for Mopars. They use the same body as a Mopar six pack using std Holley metering blocks and bowls from a regular side hung Holley carb. A Mopar air cleaner will not fit the Ford setup. I’ve got about 90 six pack carbs, as well as a set of the same as the original poster. I sold a ford set long ago. Corvette outboards have a different main body Mopars. Corvettes and Ford outboards both have an air horn on them with the choke parts removed.
