carbs, clutch and two step launch question
#3074277
09/04/22 06:52 PM
09/04/22 06:52 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
When launching off a 2 step with a carbureted engine, which is better:
Mat the gas to bring the RPM up on to the rev limiter prior to launch and then launch with no accelerator pump shot?
Or apply just enough throttle to bring the RPM up on to the rev limiter prior to launch and then mat the gas upon launch, and get some pump shot- into the motor?
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: carbs, clutch and two step launch question
[Re: Hemi_Joel]
#3074286
09/04/22 07:28 PM
09/04/22 07:28 PM
Posts: 9,101 Rogue River, OR
Jeremiah
Rogue River, OR
If I can't get the car to hook hard I leave on the floor mat becaise it doesnt seem to need the pump shot when it is black tracking. If I can make it stick reasonably well I have better luck setting the two step at say 5200, holding it at 5k and then matting the pedal on the bottom of the last yellow bulb. This technique seems to mitigate a bog especially when running (yawn) n/a.
This technique has also served me particularly well when using a nitrous kit activated by a WOT switch with a tine bit of delay programmed in (i.e. .1-.2 seconds)
Lots of variables at plat here especially driving style, clutch manners, power/weight ratio and traction. Many look at these variables as confusing and time consuming to dial in but I try to use them at my advantage the best I can wrap my head around what the car is doing. As we say "you will be the first one to know" lol
[Re: Hemi_Joel]
#3074398
09/05/22 08:40 AM
09/05/22 08:40 AM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
When I race pro tree I go to the floor. The car stays down and the reaction time is better. But it tends to hit the tires harder, When I race sportsman tree, I just touch the 2 step. Seems easier on the car
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: JERICOGTX]
#3074771
09/06/22 01:31 PM
09/06/22 01:31 PM
Posts: 11,718 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If you aren't going to leave with the gas pedal on the mat, why use a 2-step?
Bump in with the line loc on and the RPMs up some - 2000-2500. Top bulb comes on, pedal on the mat. Adjust the 2 step RPM to where you need it.
[Re: CMcAllister]
#3074876
09/06/22 05:44 PM
09/06/22 05:44 PM
Hemi_Joel
Minnesota
Bump in with the line loc on and the RPMs up some - 2000-2500. Top bulb comes on, pedal on the mat. Adjust the 2 step RPM to where you need it. You can use a 2 step to have a 100% consistent launch RPM. It doesn't take wide open throttle to hold the unloaded motor at launch RPM. So you can mat the gas upon launch, so you get a pump shot. I'll just have to test.
[Re: Hemi_Joel]
#3074912
09/06/22 08:11 PM
09/06/22 08:11 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Interesting topic for sure I always floor it on first yellow and don't let off until the stripe. One of the best stick drivers I know still doesn't use a 2-step at all. He just leaves like the old days, on the mat right before the launch and pulling gears on an old Nash box. He races a 64 Galaxie wagon with an FE engine. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: CMcAllister]
#3074941
09/06/22 09:17 PM
09/06/22 09:17 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
It is a common strategy now with drive by wire throttle bodies to limit throttle opening on the two step. Clutch cars will have an “arm” switch for the two step with either a clutch switch or clutch position sensor activating/ deactivating the two step. You can program the system to limit throttle opening to any angle you choose to get you close, but slightly beyond your launch rpm. The ignition then zeros in on the desired rpm. This is much smoother and easier on the engine. The driver arms the system, clutch pedal activates the two step, stomp the throttle pedal to the floor, and the engine floats at the desired rpm until the clutch pedal is released.
[Re: TRENDZ]
#3074945
09/06/22 09:27 PM
09/06/22 09:27 PM
TRENDZ
Milwaukee WI
This is one of the Fueltech setup screens. you see that you can set the throttle angle on the two step.
[Re: TRENDZ]
#3075089
09/07/22 11:20 AM
09/07/22 11:20 AM
Hemi_Joel
Minnesota
[Re: Hemi_Joel]
#3075537
09/08/22 03:21 PM
09/08/22 03:21 PM
Posts: 10,049 MN
JERICOGTX
MN
Bump in with the line loc on and the RPMs up some - 2000-2500. Top bulb comes on, pedal on the mat. Adjust the 2 step RPM to where you need it. You can use a 2 step to have a 100% consistent launch RPM. It doesn't take wide open throttle to hold the unloaded motor at launch RPM. So you can mat the gas upon launch, so you get a pump shot. I'll just have to test. And we know you'll be out testing at LEAST 6 times before Drag Week, if not more...
69 GTX
68 Road Runner
