Re: Hedman shortys on 512?
[Re: radar]
#3074137
09/04/22 10:37 AM
09/04/22 10:37 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I would definitely cut off the 2.5" collector and step it up to 3". And if possible, maybe step up to 3.5" somewhere in the system.
[Re: ProSport]
#3074147
09/04/22 11:15 AM
09/04/22 11:15 AM
Posts: 4,406 Michigan
MarkZ
Worthy
Worthy
My mild 512 lost 40 peak hp on a chassis dyno going through 2.5" exhaust. Headers are 1 7/8" into 3" collector mid length. If you were going to neck it down to 2.5" then best to do farther down the line where the exhaust gases have cooled down.
[Re: AndyF]
#3074324
09/04/22 10:46 PM
09/04/22 10:46 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
I wouldn't even bother changing the collector.
Either build a set of headers or run what you have.
IMO, the block hugger aspect is your first/biggest restriction.
If you can build something with larger radius bends and matched to your exhaust port, even without increasing primary size you may find some benefit in a larger collector.
[Re: AndyF]
#3075029
09/07/22 08:26 AM
09/07/22 08:26 AM
Posts: 1,682 Philadelphia
radar
Philadelphia
They'll work fine on a street car. What you want with a street car is something that is trouble free. Thick flanges, good material, solid connections, etc. is what is important. Size isn't really very important since most street cars spend 90% of their time at less than 50% throttle. Hi Andy! Even with how small the mopar community is I’m always a little starstruck to get your input! Your book was a major inspiration. You hit the nail on the head as usual. Even the terrible chinese shortys felt like I had a snarling beast most of the time- my ‘2400’ converter isn’t mushy off idle but runs up to 3k like I sidestepped a clutch when you whack it, and the 512 is a neck snapping monster at any rpm. But the rare instances that I run WOT and shift at 5500 it feels boring like a 13 second car. I’m not sure how sensitive to exhaust my motor is but I’m really looking forward to the possibility of few more ponies and really looking forward to no leaks and access to the collectors for maintenance.
[Re: Dragula]
#3075186
09/07/22 03:26 PM
09/07/22 03:26 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
My 512 uses short headers, but they are 2-1/8 to 2-1/4 step headers to 4" collectors....I would not even consider anything below 1-7/8 tube size. Mopar BB large C.I. motors don't like small pipes, especially on the exhaust side of the collectors I saw the difference on my old BB 1969 Dart GTS at LACR years ago, it had a set of Hooker 1/78 primary pipe with 3.5 inch collectors, It had a set of exhaust pipes and mufflers that were 2.5 inch from the collectors into s set of Thrust Corvair Turbo mufflers 18 inches back from the collector and then around 20 inches out from the mufflers to the edge of the car in front of the rear tires. The car ran 3 runs in the 12.31 to 12.23ET at 109.4 to 109.7 MPH by using different RPM shifts with that exhaust system on. I remove it and the next three runs varied from 11.39 to 11.41 ET at 117.5 + mph My pump gas Duster had 3.0 inch exhaust system from the same Hooker fenderwell headers with a set of Magnaflow 3.0 inch straight threw mufflers mounted at the rear bumper, that car didn't vary .02 ET and less than .02 MPH in the 1/8 mile by removing that exhaust system Use 3.0 inch pipes from the headers back to the end of your system
