dash bulbs ?
#3073848
09/03/22 12:57 PM
09/03/22 12:57 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Is there any problem with replacing the standard 158 T-3 2cp bulb with a higher candle power 168 T-3 3cp ? I just want my dash lights a little brighter.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: dash bulbs ?
[Re: 68LAR]
#3073855
09/03/22 01:16 PM
09/03/22 01:16 PM
Posts: 15,866 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I upgraded to LED's and it took a few different tries to find ones that I could dim without problem and would be right color (green) for my '89 Diplomat. My picture is not the clearest because my iphone is old but these have worked out great. I still use the factory covers over bulb, can dim without problem, and they look very original just brighter. Picture doesn't do them justice. The factory bulbs were 168 peanut bulb. https://www.superbrightleds.com/194...e-135-lumens+color-Green+packamt-10-Pack
Facts are stubborn things.
Re: dash bulbs ?
[Re: larrymopar360]
#3073857
09/03/22 01:18 PM
09/03/22 01:18 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Here's a picture during day. Maybe you can tell better. Old ones wouldn't even be visible during day!
Re: dash bulbs ?
[Re: larrymopar360]
#3073860
09/03/22 01:26 PM
09/03/22 01:26 PM
68LAR
South Park, Pa.
Here's a picture during day. Maybe you can tell better. Old ones wouldn't even be visible during day! It looks great. Not sure if an LED bulb would work with an older car without getting too involved. I'm looking for a simple bulb swap. In it's self , will a challenge for a 70 year old crawling under the dash. If the 168's will work, then that's the way I'd like to go. Just need to know if I should expect any problem in doing so. Thanks for the input though. Pass on the LED numbers just in case I go that route.
Re: dash bulbs ?
[Re: 68LAR]
#3073870
09/03/22 01:37 PM
09/03/22 01:37 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Isn't the 194 a brighter version of the 168? If you're going to use the 168 might as well us the 194. But I think this LED bulb still might work if you have a basic Mopar printed board like this.
Re: dash bulbs ?
[Re: Cab_Burge]
#3073896
09/03/22 02:29 PM
09/03/22 02:29 PM
68LAR
South Park, Pa.
. LOL, my eyes are okay. Also, my dimmer switch is good. I do have the 194’s in now. They are a 2cp along with the 158’s. I don’t know what the difference is?
Re: dash bulbs ?
[Re: larrymopar360]
#3073908
09/03/22 03:07 PM
09/03/22 03:07 PM
Posts: 10,714 North Dakota
6PakBee
North Dakota
I upgraded to LED's and it took a few different tries to find ones that I could dim without problem and would be right color (green) for my '89 Diplomat. My picture is not the clearest because my iphone is old but these have worked out great. I still use the factory covers over bulb, can dim without problem, and they look very original just brighter. Picture doesn't do them justice. The factory bulbs were 168 peanut bulb. https://www.superbrightleds.com/194...e-135-lumens+color-Green+packamt-10-Pack Did you by chance try the blue variety?
Re: dash bulbs ?
[Re: 6PakBee]
#3073927
09/03/22 04:10 PM
09/03/22 04:10 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I upgraded to LED's and it took a few different tries to find ones that I could dim without problem and would be right color (green) for my '89 Diplomat. My picture is not the clearest because my iphone is old but these have worked out great. I still use the factory covers over bulb, can dim without problem, and they look very original just brighter. Picture doesn't do them justice. The factory bulbs were 168 peanut bulb. https://www.superbrightleds.com/194...e-135-lumens+color-Green+packamt-10-Pack Did you by chance try the blue variety? I did not because I wanted mine to look stock, which is the green. First I tried white. That was a mistake because it had a washed out silvery look, even with the little covers that go over bulb (factory). Then I bought the green ones that I posted the link for and they are perfect. As I wrote, unlike some others they will dim fine. They have polarity so just need to flip them if they don't work one way.
Re: dash bulbs ?
[Re: larrymopar360]
#3074126
09/04/22 09:37 AM
09/04/22 09:37 AM
6PakBee
North Dakota
I upgraded to LED's and it took a few different tries to find ones that I could dim without problem and would be right color (green) for my '89 Diplomat. My picture is not the clearest because my iphone is old but these have worked out great. I still use the factory covers over bulb, can dim without problem, and they look very original just brighter. Picture doesn't do them justice. The factory bulbs were 168 peanut bulb. https://www.superbrightleds.com/194...e-135-lumens+color-Green+packamt-10-Pack Did you by chance try the blue variety? I did not because I wanted mine to look stock, which is the green. First I tried white. That was a mistake because it had a washed out silvery look, even with the little covers that go over bulb (factory). Then I bought the green ones that I posted the link for and they are perfect. As I wrote, unlike some others they will dim fine. They have polarity so just need to flip them if they don't work one way. I'm not familiar with a Diplomat instrument cluster. Are the bulb covers green or blue? The cluster from my Roadrunner looks like the covers are blue.
Re: dash bulbs ?
[Re: 6PakBee]
#3074164
09/04/22 11:44 AM
09/04/22 11:44 AM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I upgraded to LED's and it took a few different tries to find ones that I could dim without problem and would be right color (green) for my '89 Diplomat. My picture is not the clearest because my iphone is old but these have worked out great. I still use the factory covers over bulb, can dim without problem, and they look very original just brighter. Picture doesn't do them justice. The factory bulbs were 168 peanut bulb. https://www.superbrightleds.com/194...e-135-lumens+color-Green+packamt-10-Pack Did you by chance try the blue variety? I did not because I wanted mine to look stock, which is the green. First I tried white. That was a mistake because it had a washed out silvery look, even with the little covers that go over bulb (factory). Then I bought the green ones that I posted the link for and they are perfect. As I wrote, unlike some others they will dim fine. They have polarity so just need to flip them if they don't work one way. I'm not familiar with a Diplomat instrument cluster. Are the bulb covers green or blue? The cluster from my Roadrunner looks like the covers are blue. The covers look kind of blue-ish but display green
Re: dash bulbs ?
[Re: larrymopar360]
#3074368
09/05/22 05:04 AM
09/05/22 05:04 AM
6PakBee
North Dakota
The covers look kind of blue-ish but display green Thanks for the info. This is something I've been seriously considering just because changing instrument cluster bulbs are such a pain.
Re: dash bulbs ?
[Re: 6PakBee]
#3074547
09/05/22 06:04 PM
09/05/22 06:04 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
The covers look kind of blue-ish but display green Thanks for the info. This is something I've been seriously considering just because changing instrument cluster bulbs are such a pain. Yeah, I wanted to for long time but hesitated. Then I got some bulbs that wouldn't dim, threw them away. Tried the white ones and they washed it out and looked like crap. I thought the white ones were right because stock ones were white. Nope. The ones I linked finally were perfect.
