1966 Dana #3073214
09/01/22 10:58 AM
09/01/22 10:58 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Looking for the housing flange to flange size on a 66-67 Dana l, I think it’s 5/8” less than the 68-70. Next question, how much inside tire room is there on a 66 Belvedere with stock rear? I can make the rear shorter if I have the room, 15 x8” rim and 10” tire, I don’t want to get to close to the outer fender
Re: 1966 Dana [Re: cudaman1969] #3073236
09/01/22 11:58 AM
09/01/22 11:58 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '66 Dana used a 7260 joint which is 2 7/8" across, the '67 used a 1330 joint which is 4" across. '68 and later used the 7290.
Re: 1966 Dana [Re: John_Kunkel] #3073276
09/01/22 01:28 PM
09/01/22 01:28 PM
fredericksburg,va
fredericksburg,va
No, the differential housing itself
Re: 1966 Dana [Re: cudaman1969] #3073287
09/01/22 02:00 PM
09/01/22 02:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: 1966 Dana [Re: cudaman1969] #3073499
09/02/22 08:50 AM
09/02/22 08:50 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I can ck over the weekend. My 66 Satellite has a dana in it
Re: 1966 Dana [Re: gtx6970] #3073526
09/02/22 11:05 AM
09/02/22 11:05 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
There is not alot of inside room with the leaf springs in the stock location. 4 3/4 is the optimal wheel backspacing for an 8 inch wheel. You can fit about 11 inches of section width without rubbing, maybe 11 1/4.
Any tighter will start rubbing the leaf spring in turns most likely. My slicks are about 11.6 and 28 inches tall and touch the springs on tight turns, only about 1/4 inch of clearance. If I space them out 1/8” they touch the inside of the outer wheelhouse instead. More clearance, maybe 3/8” to the wheelhouse that way (but I hate it scuffing the side wall).
This is with SS springs and regular shocks, I might be able to get away without rubbing with stiffer shocks or if the rear was higher (made in mexico SS springs sagged about 2 inches after a year or two), but if you have stock springs I’m sure it’d rub more.
Re: 1966 Dana [Re: GTX MATT] #3073569
09/02/22 01:34 PM
09/02/22 01:34 PM
fredericksburg,va
fredericksburg,va
Thanks just don’t want to make a special rim
