Re: A look at the inside of a 727 that lives
[Re: 71Demon528]
#3072799
08/30/22 11:44 PM
08/30/22 11:44 PM
Posts: 9,883 MI, usa
dvw
MI, usa
There was very little metal. Some inside the rear drum and some behind the governor support. It was all fine dust. I wanted to wash out all the Torrington's and the roller bearings in the governor support and tail shaft housing. Speaking of the roller bearing in the governor support. Originally the lube hole to the rear shaft was restricted by the roller bearing. My friend Paul again worked his magic on the governor support and whipped up a spacer to keep the roller captured in the right spot. Here's the pics and his work on the sun shell as well. Doug
[Re: dvw]
#3072812
08/31/22 06:06 AM
08/31/22 06:06 AM
Posts: 10,049 MN
JERICOGTX
MN
I have absolutely no idea what any of this stuff is, but nice to see a detailed post about it.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3072827
08/31/22 08:33 AM
08/31/22 08:33 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
I have absolutely no idea what any of this stuff is, but nice to see a detailed post about it. LMAO! Great post Doug! I'm still learning about the innards of these 727s...posts like these help a lot.
[Re: an8sec70cuda]
#3072996
08/31/22 06:06 PM
08/31/22 06:06 PM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
Jeff!! Really appreciate the detailed pics, I'm trying to learn as well and this is all super helpful!
[Re: Blusmbl]
#3073156
09/01/22 08:25 AM
09/01/22 08:25 AM
dvw
MI, usa
So a few mods I do. Pic 1 is the reaction shaft support. This a 71 or newer wide bushing version. The oil feed hole to the front clutch has been widened. Its done with a used cut off wheel that's worn down to about 1 1/2 " diameter. Or the high end guys can mill it. This also gives a good shot of the reaction shaft ring grooves. They are square and smooth. this can be verified by inserting the ring in the groove and holding it up to the light. You also want to look inside and see where the input shaft rings ride. That area should be smooth as well. The 2nd pic is the OE front pump vent. Drill it with a R drill. Then tap for 1/8 pipe and plug with an Allen plug. I'll go into detail where to locate it in the next post. Pic 3 is what's left of the parking gear/governor support. All cut down to reduce weight. We did cut a new snap ring groove in the output shaft further forward to retain it. The last pic is the accumulator blocker rod. You can really use anything. A piece of rod, an old bolt. Just make sure its not to long that it holds the valve body up off the case. Doug
[Re: J_BODY]
#3073375
09/01/22 07:32 PM
09/01/22 07:32 PM
dvw
MI, usa
Doug…. What’s your feelings on oil relief holes in the drums (help evacuate fluid/centrifugal weight)? Both of my older Lofgren builds had them including the 904 I’m currently beating on. I've never used them. How much oil is in the drum when the piston isn't applied? Good question. However the only time pressurized oil is in the drum is when the clutch is applied. That clutch pack always applys plenty quick. We all know the dreaded overlap. So why do we need them? Maybe someone smarter than me can shed some light. Doug
[Re: dvw]
#3073395
09/01/22 08:15 PM
09/01/22 08:15 PM
Posts: 326 Alberta
Wookie316
Alberta
Thanks for sharing this. Very appreciated.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: J_BODY]
#3073539
09/02/22 12:08 PM
09/02/22 12:08 PM
Posts: 26,005 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Doug…. What’s your feelings on oil relief holes in the drums (help evacuate fluid/centrifugal weight)? Both of my older Lofgren builds had them including the 904 I’m currently beating on. B&M found a decrease in parasitic loss in first gear with the holes. In 1st gear, the front clutch retainer turns at 80% of the input shaft speed in the opposite direction, so this means that the released clutches see a surface speed of 180% of input shaft speed; the trapped fluid in the drum creates lots of parasitic drag so drilling peripheral holes allows the trapped fluid to escape. I drill 3/16" holes in a staggered row. Nowadays, lots of builders place small pieces of rubber tubing between the disc floater ears to help keep the discs separated but the trapped fluid is still there with no place to go.
[Re: moparx]
#3073589
09/02/22 02:46 PM
09/02/22 02:46 PM
John_Kunkel
Rio Linda, CA
Evenly spaced around the periphery, no balance change.
[Re: racerx]
#3073707
09/02/22 10:13 PM
09/02/22 10:13 PM
dvw
MI, usa
I've long thought about the silicone O ring material between the high gear clutch stack up. The clutch drag would certainly be reduced in 1st and 2nd. I may drill the holes on the next go round as well. A lot of this stuff gains very little in ET. But all together you can see something. Got some time today and putt he trans back in. spent some time making sure the converter lined up properly fore/aft. On the 2 Mega blocks that I've used the rear block face is to short. Both of them required 1/8 aluminum spacers between the trans and block. Other wise the starter gear engages the flywheel teeth about 1/2 way. Also some converters bottom in the crank. Spacing the trans back also allows you to space the converter rearward from the flex plate to gain crank to snout clearance. Another mod is to drill the lower trans to engine mounting holes. then you can use a 3/8" bolt and nut instead of trying to put the 7/16" bolt through from the engine side. Many times the headers interfere with bolt removal in this area. It takes a little case clearancing around Where the bolt head will seat. A small head or allen bolt works well. A hole saw makes for a nice radius for the converter access. Doug
[Re: dvw]
#3073709
09/02/22 10:24 PM
09/02/22 10:24 PM
dvw
MI, usa
To add the RH46/518 repop pans are nice and cheap to boot. They are deeper than anything else. Structurally strong against leaks with a reusable gasket. Mines still using the same gasket from 2013. They do need a little notching for cable shift transmissions near the park housing. Being deep we made (Paul again) a longer 1 3/4" filter spacer. Doug
[Re: dvw]
#3073781
09/03/22 10:25 AM
09/03/22 10:25 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
I’m also a fan of the 47/48RE pan….. especially when there were some trans that’s didn’t have a core charge at work so they were free . Doug I tagged you on a cable shift 727 for sale on FB. Not sure if there any hard to find specific parts with those. Not like they’re laying around like they used to be Thanks for the interesting notes on the oil reliefs John….. but I can’t read that without hearing cliff clavins voice! great stuff!
[Re: J_BODY]
#3073813
09/03/22 12:05 PM
09/03/22 12:05 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Doug,
Nice autopsy man! Even though I don’t run a 727, I’ve learned some new stuff for sure. Thank you for taking the time to share.
Wes
"Any fool can know. The point is to understand"
- A. Einstein
[Re: dvw]
#3073890
09/03/22 02:17 PM
09/03/22 02:17 PM
Posts: 43,312 Bend,OR USA
Cab_Burge
Do those pans fit 727? What brand part number for the spacer if you don't mind sharing that info?
[Re: mopar dave]
#3073962
09/03/22 05:43 PM
09/03/22 05:43 PM
Blusmbl
Plymouth, MI
The aluminum Summit pan I picked up last year looks to be as deep as that one based on the filter extension size, but doesn't have a sweet reusable gasket like that one. I like it!
