How can I tell an exhaust leak from a valve tic?? #307246
05/04/09 07:45 AM
05/04/09 07:45 AM
Cincinnati, Ohio
Challenger 1 Offline OP
Cincinnati, Ohio
I can't seem to find my tic from my 440 motor with TTI headers. I've pulled the header and used a couple really hi dollar gaskets and have had the valve covers off several times. I can't seem to get rid of a tic. I wonder if the headers are leaking where the four pipes go into the collector. How can I find the ticking sound??
Re: How can I tell an exhaust leak from a valve tic?? [Re: Challenger 1] #307247
05/04/09 08:05 AM
05/04/09 08:05 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
To find a header leak, Pull a plug wire off one at a time and run it.
Re: How can I tell an exhaust leak from a valve tic?? [Re: Challenger 1] #307248
05/04/09 08:13 AM
05/04/09 08:13 AM
scratchnfotraction Offline
most likly its a leak,as I have chased a "lifter tick" with all my headers
my brand new headmans leak where the 4 tubes meet at the collector right from the get go
I used the copper rtv on the header gaskets,and let cure over night,that has fixed most of them
the new headers have a ball/cone set up down below so no gasket there now,that was the one that would go every time it rained for me
and nothing is worse than brand new high dollor headers and gaskets that leak
take a 2-3 foot piece of water hose and use it to listen around the tubes and header flange
also pull your vc and use the wood handle of it to push against the rockers as it runs,this will let you know which one is ticking,it will quit ticking with you pushig against it
do you hear it in the car only?
can you hear it under the hood while running?
most time I can only hear it in the car,never out side the car and under the hood
good luck
Re: How can I tell an exhaust leak from a valve tic?? [Re: scratchnfotraction] #307249
05/04/09 11:07 AM
05/04/09 11:07 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
A header leak will make noise only when your foot is on the gas. A valve tick will be RPM dependent and won't be affected by letting off on the gas.
Re: How can I tell an exhaust leak from a valve tic?? [Re: 69Cuda340S] #307250
05/04/09 12:07 PM
05/04/09 12:07 PM
This is easy. To find an exhaust leak, take a piece of hose, say, 3/8 fuel hose, and hold near your ear CAREFULLY. Search around and if it's an exhaust leak it will "blow in your ear"!!!!
Re: How can I tell an exhaust leak from a valve tic?? #307251
05/04/09 12:27 PM
05/04/09 12:27 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The chunk of hose trick does work well.
Re: How can I tell an exhaust leak from a valve tic?? [Re: buildanother] #307252
05/04/09 03:26 PM
05/04/09 03:26 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
If you want stereo use one in each ear!
Re: How can I tell an exhaust leak from a valve tic?? [Re: Classof70Chally] #307253
05/04/09 03:57 PM
05/04/09 03:57 PM
there is a mechanics stethoscope for stereo, ya know
Re: How can I tell an exhaust leak from a valve tic?? [Re: scratchnfotraction] #307254
05/04/09 04:41 PM
05/04/09 04:41 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Couple other tricks that help pinpoint a hard to locate exhaust tick.. Have someone plug the tailpipe with rags.. It increases the pressure making an exhuast leak more noticable... If you need more pull a little ATF down the carb, the smoke in the exhuast gives a visual indication of your leak...
Re: How can I tell an exhaust leak from a valve tic?? [Re: 1_WILD_RT] #307255
05/04/09 05:22 PM
05/04/09 05:22 PM
Cincinnati, Ohio
Cincinnati, Ohio
Great advise from everyone, tonight or tommorrow night I 'm gonna check it out again with my new homemade stethoscope. It's only mono though.
Maybe I need to hookup with a nurse?
Re: How can I tell an exhaust leak from a valve tic?? [Re: Challenger 1] #307256
05/04/09 06:04 PM
05/04/09 06:04 PM
I hope she looks like Miss Goodbody from heehaww
BR-549
Re: How can I tell an exhaust leak from a valve tic?? [Re: scratchnfotraction] #307257
05/04/09 10:43 PM
05/04/09 10:43 PM
salem, oregon. usa
E
elmor Offline
elmor  Offline
E
salem, oregon. usa
As long as she doesn't look like LULU!
Re: How can I tell an exhaust leak from a valve tic?? [Re: elmor] #307258
05/04/09 10:55 PM
05/04/09 10:55 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
I was going through this recently... looked for stethoscopes on eBay and found them for like $4, bought two just in case. When it got here, I took off the "drum" part and stuck in about a 2-foot length of metal brake line. Amazing how you can put the tip of that thing around the engine and hear all kinds of things that you never knew were there!
Darren
Re: How can I tell an exhaust leak from a valve tic?? [Re: Ludington1] #307259
05/05/09 09:13 AM
05/05/09 09:13 AM
NC
HMcCandless_Jr Offline
NC
A small squirt of Oil or Tranny fluid in the carb will show you where is. Also the plug wire off one at a time will as well.
Herb Jr
Re: How can I tell an exhaust leak from a valve tic?? [Re: HMcCandless_Jr] #307260
05/05/09 10:41 AM
05/05/09 10:41 AM
or mimi
Re: How can I tell an exhaust leak from a valve tic?? [Re: scratchnfotraction] #307261
05/05/09 12:47 PM
05/05/09 12:47 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Never tried this but how about removing the rocker shafts to close all the exhaust valve or seal the top of the carb.
Then plumb air or vacuum from the shop vac in the exhaust pipe.
Re: How can I tell an exhaust leak from a valve tic?? #307262
06/03/09 07:44 AM
06/03/09 07:44 AM
Cincinnati, Ohio
Cincinnati, Ohio
Great advise, I used a peice of rubber 3/8" fuel line and found the leak right away.
Hate to say it but it was the TTI headers that leaked from day one. I didn't think it would be them as they were new but there was a crack right where they were welded to the flange at the number 5 exhaust. I took them off for the third time and could see day light thru the flange. TTI ground the inside pipe before coating and it was real thin there with no weld penatration. I ground it clean on inside pipe and tig welded it back togeather and now the car is quiet like it show be. The motor even runs better. This has kept my car in the garage for like two years now. It was so depressing that I didn't even want to drive it like that, it sounded like crap. I'm thinking about emailing TTI to let them know of my troubles, I bought the headers from Indy Cly Head in Indy one day when I was driving thru there in 05. I hate to complain to anyone after that long of time. I wanted to thank everyone for the help and the mechanics stethoscope really works.
Re: How can I tell an exhaust leak from a valve tic?? [Re: Challenger 1] #307263
06/03/09 07:58 AM
06/03/09 07:58 AM
and thanks for the update on the cause and fix
makes me want to pull mine off and have a looky seee
I only got cheap headmans for 190$...but they should at least not leak at the welds right where the 4 go into the collector
it is depressing to get nice new stuff and its got issues from the git go
made me feel bumed out with mine also
Re: How can I tell an exhaust leak from a valve tic?? [Re: scratchnfotraction] #307264
06/03/09 10:57 AM
06/03/09 10:57 AM
Cincinnati, Ohio
Cincinnati, Ohio
I think the crack got bigger as the header was used/heated up. Because it got worse everytime I started the car it seemed.
Re: How can I tell an exhaust leak from a valve tic?? [Re: Challenger 1] #307265
06/04/09 10:29 PM
06/04/09 10:29 PM
Magnum Offline
Magnum  Offline
I'd consider that a manufacturing defect. Any warranty left?
