Lower Control Arm Issue- A Body vs B Body HELP! #3072485
08/29/22 09:13 PM
08/29/22 09:13 PM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
I may have put A body Lower Control arms on a B Body?
The sway bar tab is at the Bottom....
I had a bunch of Lower control Arms apart....
73 A Body I guess is a similar Lower Ball Joint to 69 B Body
I used the B-Body Pins to go through the K Frame....
They bolted up but.....
The 69 Sway Bar comes real close to the strut....
Actually hit on the Passenger side?????
Is there a dimensional difference in the 2 arms?
I aligned the car and it drives great!
I just found this
I
Re: Lower Control Arm Issue- A Body vs B Body HELP! [Re: 440PURSUIT] #3072502
08/29/22 10:08 PM
08/29/22 10:08 PM
DC, MD Suburbs
DC, MD Suburbs
Pic
Re: Lower Control Arm Issue- A Body vs B Body HELP! [Re: 440PURSUIT] #3072520
08/30/22 12:59 AM
08/30/22 12:59 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
All A body LCAs have a flat spot across the bottom like this:
Re: Lower Control Arm Issue- A Body vs B Body HELP! [Re: Kern Dog] #3072521
08/30/22 01:00 AM
08/30/22 01:00 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The B body has a curved bottom like so:
Re: Lower Control Arm Issue- A Body vs B Body HELP! [Re: Kern Dog] #3072522
08/30/22 01:02 AM
08/30/22 01:02 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Finally, as odd as it will seem, the A body LCA is longer than this B LCA by 1/2" from the pin to the ball joint mount.
Re: Lower Control Arm Issue- A Body vs B Body HELP! [Re: Kern Dog] #3072529
08/30/22 06:00 AM
08/30/22 06:00 AM
DC, MD Suburbs
DC, MD Suburbs
Thanks a lot for the pics. Now I see easier ways to identify!
Were any B bodies of the low mount tab sway bar style?
From FSM it appears A bodies were in 1969.
I’ll inspect closer.
I’m thinking it’s late 60’s A body by sway bar tab
Re: Lower Control Arm Issue- A Body vs B Body HELP! [Re: 440PURSUIT] #3072536
08/30/22 07:01 AM
08/30/22 07:01 AM
DC, MD Suburbs
DC, MD Suburbs
Longer A body installed
Re: Lower Control Arm Issue- A Body vs B Body HELP! [Re: 440PURSUIT] #3072537
08/30/22 07:02 AM
08/30/22 07:02 AM
DC, MD Suburbs
DC, MD Suburbs
Comparison
Re: Lower Control Arm Issue- A Body vs B Body HELP! [Re: 440PURSUIT] #3072538
08/30/22 07:06 AM
08/30/22 07:06 AM
DC, MD Suburbs
DC, MD Suburbs
Shorter B Body arm (lower) with correct “high mount” sway tab removed
Re: Lower Control Arm Issue- A Body vs B Body HELP! [Re: 440PURSUIT] #3072544
08/30/22 08:03 AM
08/30/22 08:03 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The shock absorber mounting holes are a bit different between the two as well. I'd have to have them side by side to remind me of the difference.
Re: Lower Control Arm Issue- A Body vs B Body HELP! [Re: Kern Dog] #3072606
08/30/22 01:46 PM
08/30/22 01:46 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Abody ones should be stamped VL (for Valiant Lancer)
Bbody one should be stamped P/D or R/W
Re: Lower Control Arm Issue- A Body vs B Body HELP! [Re: autoxcuda] #3072620
08/30/22 02:19 PM
08/30/22 02:19 PM
DC, MD Suburbs
DC, MD Suburbs
Here’s the best pics after I went to shop to find some
B body a high sway bar tab has 1” rolled lip extending from shock hole.
A body has more of a gentle 2” flare serenading from shock hole out toward Ball Joint mount
See attached
